Active Contributor
ACT-Standards
Message 1 of 8 (400 Views)
Create layer from highlighting words in text or mtext
400 Views, 7 Replies
09-23-2011 04:11 PM
I want to create a layer from selecting only some words from an mtext or text entitty.
Is it possible to highlight and select only part of the text from an mtext using a lisp routine ? similar to how Adobe Reader can select text.
What you can do is pass the MTEXT/TEXT String to a lsit box and select the name from there.
I wrote a routien similar to that before for my so called "Lazy Typist" staff
(defun c:LayerFromText(/ CDiaStr ListBoxDia CollectStr lst
StringList StrListS a Str RepStr b fnSTR)
(vl-load-com)
(defun CDiaStr ( / fnSTR)
(setq StrDiaFnme (vl-filename-mktemp "tmp.DCL"))
(setq fnSTR (open StrDiaFnme "a"))
(write-line
"dcl_settings : default_dcl_settings { audit_level = 3; }
GrabLayerNAme : dialog
{ label = \"\"; key= \"Taytol\";
: list_box { key = \"StrListS\"; multiple_select =
true; width = 20; height = 20; } spacer ;
ok_cancel;
}" fnSTR)
(close fnSTR) T
;;; List Box Dialog ;;;
(defun ListBoxDia (DiaName DiaKey Title Lst)
(setq StrDIA (load_dialog StrDiaFnme))
(if (not (new_dialog DiaName StrDIA))
(exit)
(start_list DiaKey)
(mapcar 'add_list Lst)
(end_list)
(set_tile "Taytol" Title)
(action_tile DiaKey (vl-prin1-to-string
(quote (set (setq dd (read DiaKey)) (get_tile $key)))))
(action_tile "accept" "(done_dialog 1)")
(action_tile "cancel" "(done_dialog 0)")
(start_dialog)
(unload_dialog StrDIA)
(mapcar '(lambda (x)
(atoi (chr x)))
(vl-remove
32
(vl-string->list (eval (read DiaKey)))))
;;; Collect String from List ;;;
(defun CollectStr (LstS LstC)
(apply 'Strcat
(mapcar '(lambda (y) (strcat (nth y LstC) " ")) LstS))
(defun StringList (ent / Str i Lst)
(setq Str (cdr (assoc 1 (entget (ssname ent 0))))
Str (LM:UnFormat (cdr (assoc 1 (setq Entype (entget (ssname a 0)))))
(if (equal (cdr (assoc 0 Entype)) "MTEXT") T nil)))
(while
(setq i (vl-string-search " " str))
(setq Lst (cons (substr str 1 i) Lst))
(setq str (substr str (+ 2 i)))
(reverse (cons str Lst)))
;;; Main Function ;;;
(setq a (ssget "_+.:S:E:L" '((0 . "*TEXT"))))
(setq StrList (StringList a))
(CDiaStr)
(Setq RepStr (CollectStr
(ListBoxDia
"GrabLayerNAme"
"StrListS"
"Select String to Follow"
StrList)
StrList))
(setq RepStr (lisped RepStr))
(vl-file-delete StrDiaFnme)
(cond ((and
(or (not (eq RepStr ""))
(/= RepStr 0)
(setq objs (ssget ":L"))
(repeat (sslength objs)
(setq TEnt (Entget (ssname objs 0)))
(entmod (subst (cons 8 (vl-string-translate " " "-"
(vl-string-trim "'\" " RepStr)))
(assoc 8 TEnt)
TEnt
(ssdel (ssname objs 0) objs)
;;; Unformat Text ;;;
;;; Lee Mac ;;;
(defun LM:UnFormat ( str mtx / _Replace regex ) (vl-load-com)
;; © Lee Mac 2010
(defun _Replace ( new old str )
(vlax-put-property regex 'pattern old) (vlax-invoke regex 'replace str new)
(setq regex (vlax-get-or-create-object "VBScript.RegExp"))
(mapcar
(function
(lambda ( x ) (vlax-put-property regex (car x) (cdr x)))
(list (cons 'global actrue) (cons 'ignorecase acfalse) (cons 'multiline actrue))
(mapcar
(function
(lambda ( x ) (setq str (_Replace (car x) (cdr x) str)))
("Ð" . "\\\\\\\\")
(" " . "\\\\P|\\n|\\t")
("$1" . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
("$1$2" . "\\\\(\\\\S)|[\\\\](})|}")
("$1" . "[\\\\]({)|{")
(setq str
(if mtx
(_Replace "\\\\" "Ð" (_Replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
(_Replace "\\" "Ð" str)
(vlax-release-object regex)
str
What it does select a TEXT/MTEXT displayes a list box for selection, and shows an edit box if you want to modify the string, assigns the layer to the selected objects
a blank space will be translated to a dash synbol i.e "his String" to this-String"
Kudos to Lee Macs Unformat Routine
HTH
Lee_Mac
Message 2 of 8 (388 Views)
Re: Create layer from highlighting words in text or mtext
09-24-2011 02:52 AM in reply to: ACT-Standards
To my knowledge there is no way using LISP to highlight sections of MText through the MText editor, nor determine which part of MText has been selected.
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
Active Contributor
ACT-Standards
Message 3 of 8 (375 Views)
09-24-2011 10:35 PM in reply to: Lee_Mac
Thanks Lee,
  I suspected that might be the case.
Paul
pbejse
Message 4 of 8 (337 Views)
09-27-2011 03:01 AM in reply to: ACT-Standards
(vl-load-com)
       (write-line
  ok_cancel;
  }"  fnSTR)
              (close fnSTR) T
   (exit)
  (start_list DiaKey)
   (end_list)
  (start_dialog)
                               (atoi (chr x)))
                        (vl-remove
                              32
      (apply 'Strcat
   (while
	(CDiaStr)
                                   (ListBoxDia
                                         "GrabLayerNAme"
                                         "StrListS"
                                         StrList)
                                   StrList))
  	(cond ((and
		     (/= RepStr 0)
			     (assoc 8 TEnt)
			     TEnt
;;;      Lee Mac	;;;
  ;; © Lee Mac 2010
  (mapcar
    (function
  (mapcar
    (function
      ("Ð"       . "\\\\\\\\")
  (setq str
    (if mtx
  str
HTH
Distinguished Mentor
_Tharwat
Message 5 of 8 (330 Views)
09-27-2011 04:59 AM in reply to: ACT-Standards
Fantastic idea pBe and a very great codes indeed .
it is good to add error trap to catch any errors if the user pressed cancel while codes are being ruuning .
Best regards.
Tharwat
____________________________________________________
Get learn and learn and practice , to become experienced guy .
pbejse
Message 6 of 8 (327 Views)
09-27-2011 05:22 AM in reply to: _Tharwat
Thank you for the compliment Tharwat.
but this code was done in haste. bunch of codes cobbled together, need to write it that before the IT group here blocks this webiste again. Its more like i'm giving the OP an idea and he can pick up from there.
and yes iit has virutally no error trapping. Hope the OP learns from it.
Cheers Tharwat
Active Contributor
ACT-Standards
Message 7 of 8 (309 Views)
09-28-2011 04:41 AM in reply to: pbejse
Thank you so much,
   I really appreciate that.
Paul
pbejse
Message 8 of 8 (305 Views)
09-28-2011 05:02 AM in reply to: ACT-Standards
Glad it works for you, it still need a lot of work though.
I'm pretty sure you can handle those  ACT-Standards
Cheers
