Hi, I need a macro to contain the following: (if does not exist) Make Layer "S-DIM", Color 1, set current, (if does not exist) Make Dimstyle "S-DIM12", set current.
If S-DIM, S-DIM12 do exist, set current
Solved by hmsilva. Go to Solution.
Hi m_rogoff,
just a starting point:
To the
"(if does not exist) Make Layer "S-DIM", Color 1, set current. If S-DIM do exist, set current"
you can use something like this
(command "_.layer" "_T" "S-DIM" "_M" "S-DIM" "_U" "S-DIM" "_C" "1" "" "")
To the
"(if does not exist) Make Dimstyle "S-DIM12", set current. If S-DIM12 do exist, set current"
perhaps something like this
(if (tblsearch "DImstyle" "S-DIM12") (command "-dimstyle" "_R" "S-DIM12") (command "_.dim" "DIMADEC" "0";; Angular decimal places "DIMALT" "Off";; Alternate units selected ;; add all the necessary variables to your dimstyle... "save" "S-DIM12";; to save your dimstyle and become current "exit");; to exit the command );; if
If you don't want to use the command function, you can entmake the new layer or the new dimstyle, or use VisualLISP, or...
Hope that helps
Henrique
Henrique,
Thanks for the suggestions. I am running Acad LT and need it in macro. Does this routine need a deisel expression? The first one is easy to convert to a macro.
Should I write the code to make a new dimstyle everytime, or is there a way (in macro) to use th IF statement? Thanks
@m_rogoff wrote:
Henrique,
You're welcome, m_rogoff
using Lt you can't use Autolisp, you can use an if statement, but I don't see a way to do a tblsearch in a macro...maybe someone else may have another solution...
Henrique
I don't know about the dimension style but if you use the layer command and use the "make" option it will automatically set it current if it exists and if it does not exist it will create it and then set it current. If the dimension style is stored as one one of your default styles in your templates it is just a matter of setting it. Or you can you can type -DIMSTYLE <enter> _a <enter> and select a dimension to copy the settings from. Haven't played around with that too much but if you know how to set all the variables for your dimension style at the command line then it is a matter of sitting down with a pad a paper and write step by step what you type in at the command line to create it. Then put that info in the macro. Here is what I used for your layer name. Worked fine for me.
^C^C-layer;_make;S-DIM;_color;1;;;
