Dear all,
create layer add discription some error come without discipation file run nice
please help me add the layer discripation
Command: MAKELAYERS ; error: too many arguments
(defun c:MakeLayers nil (vl-load-com) ;; © Lee Mac 2010 ;;----------------------------------------------------------------------------------------------;; ;; Specifications: ;; ;;----------------------------------------------------------------------------------------------;; ;; Description Data Type Remarks ;; ;;----------------------------------------------------------------------------------------------;; ;; Layer Name STRING Only standard chars allowed. ;; ;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256 ;; ;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS. ;; ;; Layer Lineweight REAL may be nil, negative=Default, otherwise 0 <= x <= 2.11 ;; ;; Plot? BOOLEAN T = Plot Layer, nil otherwise ;; ;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked ;; ;; Description STRING may be nil for no description ;; ;;----------------------------------------------------------------------------------------------;; ;; Function will print list detailing any unsuccesful layers ;; ;;----------------------------------------------------------------------------------------------;; (regapp "AcAecLayerStandard") ( (lambda ( lst ) (mapcar 'print (vl-remove-if 'cdr (mapcar (function (lambda ( x ) (and (caddr x) (LM:LoadLinetype (caddr x))) (cons (car x) (apply 'MakeLayer x)) ) ) lst ) ) ) ) '( ; Name Colour Linetype Lineweight Plot? Bitflag Description ( "EL_COMPONENTS" 7 "CONTINUOUS" -3 T 0 componets ) ( "EL_CONSTR_COMP" 1 "CONTINUOUS" -3 T 0 const ) ( "EL_FITTINGS" 4 "CONTINUOUS" -3 T 0 fitting ) ( "EL_LABEL" 1 "CONTINUOUS" -3 T 0 nil ) ( "EL_LABEL_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "EL_TERMINALS" 1 "CONTINUOUS" -3 T 0 nil ) ( "EL_TERMINALS_PE" 24 "CONTINUOUS" -3 T 0 nil ) ( "EL_TERMINALS_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "EL_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "EL_WIRES" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_ANNOTATION" 7 "CONTINUOUS" -3 T 0 nil ) ( "GE_LABEL" 10 "CONTINUOUS" -3 T 0 nil ) ( "GE_LABEL_TEXT" 253 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_DU" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_EN" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_FR" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_GE" 252 "CONTINUOUS" -3 T 0 nil ) ( "LA_HEADER_FRAME" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_HEADER_TXT" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST" 254 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST_FRAME" 254 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST_POS" 254 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_FRAME" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_LOGO" 10 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_LOGO_TXT" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_TXT" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_VIEWPORTS" 230 "CONTINUOUS" -3 nil 0 nil ) ( "PN_ACCESSORIES" 30 "CONTINUOUS" -3 T 0 nil ) ( "PN_ACTUATORS" 160 "CONTINUOUS" -3 T 0 nil ) ( "PN_AIR_LINE_EQUIPMENT" 40 "CONTINUOUS" -3 T 0 nil ) ( "PN_BRACKET_MOUNTING" 1 "ACAD_ISO12W100" -3 T 0 nil ) ( "PN_CABINET" 8 "CONTINUOUS" -3 T 0 nil ) ( "PN_CABINET_DIM" 8 "CONTINUOUS" -3 T 0 nil ) ( "PN_COMPONENTS" 7 "CONTINUOUS" -3 T 0 nil ) ( "PN_CONDUCTS" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_CONSTR_COMP" 2 "CONTINUOUS" -3 T 0 nil ) ( "PN_DRAIN" 3 "HIDDEN" -3 T 0 nil ) ( "PN_EXHAUST" 104 "CONTINUOUS" -3 T 0 nil ) ( "PN_FITTINGS" 30 "CONTINUOUS" -3 T 0 nil ) ( "PN_IDENTIFICATION" 4 "CONTINUOUS" -3 T 0 nil ) ( "PN_PILOT_SUPPLY" 3 "HIDDEN" -3 T 0 nil ) ( "PN_PORT_NUMBERS" 8 "CONTINUOUS" -3 T 0 nil ) ( "PN_PRESSURE_SWITCHES" 200 "CONTINUOUS" -3 T 0 nil ) ( "PN_PROPORTIONAL_VALVES" 226 "CONTINUOUS" -3 T 0 nil ) ( "PN_SECTIONS" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_SUB-BASES" 8 "ACAD_ISO12W100" -3 T 0 nil ) ( "PN_SUB-BASE_CONDUCTS" 2 "CONTINUOUS" -3 T 0 nil ) ( "PN_SUPPLY" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_TXT" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_VACUUM" 60 "CONTINUOUS" -3 T 0 nil ) ( "PN_VALVES" 240 "CONTINUOUS" -3 T 0 nil ) ( "PN_VALVES_OVERRIDE" 1 "CONTINUOUS" -3 T 0 nil ) ) ) (princ) ) (defun MakeLayer ( name colour linetype lineweight willplot bitflag description ) ;; © Lee Mac 2010 (or (tblsearch "LAYER" name) (entmake (append (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "LTYPE" linetype)) linetype "CONTINUOUS" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (if (minusp lineweight) -3 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) ) (if description (list (list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) ;;--------------------=={ Load Linetype }==-------------------;; ;; ;; ;; Attempts to load a specified linetype from any linetype ;; ;; definition files (.lin) found in the ACAD Support Path ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; lt - name of linetype to load ;; ;;------------------------------------------------------------;; ;; Returns: T if linetype loaded successfully, else nil ;; ;;------------------------------------------------------------;; (defun LM:LoadLinetype ( lt ) (vl-load-com) ;; © Lee Mac 2010 (cond ( (tblsearch "LTYPE" lt) ) ( (progn (or acdoc (setq acdoc (vla-get-ActiveDocument (setq acapp (vlax-get-acad-object))))) (or aclts (setq aclts (vla-get-Linetypes acdoc))) (vl-some (function (lambda ( file ) (vl-catch-all-apply 'vla-load (list aclts lt file)) (and (tblsearch "LTYPE" lt)) ) ) (setq *LineTypeDefs* (cond ( *LineTypeDefs* ) ( (apply 'append (mapcar '(lambda ( directory ) (vl-directory-files directory "*.lin" 1)) (LM:str->lst (vla-get-SupportPath (vla-get-Files (vla-get-Preferences acapp))) ";" ) ) ) ) ) ) ) ) ) ) ) ;;-------------------=={ String to List }==-------------------;; ;; ;; ;; Separates a string into a list of strings using a ;; ;; specified delimiter string ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; str - string to process ;; ;; del - delimiter by which to separate the string ;; ;;------------------------------------------------------------;; ;; Returns: A list of strings ;; ;;------------------------------------------------------------;; (defun LM:str->lst ( str del / pos ) ;; © Lee Mac 2010 (if (setq pos (vl-string-search del str)) (vl-remove "" (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))) (list str) ) )
Solved by Lee_Mac. Go to Solution.
Try this instead:
(defun c:MakeLayers nil (vl-load-com) ;; © Lee Mac 2010 ;;----------------------------------------------------------------------------------------------;; ;; Specifications: ;; ;;----------------------------------------------------------------------------------------------;; ;; Description Data Type Remarks ;; ;;----------------------------------------------------------------------------------------------;; ;; Layer Name STRING Only standard chars allowed. ;; ;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256 ;; ;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS. ;; ;; Layer Lineweight REAL may be nil, negative=Default, otherwise 0 <= x <= 2.11 ;; ;; Plot? BOOLEAN T = Plot Layer, nil otherwise ;; ;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked ;; ;; Description STRING may be nil for no description ;; ;;----------------------------------------------------------------------------------------------;; ;; Function will print list detailing any unsuccesful layers ;; ;;----------------------------------------------------------------------------------------------;; (regapp "AcAecLayerStandard") ( (lambda ( lst ) (mapcar 'print (vl-remove-if 'cdr (mapcar (function (lambda ( x ) (if (caddr x) (LM:LoadLinetype (caddr x))) (cons (car x) (apply 'MakeLayer x)) ) ) lst ) ) ) ) '( ; Name Colour Linetype Lineweight Plot? Bitflag Description ( "EL_COMPONENTS" 7 "CONTINUOUS" -3 T 0 "componets") ( "EL_CONSTR_COMP" 1 "CONTINUOUS" -3 T 0 "const" ) ( "EL_FITTINGS" 4 "CONTINUOUS" -3 T 0 "fitting" ) ( "EL_LABEL" 1 "CONTINUOUS" -3 T 0 nil ) ( "EL_LABEL_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "EL_TERMINALS" 1 "CONTINUOUS" -3 T 0 nil ) ( "EL_TERMINALS_PE" 24 "CONTINUOUS" -3 T 0 nil ) ( "EL_TERMINALS_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "EL_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "EL_WIRES" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_ANNOTATION" 7 "CONTINUOUS" -3 T 0 nil ) ( "GE_LABEL" 10 "CONTINUOUS" -3 T 0 nil ) ( "GE_LABEL_TEXT" 253 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_DU" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_EN" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_FR" 252 "CONTINUOUS" -3 T 0 nil ) ( "GE_TXT_LANGUAGE_GE" 252 "CONTINUOUS" -3 T 0 nil ) ( "LA_HEADER_FRAME" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_HEADER_TXT" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST" 254 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST_FRAME" 254 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST_POS" 254 "CONTINUOUS" -3 T 0 nil ) ( "LA_MATLIST_TXT" 252 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_FRAME" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_LOGO" 10 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_LOGO_TXT" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_TITLE_TXT" 7 "CONTINUOUS" -3 T 0 nil ) ( "LA_VIEWPORTS" 230 "CONTINUOUS" -3 nil 0 nil ) ( "PN_ACCESSORIES" 30 "CONTINUOUS" -3 T 0 nil ) ( "PN_ACTUATORS" 160 "CONTINUOUS" -3 T 0 nil ) ( "PN_AIR_LINE_EQUIPMENT" 40 "CONTINUOUS" -3 T 0 nil ) ( "PN_BRACKET_MOUNTING" 1 "ACAD_ISO12W100" -3 T 0 nil ) ( "PN_CABINET" 8 "CONTINUOUS" -3 T 0 nil ) ( "PN_CABINET_DIM" 8 "CONTINUOUS" -3 T 0 nil ) ( "PN_COMPONENTS" 7 "CONTINUOUS" -3 T 0 nil ) ( "PN_CONDUCTS" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_CONSTR_COMP" 2 "CONTINUOUS" -3 T 0 nil ) ( "PN_DRAIN" 3 "HIDDEN" -3 T 0 nil ) ( "PN_EXHAUST" 104 "CONTINUOUS" -3 T 0 nil ) ( "PN_FITTINGS" 30 "CONTINUOUS" -3 T 0 nil ) ( "PN_IDENTIFICATION" 4 "CONTINUOUS" -3 T 0 nil ) ( "PN_PILOT_SUPPLY" 3 "HIDDEN" -3 T 0 nil ) ( "PN_PORT_NUMBERS" 8 "CONTINUOUS" -3 T 0 nil ) ( "PN_PRESSURE_SWITCHES" 200 "CONTINUOUS" -3 T 0 nil ) ( "PN_PROPORTIONAL_VALVES" 226 "CONTINUOUS" -3 T 0 nil ) ( "PN_SECTIONS" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_SUB-BASES" 8 "ACAD_ISO12W100" -3 T 0 nil ) ( "PN_SUB-BASE_CONDUCTS" 2 "CONTINUOUS" -3 T 0 nil ) ( "PN_SUPPLY" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_TXT" 3 "CONTINUOUS" -3 T 0 nil ) ( "PN_VACUUM" 60 "CONTINUOUS" -3 T 0 nil ) ( "PN_VALVES" 240 "CONTINUOUS" -3 T 0 nil ) ( "PN_VALVES_OVERRIDE" 1 "CONTINUOUS" -3 T 0 nil ) ) ) (princ) ) (defun MakeLayer ( name colour linetype lineweight willplot bitflag description ) ;; © Lee Mac 2010 (or (tblsearch "LAYER" name) (entmake (append (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "LTYPE" linetype)) linetype "CONTINUOUS" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (if (minusp lineweight) -3 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) ) (if description (list (list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) ;;--------------------=={ Load Linetype }==-------------------;; ;; ;; ;; Attempts to load a specified linetype from any linetype ;; ;; definition files (.lin) found in the ACAD Support Path ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; lt - name of linetype to load ;; ;;------------------------------------------------------------;; ;; Returns: T if linetype loaded successfully, else nil ;; ;;------------------------------------------------------------;; (defun LM:LoadLinetype ( lt ) (cond ( (tblsearch "LTYPE" lt) ) ( (progn (or acapp (setq acapp (vlax-get-acad-object))) (or acdoc (setq acdoc (vla-get-ActiveDocument acapp))) (or aclts (setq aclts (vla-get-Linetypes acdoc))) (vl-some (function (lambda ( file ) (vl-catch-all-apply 'vla-load (list aclts lt file)) (and (tblsearch "LTYPE" lt)) ) ) (setq *LineTypeDefs* (cond ( *LineTypeDefs* ) ( (apply 'append (mapcar '(lambda ( directory ) (vl-directory-files directory "*.lin" 1)) (LM:str->lst (vla-get-SupportPath (vla-get-Files (vla-get-Preferences acapp))) ";" ) ) ) ) ) ) ) ) ) ) ) ;;-------------------=={ String to List }==-------------------;; ;; ;; ;; Separates a string into a list of strings using a ;; ;; specified delimiter string ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; str - string to process ;; ;; del - delimiter by which to separate the string ;; ;;------------------------------------------------------------;; ;; Returns: A list of strings ;; ;;------------------------------------------------------------;; (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (vl-remove "" (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))) (list str) ) )
Also, why did you modify my code header to remove my site?
dear sir
thx for help
i dont no hows erase u r code header to remove
this code copy cadtutuor site
