Good night would create a new text style by entmake
so far did it
(defun c:ntext()
(entmake (list
(cons 0 "style")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbTextStyleTableRecord")
(cons 2 "novo_texto")
(cons 40 0.5)
(cons 41 1)
but is not working, someone could help me.
Solved by hmsilva. Go to Solution.
Hi Marcelo,
try
(entmake (list (cons 0 "style") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbTextStyleTableRecord") (cons 2 "novo_texto") ;; Standard flag values (bit-coded values): ;; 0 = Normal text ;; 1 = If set, this entry describes a shape ;; 4 = Vertical text ;; 16 = If set, table entry is externally dependent on an xref '(70 . 0) (cons 40 0.5) (cons 41 1.0) ;; your font file (cons 3 "C:\\Windows\\Fonts\\arial.ttf") ) )
Henrique
