Visual LISP, AutoLISP and General Customization
creat a command
4 REPLIES 4
417 Views, 4 Replies
creat a command
i made a toolbar that has a command like this "_plot 752.3389,680.5393 641.0157,524.6924" a print command.
when i click on the toolbar commands the print windows appear then i click on the option "windows", autcad take the coordinates and print the object ,
http://www.youtube.com/watch?v=HzYJVMeHOag&feature=youtu.be
it works..
but i have to click on the button "window" when print window appear ..
is there any way to make the command choose a particular button of the print window..
thax
4 REPLIES 4
Rtogores
I believe you should use something more powerful than a menu macro. You can use Visual LISP to set the Layout's PlotType property before you try to plot.
Look for PlotStyle in the ActiveX Reference.
This is a sample program included in the AutoCAD 2013 ActiveX Reference:
(vl-load-com)
(defun c:Example_PlotType()
    ;; This example reads and modifies the PlotType
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    (setq acadObj (vlax-get-acad-object))
    (setq doc (vla-get-ActiveDocument acadObj))
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    ;; Read and display the original value
    (setq originalValue (vla-get-PlotType ACADLayout))
    (alert (strcat "The PlotType value is set to: " (itoa originalValue)))
    ;; Modify the PlotType preference by toggling the value
    (vla-put-PlotType ACADLayout acExtents)
    (alert (strcat "The PlotType preference has been set to: " (itoa (vla-get-PlotType ACADLayout))))
    ;; Reset the preference back to its original value
    (vla-put-PlotType ACADLayout originalValue)
    (alert (strcat "The PlotType preference was reset back to: " (itoa originalValue)))
 I hope this helps.
hmsilva
mr-_-small,
put this macro in your button...
^C^C-PLOT;Y;;;;;;;W;752.3389,680.5393;641.0157,524.6924;;;;;;;;;;
the best way is to write macros is using the command-line version.
of the command you want to use, and see how many enters are needed and the required options...
Hope that helps,
Henrique
in reply to: hmsilva
thank you  fhmsilva .... thiss exactly what im looking for....
you are awesome and brilliant ..... best answer
hmsilva
You're welcome, mr-_-small
Henrique
”Boost
