Hi all,
Can some one help me a lisp to count dynamic block including total lenght.
Hi
The first block into your drawing is not considered as a Dynamic Block , so the following routine would would the trick on
the same dynamic blocks that you uploaded with you sample drawing .
(defun c:TesT (/ total selectionset count intger selectionsetname vl a b) (vl-load-com) ;;; Tharwat 02 . April . 2012 ;;; ;; Count number of selected Dynamic blocks and length of total selected dynamic blocks (if (setq total 0 selectionset (ssget '((0 . "INSERT") (2 . "`*U*"))) ) (progn (setq count (sslength selectionset)) (repeat (setq intger (sslength selectionset)) (setq selectionsetname (ssname selectionset (setq intger (1- intger)) ) ) (setq vl (vlax-ename->vla-object selectionsetname)) (vla-getboundingbox vl 'a 'b) (setq total (+ total (distance (list (car (vlax-safearray->list b)) (cadr (vlax-safearray->list a)) ) (vlax-safearray->list a) ) ) ) ) (print (strcat " Total number of Dynamic Blocks :" "< " (itoa count) " >" ) ) (print (strcat " Total lengths of Dynamic Blocks :" "< " (rtos total 2) " >" ) ) ) (princ) ) (princ) )
This one is a little bit better for the same block name and wth message box .
(defun c:Test
(/ total selectionset count intger selectionsetname a b)
(vl-load-com)
;; Count number of selected Dynamic blocks and length of selected dynamic blocks
(if (setq total 0
selectionset
(-4 . "<or")
(2 . "`*U*")
(2 . "_P1000")
(-4 . "or>")
(progn
(vla-getboundingbox
'a
'b
(alert (strcat " Total number of Dynamic Blocks :"
(itoa count)
"\n"
(rtos total 2)
(princ)
(princ)
Hi Tharwat, I know the OP show only the _p1000 "original" block.
But, what could be happen if there is another "original" block , and furthermore, what about if it have a inclination?.
I think the user shall pick the block to size and count, then using the EFFECTIVE NAME , select all them , or split them from the inserted blocks.
If they are not a 0 inclination or slope , there will be a issue to get the real distance.
Gabriel.
Try this
(defun c:CDL ( / ss val ttl) (setq bn "_P1000" ttl 0 i 0) (if (ssget "_X" (list '(0 . "INSERT")(cons 2 (strcat bn ",`*U*")))) (progn (vlax-for itm (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (if (and (= :vlax-true (vla-get-isdynamicblock itm)) (setq val (vl-remove-if-not '(lambda (x) (eq (vla-get-PropertyName x) "Distance")) (vlax-invoke itm 'getdynamicblockproperties)))) (setq ttl (+ ttl (vlax-get (car val) 'value)) i (1+ i)) ) ) (vla-delete ss) (alert (strcat "Number of Blocks: " (itoa i) "\nTotal Length: " (rtos ttl 2 2))) ) (prompt "\n** Nothing selected ** ")) (princ))
HTH
@devitg wrote:Hi Tharwat, I know the OP show only the _p1000 "original" block.
But, what could be happen if there is another "original" block , and furthermore, what about if it have a inclination?.I think the user shall pick the block to size and count, then using the EFFECTIVE NAME , select all them , or split them from the inserted blocks.
Gabriel.
You're right devitg .
I knew that and I did not write the rotine before taking a look at the attached drawing . if all blocks are similar to the once in the drawing , the code would give correct lengths , otherwise there be a mistake in the total of lengths .
the routine that given by pBe is very accurate completely .
Thanks a lot.
@_Tharwat wrote:You're right devitg .the routine that given by pBe is very accurate completely .Thanks a lot.Not at all Tharwat. it lacks error trapping besides i missed this part
(eq (strcase (vla-get-effectivename itm)) bn)(setq val (vl-remove-if-not......
But thanks nonetheless tharwat.
Cheers
Thanks for all, but what I mean is total of length for each piece including original block (_P1000) so I can able to cut them off.
@devitg wrote:
But you can use the DATAEXTRACTION ......
I concur.
For the fun of it
(defun c:CDL (/ ss val_rnd lst Pname) (setq bn "_P1000" Pname "Distance" lst nil ) (setq _rnd (lambda (n) (fix (+ n (/ n (abs n) 2.))))) (if (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat bn ",`*U*"))) ) (progn (vlax-for itm (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object) ) ) ) (if (and (= :vlax-true (vla-get-isdynamicblock itm) ) (eq (strcase (vla-get-effectivename itm)) bn) (setq val (vl-remove-if-not '(lambda (x) (eq (vla-get-PropertyName x ) Pname ) ) (vlax-invoke itm 'getdynamicblockproperties ) ) ) ) (if (setq d (assoc (_rnd (setq l (vlax-get (car val) 'value))) lst) ) (setq lst (subst (cons (car d) (1+ (cdr d))) d lst)) (setq lst (cons (cons l 1) lst)) ) ) ) (vla-delete ss) (textscr) (princ "\nQTY\tLength\t Total:") (foreach it (vl-sort lst '(lambda (k l) (< (car k) (car l)))) (princ (strcat "\n" (itoa (cdr it)) "\t\t" (rtos (car it) 2 2) "\t\t" (rtos (* (cdr it) (car it)) 2 2) ) ) ) ) (prompt "\n** Nothing selected ** ") ) (princ) )
Command: cdl
QTY Length Total:
1 12.00 12.00
3 18.00 54.00
2 22.00 44.00
3 24.00 72.00
1 28.00 28.00
Sorted by Length
HTH
Hi Pbejse,
Thanks for asking, at this time it does not work for me 😞
and if you don't mind would you help me one more time.
I am looking for.
QTY BLOCK(S) NAME LENGTH
1 _P1000 1'-0"
1 _P1000 1'-6"
1 _P1000 1'-10"
1 _P1000 2'-0"
1 _P1000 2'-4"
Of course we have more than one bock in a drawing.
@tdcad wrote:Hi Pbejse,
Ok tdcad , humor me.
I would presume those are Dynamic blocks? and does it all have DISTANCE parameter?
And the names differs from every drawing?
The routine would have done and over with if you laid out everything from the get-go.
I perosnally dont mind helping you out, but you need to be very CLEAR about what you're trying to accomplish.
Everything we did here were based on your sample drawing
BTW: Did you try Data Extraction command suggested by devtg?
Hi Pbejse,
1- In a drawing I had more than one dynamic bock (they are unistruts but different type, name) withdistance parameters
2- All bock name will be same and never change.
3- I did try DATAEXTRACT (suggested by Devitg) but it's make me alot confusing.
1-2. We could re-write the cod above and use a fitler for block names. would you want it to be generic?. Thing is the Dynamic Property name "distance" can be modiied. it could be "distance1" "dist" depending on the user. If not a generic code a specific sets of properties and block names should be met fot he code to work
As for this
1 _P1000 1'-0"
1 _P1000 1'-6"
1 _P1000 1'-10"
You notice the difference between what i posted
QTY Length Total:
1 12.00 12.00
3 18.00 54.00
Does that mean you dont need/want to see the total for every varying lenghts? We could do this:
Block(S) Name QTY Length Total:
_P1000 1 1'-0" 1'-0"
_P500 3 1'-6" 4'-6"
Pbejse,
Sound good but I have a question is if we have some blocks with same name but the length are different.
Can you able call out those lengths with same bocks name?
Example:
_P500 3 1'-6" 4'-6"
_P500 2 2'-0" 4'-0"
Try:
(defun c:CDL (/ ss strnum bnm val lst d l Pname) ;;; pBe Arpil 2012 ;;; (vl-load-com) (setq Pname "Distance" lst nil ) (defun strnum (var val / p) (repeat (abs (- val (strlen var))) (setq p (strcat " " (if p p " ")))) (strcat var p) ) (if (ssget "_X" '((0 . "INSERT")(2 . "_P1000,_P57,_P2000,`*U*"))) (progn (vlax-for itm (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object) ) ) ) (if (and (= :vlax-true (vla-get-isdynamicblock itm) ) (setq bnm (vla-get-effectivename itm)) (setq val (vl-remove-if-not '(lambda (x) (eq (vla-get-PropertyName x ) Pname )) (vlax-invoke itm 'getdynamicblockproperties ) ) ) ) (if (setq d (assoc (list (setq l (vlax-get (car val) 'value)) bnm) lst) ) (setq lst (subst (list (list l bnm) (1+ (cadr d))) d lst)) (setq lst (cons (list (list l bnm) 1 ) lst)) ) ) ) (vla-delete ss) (textscr) (princ "\nBlock Name QTY Length Total") (foreach it (vl-sort lst '(lambda (k l) (< (cadar k) (cadar l)))) (princ (strcat "\n" (strnum (cadar it) 16) (strnum (itoa (last it)) 7) (strnum (rtos (caar it) 4 4) 14) (rtos (* (caar it) (last it)) 4 4))) ) ) (prompt "\n** Nothing selected ** ") ) (princ) )
The blocknames are hardcoded on the ssget filter
(ssget "_X" '((0 . "INSERT")(2 . "_P1000,_P57,_P2000,`*U*")));<-- do not removed that last entry
You need to change these Block names according to your drawing.
_P1000 2 1'-0" 2'-0"
_P1000 3 1'-11 1/2" 5'-10 9/16"
_P57 1 1'-6" 1'-6"
_P57 1 1'-10" 1'-10"
_P57 1 2'-0" 2'-0"
_P57 1 1'-0" 1'-0"
_P57 2 2'-4" 4'-8"
HTH
