Visual LISP, AutoLISP and General Customization
copy/entmake pline w/o xdata?
11 REPLIES 11
Message 1 of 12
Kevin_Van
746 Views, 11 Replies
How is the best way to go about this?
I have a ton of polylines I have to copy to another layer. Problem is these polylines have xdata linked to a db, which is linked to text in the drawing. When copied they create another entry in the db & another linked text entity.
My first attempt was a routine that would copy a pline, then unlink it (asset explode), than move it to another layer. That 's no good because of the multiple db entry & entlast gets the text not the pline.
I don't know much about entmake. Can I use it to create an identical pline w/o the xdata? Or is there another way?
Any & all help is appreciated.
11 REPLIES 11
Message 2 of 12
pciganek
in reply to: Kevin_Van
Kevin,
If I understand your problem correctly - it sounds like (setq new_obj (vla-Copy existing_obj)) would be the way to go. This avoids using a command call. Entmake will work as well (on LWPolylines) - but it's not as simple. As far as I can tell, entmake will not copy the xdata with it - vba-Copy will.
Once you have your new_obj - you can make your changes to the xdata as needed.
Peter
Message 3 of 12
Kevin_Van
Hey Peter,
Thanks. I'll try the vla-copy as you discribe.
There is no need to change the new_obj xdata. The key is when the new_obj is created it doesn't have any of the original's xdata which would go into the db.
Message 4 of 12
Don't use (entmake) to copy something. Doing that can easily
result in changing properties whose values are set to 'BYLAYER',
to the current ediitor settings.
You can read more about the perils of using (entmake) to copy
entities by reading this newsgroup.
How to do that depends on how (and when) the database records
are being created. Does it happen when you copy the objects or
at some later point? Is there a custom application managing the
data links?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5087790@discussion.autodesk.com...
Message 5 of 12
I'm curious as to why I see Tony's reply in my News reader (Thunderbird,
but also with OE), but I never got the original message that was being
replied to. I've seen this a few other time recently also. What's going
on? Is there activity on the web interface that's not making it to the
Newsgroup?
Message 6 of 12
Hmmmm . . . same for me! Odd.
Gordon.
"Ken Krupa" wrote in message
news:5726465@discussion.autodesk.com...
Newsgroup?
Message 7 of 12
The original post was from February of 2006. You'll
have to download all the headers from that time period
before you will see the original message.
Autodesk Discussion Group Facilitator
Newsgroup?
Message 8 of 12
OK, that explains it. Thanks.
Message 9 of 12
I wish it was easier to do that. Autodesk has things throttled to the
point that I seldom can download all headers in a newsgroup to a new
computer or after they "reorganize" a group -- it takes approximately
forever (up to 20 minutes for the larger groups), and the header
download generally times out (I have a 12M cable connection for
internet). I don't understand the logic behind their decision. Surely
Autodesk can afford decent servers and enough bandwidth.
Martin
Message 10 of 12
I don't think it's the servers or the bandwidth that is at fault here. I
think it lies in the software they are using to make these groups accessible
from both nntp & http.
Yes, I got a new PC last week and let it spent a good porton of last weekend
downloading the headers. Although, this time it only timed out 2 or 3 times.
The last time I did it, it timed out every 15k-20k headers.
Guess this is the one good thing about getting new PC's evry 3-4 years 😞
"Martin Shoemaker" wrote in message
news:5729206@discussion.autodesk.com...
Martin
Message 11 of 12
You see my reply only because I inadvertently
replied to an 18 month-old message :))
I do that sometimes when my sorting was by
subject and don't notice the date.
"Ken Krupa" wrote in message news:5726465@discussion.autodesk.com...
Newsgroup?
Message 12 of 12
What I recall is that they intentionally turned the header download
speed down a few years ago as part of one of the "reorganizations" of
the newsgroup articles. I think they posted something about making the
change to prevent people from hogging the available bandwidth, but it's
been a while.
I think they may well have a bandwidth issue -- it's not unusual when
reading posts with Thunderbird for the system to pause 10 to 20 seconds
on some of the posts. Most posts come up immediately, but a significant
number hang.
Martin
> Martin
”Boost
