Visual LISP, AutoLISP and General Customization
Copy Design With Renaming
1 REPLY 1
ASchlaack
212 Views, 1 Reply
In Inventor I've got an .iam that is ran through iLogic. I have this vaulted as a template. What I need to be able to do is copy design the .iam then rename it and also have it rename all the part contained within the .iam.
For example my .iam template name would be "15-1-0000 - ASSY" and each part in it would be named "15-1-0000 - PART".
When I design copy it I'd want to be able to do something along the lines of change the .iam name to "15-1-0001 - ASSY". And when I do that I would need each part to do a save as and have the name update to "15-1-0001 - PART".
In what way can I accomplish this? I'm clueless and anything would help, I need this done by Friday...
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
1 REPLY 1
ASchlaack
in reply to: ASchlaack
I did end up finding a way to do this.  If anyone runs into an issue like this they can contact me and I'll explain what I had to do.
Aaron Schlaack
”Boost
