Visual LISP, AutoLISP and General Customization
Copy block to multiple layout tabs
4 REPLIES 4
502 Views, 4 Replies
Does anyone have a nugget of code that will copy a selected block to
multiple layout tabs (preferably without having to switch to each tab)??
I can do it using COPYBASE (which might be kind of a hack way of doing it)
and cycling through the various CTABs, but I would LIKE to be able to do it
magically without switching to each tab first.
Anyone have anything like this kicking around he/she would like to share or
could possibly point me in the right direction??
Thanks in advance!
Matt W
"I did absolutely nothing, and it was everything I thought it could be."
4 REPLIES 4
You could use the InsertBlock method of the layout block object.
Tim
"A blind man lets nothing block his vision."
"Matt W" wrote in message
news:5090152@discussion.autodesk.com...
Thanks in advance!
Matt W
I'm not sure I follow you - I'm not too familiar with VLISP, but this is
what I came up with VBA (doesn't work though).
Public Sub Main()
Dim objSpace As AcadPaperSpace
Dim insertionPnt(0 To 2) As Double
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockRefObj = objSpace.InsertBlock(insertionPnt, "CircleBlock", 1#,
1#, 1#, 0)
End Sub
Matt W
I know it lisp you have to have the insertion point, scale factors, and
rotation in doubles. So this worked for me, where psp is a variable for
paper space.
(vlax-invoke psp 'InsertBlock '(0.0 0.0 0.0) "CIR-NOTE" 1.0 1.0 1.0 0.0)
Tim
news:5091786@discussion.autodesk.com...
Public Sub Main()
1#, 1#, 0)
End Sub
Matt W
does anyone have a lisp that accomplishes this? I am looking to copy something to multiple tabs, not have to open each one and paste.
thanks
”Boost
