My computer is getting re-imaged this weekend at work. What do I need to do to get AutoCad looking the same
way it does now after they reinstall AutoCad? Is there certain files that i need to copy or what? I have AutoCad 2006.
Basically what you need is to export your actual profile and any other which might be important for you. Also, if you have customization added to your menu file you should save this too, in order to be able to restore it on the new install (although you are not supposed to modify the ACAD.CUI file and keep your custom menus outside the AutoCAD install directory). You might also want to save your ACAD.PGP file and any other LSP, DCL, VLX, FAS, DVB files you might have placed in the AutoCAD install directory.
