How to create lisp file for multiple commands sequentially?
eg. copy with base point 0,0 and paste as block with base point 10,10.
Solved by hmsilva. Go to Solution.
Hello m.ugrinic and welcome to the Autodesk Community!
(defun c:demo (/ ss) (if (and (princ "\nSelect objects to copy from 0,0 and paste as block at 10,10: ") (setq ss (ssget)) ) (command "_.copybase" '(0.0 0.0 0.0) ss "" "_.pasteblock" '(10.0 10.0 0.0)) (prompt "\nYou did not select an object... ") ) (princ) )
Hope this helps,
Henrique
