Visual LISP, AutoLISP and General Customization
Copy & Rotate Macro not working in 2013
5 REPLIES 5
ceden
1341 Views, 5 Replies
Hi
I have a macro that i have been using in autocad 2012 for a simple copy & rotate command as follows ^C^C_select;auto;\_copy;p;;0,0;0,0;_move;p;;\\_rotate;p;;\\redraw
For some reason it now does not work in 2013
the macro exits after the copy part of the macro is finished & fails to let you rotate the copied object
Any suggestions would be appreciated
5 REPLIES 5
devitg
in reply to: ceden
I try to use MOCORO , and it crash ACAD 2013.
dbroad
in reply to: ceden
Ceden,
Try setting pickfirst to 0.  2013 works pretty much the same as 2012 except for command line parameters are clickable.
Devit,
mocoro works fine for me in 2013.  Can you post a sequence with a reproducable error?
Architect, Registered NC, VA, SC, & GA.
ceden
in reply to: dbroad
Dbroad
Thanks, it works a treat now
ceden
devitg
in reply to: dbroad
I reload acad 2013 , and now it work.
in reply to: ceden
I have Autocad 2013 and in certain files it will crash the program.  I reinstalled 2013 and it still crashes in certain files.  Any help would be appreciated.
”Boost
