I am trying to understand why the coordinates of the 4 corners of a viewport are ridiculously large if the viewport is viewing objects in 3D rotated view (such as viewing from South-East):
On the other hand, the same viewport viewing from Top / Front / Back / Left / Right has reasonable coordinates:
I would like to know why the coordinates of the viewport can become so large. And I also would like to know how we can calculate the very large coordinates.
I have a related post called "How to Find the 4 Corners of a Viewport in WCS _if_ the Viewport is at an Angle?". But I have a feeling that the title of that post may be a bit too specific. Therefore, I need to re-phrase the question to make the question more "general".
Please help. Thanks in advance.
Jay Chan
Solved by JC_BL. Go to Solution.
Seem like I need to set the UCS of the viewport in order to work with the coordinates conveniently. I will see how this goes.
Jay Chan
Yes, indeed I need to set up UCS instead of trying to calculate the crazily large coordinate numbers. I use this command to setup the UCS for the viewport:
(command "ucs" "view")
This works fine. I should have thought of that.
Jay Chan
