Converting DWG to AutoLisp
11 REPLIES 11
Message 1 of 12
1243 Views, 11 Replies
I have a DWG file. Is there any utility available to see the Autolisp script for this DWG file?
Thanks in advance
FACTS
11 REPLIES 11
Message 2 of 12
wrote in message news:4925000@discussion.autodesk.com...
DWG files do not contain scripts or autolisp. They can however contain VBA code. If this is what you mean, try the commands VBAMAN and VBAIDE
Message 3 of 12
I think you may be looking for "DBLIST."
This will list everything in the drawing.
Message 4 of 12
Nope, I'm not looking for anything.
R.K. McSwain
http://rkmcswain.blogspot.com
Message 5 of 12
HUM....are you sure?
I think not...
"R.K. McSwain" wrote in message
news:4925022@discussion.autodesk.com...
Message 6 of 12
As for your understanding of the database...well...there is a dxfcode that
will spit out all existing conditions within a file...
As for how to access that, depends on your programming
capabilities...activex and then some...
What exactly do you want to gather? or recreate...?
Thanks in advance
FACTS
Message 7 of 12
Rudy,
Have you heard of embedded VBA code?
R. Robert Bell
"Rudy Tovar" wrote in message
news:4925556@discussion.autodesk.com...
I think not...
Message 8 of 12
Yeah, I'm not questioning that...
but you can embed lisp code...
"R. Robert Bell" wrote in message
news:4926018@discussion.autodesk.com...
Rudy,
R. Robert Bell
I think not...
Message 9 of 12
Actually I wanted to change a 'Label/Text' in a DWG file and save it as a new DWG file dynamically and automatically using program made using VB.
Is there any other simple way, than wring complicated coding using DLLs ?
Message 10 of 12
rjay75
How do you embed Lisp Code and in what release did they add this functionality?
Reply From: Rudy Tovar
Date: Aug/11/05 - 17:39 (CDT)
Re: Converting DWG to AutoLisp
Message 11 of 12
2004 I think...maybe sooner...
Read your 'vlide' help...not autocads help...
wrote in message news:4927293@discussion.autodesk.com...
functionality?
Message 12 of 12
Let try DCL&AutoLisp Generator http://geocities.com/dclgenerator
With this you never need to know about the DCL file but still create proffessional look dialog. Dialog & autolisp automatic generated and link together. The code generate will run on every autocad version.
The DWG2LSP feature allow user to convert drawing entity in AutoCad drawing into AutoLisp code.
”Boost
