Thanks in advance
I need to convert Autocrat dwg files to Microstation V8.
Its possible to convertl globally ?
I am having lots of file in dwg.....
shanskvm
This is a far too complicated issue if you want to do it this way and it seems there are some problems with the direct conversion. It's a better idea to use a simple AutoCAD script in order to export the drawings in DXF format, which can be easily red by Microstation.
Such a script it's quite easy to create and it will do the job.
