Convert time CDATE in absolute minutes
7 REPLIES 7
Message 1 of 8
Gustavo_Bernardi
909 Views, 7 Replies
How to convert the format obtained in "CDate" in absolute minutes?
ex:
Command: (rtos (getvar "CDate") 2 4)
The result is:
"20130326.1301"
What I need is:
+01 minuts
+13 hours X 60 = 780 minuts
+26  x 1440 = 37440 minuts
the current time this month is: 38221 minutes
TIA
7 REPLIES 7
Message 2 of 8
"20130326.1301"
What I need is:
+01 minuts
The (substr) function is the key function for something like this.  You can get the day/hour/minute parts from there [i.e. remove the year and month parts] with it:
(setq DHM (substr (rtos (getvar 'cdate) 2 4) 7))
Then you can multiply the pieces [converted to integers] by the appropriate numbers, and add them up:
(setq TotalMinutesSoFarThisMonth
    (* (atoi (substr DHM 1 2)) 1440); days
    (* (atoi (substr DHM 4 2)) 24); hours
    (atoi (substr DHM 6)); minutes
); setq
Kent Cooper, AIA
Message 3 of 8
Kent1Cooper
in reply to: Kent1Cooper
); setq
Come to think of it, you could skip the middleman of truncating CDATE to just day/hour/minute parts, and simply change the starting-character-position numbers in the substring functions in the add-it-up variable:
(setq
  datestring (rtos (getvar 'cdate) 2 4)
      (* (atoi (substr datestring 7 2)) 1440); days
      (* (atoi (substr datestring 10 2)) 24); hours
      (atoi (substr datestring 12)); minutes
    ); + & TotalMinutesSoFarThisMonth
); setq
Kent Cooper, AIA
Message 4 of 8
Thanks Kent, This issue is resolved with your help
I want to create a lisp to save my project periodically, associate to some commands. In the case with the command move.
Now the problem (one of) is when the file not yet saved, and the command qsave create a file in My Documents.
	(defun c:copysave(/ select frase DHM timetosavestring frase saveorno)
	(if (= timetosave nil) (setq timetosave 1));;I set the interval to save
	(if
	(= oldtime nil)
	(progn
	(setq oldtime ;; get the initial time
	(* (atoi (substr DHM 4 2)) 60); hours
	(setq DHM (substr (rtos (getvar 'cdate) 2 4) 7));;Get the actual time
	(setq atualtime
	(if
	(> oldtime atualtime);; solves the problem of the last day of the month and the first of the following month
	(progn
	(setq oldtime
	(setq deltime (- atualtime oldtime));;; verify the time variation
	(cond
	(< deltime timetosave);;; if the time is less than thr timesave only use the copy
	(setq select (ssget))
	(command "._copy" select "")
	(>= deltime timetosave);;; if the time is greater than the interval to save
	(initget "S N Y I" 0)
	(setq timetosavestring(rtos timetosave))
	(setq frase (strcat "\nHora de salvar o projeto? [Sim/Não/Intervalo= "timetosavestring" min]<Sim>"));;; save the project or no, and define the interval
	(setq saveorno(getkword frase))
		(cond
		(or (= saveorno "S")(= saveorno "Y")(= saveorno nil));;If the save is Yes
		((setq oldtime atualtime)(command "._qsave")(setq select (ssget))(command "._copy" select ""));;reset the oldtime anda save the project
			(= saveorno "N");;; Not save
			(setq oldtime atualtime);;reset the time
		(= saveorno "I");;set the interval
		(initget 7)
		(setq timetosave(getreal "\nIntervalo para salvamento: "));;;Get the interval
		(c:copysave);;restart the command
		);;end of conditions in save
	);;end of save
	);;end of save or no
	);;end of lisp
 How to solve this?
Sorry my english
Message 5 of 8
pbejse
in reply to: Gustavo_Bernardi
look into DWGTITLED system variable
If value is 0 , its either you are prompted for a drawing name and path or terminate the command and flash an alert box.
Message 6 of 8
Now that I see what you're doing with it, I have a suggestion for a simpler way to do the same thing, which can shrink your routine considerably.
The DATE System Variable is stored in decimal days, which means it is always numerically increasing, and no portion of it shifts from 28 or 29 or 30 or 31 back to 1 at the month turnover, or from 59 back to 00 at the hour turnover, etc.  So if you use DATE values, you can get a direct comparison without having to convert to total minutes so far this month.
(if (not timetosave) (setq timetosave 1.0));; set the interval to save [see comments below about the 1.0]
(if (not oldtime) (setq oldtime (getvar 'date)))
(setq atualtime (getvar 'date))
There would be no need to compare oldtime to atualtime and possibly reset oldtime because of a month turnover, because atualtime will always be greater than oldtime, no matter what.
Then, with timtosave being a real number in minutes, you can calculate the decimal fraction of a day that it represents very simply:
(cond
    (< deltime (/ timetosave 24 60));;; if the time is less than the timesave only use the copy
  ); end less-than condition
    (>= deltime (/ timetosave 24 60));;; if the time is greater than the interval to save
You already have timetosave being a real number where it's asked for with a prompt, because it's in a (getreal) function, and to correspond with that, I changed the default at the beginning from 1 to 1.0.  It has to be a real [decimal] number, not an integer, or the division with 24 and 60 as integers will always result in an integer, which won't give you the comparison you need.  [You could also use (getint) to ask for timetosave, keep the default at 1 as an integer, and change either the 24 to 24.0 or the 60 to 60.0 (or both) in the division.  But leaving it as a real number means someone could choose a timetosave value of 2.5 minutes, which wouldn't be possible if it needed to be an integer.]
Kent Cooper, AIA
Message 7 of 8
So much better ... What I was doing is what we named here in Brazil as "gambiarra" (check on google about)
Thank you guys...
Now I need only elect to associate commands. Initially I will use with the commands: LAYISO and LAYON
I chose to use real and not integer.
Below is the routine I think everything is OK:
(defun c:layisosave(/ select frase DHM timetosavestring frase saveorno)
(if (not timetosave) (setq timetosave 15.0))
(cond
(< deltime (/ timetosave 24.0 60.0))
(command "._layiso")
(>= deltime (/ timetosave 24.0 60.0))
(setq frase (strcat "\nHora de salvar o desenho? [Sim/Não/Intervalo= "timetosavestring " min]<Sim>"))
(cond
(if
(= 0 (getvar "DWGTITLED"))(alert
     "Você ainda não salvou seu arquivo?
Fique calmo...Você pode salvar com o atalho CTRL+S.
Você pode mudar o intervalo de alerta com o comando TIMETOSAVE
(command "_.qsave")
(command "._layiso" select "")
(= saveorno "N")
(= saveorno "I")
(initget 7)
(c:layisosave)
(defun c:timetosave()
Message 8 of 8
That looks good [within the limitation on my part that you know at least one more language than I do], though I have two small comments:
You can, if you like, use 24 and 60 as integers in the divisions, as long as the timetosave variable is a real number.  If any number in a division is a real number, the result will be, too -- they do not all need to be real numbers.
And you can simplify your first (cond)ition a little bit.  This part:
  (cond
can be done this way:
  (cond
      (member saveorno '("S" "Y" nil))
Any time I see multiple instances of the same thing [in this case, (= saveorno ...) three times over], I look for a different [i.e. shorter] way to do the same thing.
Kent Cooper, AIA
”Boost
