Visual LISP, AutoLISP and General Customization
convert String to real?
9 REPLIES 9
Message 1 of 10
1831 Views, 9 Replies
Hi, What Vlisp command would convert String to real? (defun c:AOF () (SETQ GL (ENTGET (ENTLAST))) (SETQ GT (CDR (ASSOC 1 A))) (setq GA (* 0.0001 GT)) (print GA) (print) ) error: bad argument type: consp "1998289.8296"
9 REPLIES 9
Message 2 of 10
ATOF "Virgis" wrote in message news:410f8fae$1_3@newsprd01... > Hi, > What Vlisp command would convert String to real? > > > > (defun c:AOF () > (SETQ GL (ENTGET (ENTLAST))) > (SETQ GT (CDR (ASSOC 1 A))) > (setq GA (* 0.0001 GT)) > (print GA) > (print) > ) > > error: bad argument type: consp "1998289.8296" > >
Message 3 of 10
Hi Virgis 'atof' like Alan says. To prevent unexpected errors, I would propose this function: (defun MeAtof (Val) (if (not (wcmatch Val "*[~0-9.-]*")) (atof Val)) ) I've seen, that you plan to read a text string. Probably this string can contain characters also. In this case 'atof' returns 0, 'MeAtof' returns nil. Following this, your function may work like this: ... (if (setq RetVal (MeAtof GT)) (setq GA (* 0.0001 RetVal)) (setq GA "Text is not nummeric.") ) (print GA) Cheers -- Juerg Menzi MENZI ENGINEERING GmbH, Switzerland http://www.menziengineering.ch
Message 4 of 10
Thanks it works! (defun c:AOF () (SETQ A (ENTGET (ENTLAST))) (SETQ AA (CDR (ASSOC 1 A))) (SETQ B (ATOF AA)) (setq BB (* 0.0001 B)) (COMMAND "TEXT" PAUSE "" BB) ) But is still one problem I become such result 187.7116600000000 I need this one: 187.71 Virgis
Message 5 of 10
(COMMAND "TEXT" PAUSE "" (rtos BB 2 2)) "Virgis" wrote in message news:410fad69_3@newsprd01... > Thanks it works! > > (defun c:AOF () > (SETQ A (ENTGET (ENTLAST))) > (SETQ AA (CDR (ASSOC 1 A))) > (SETQ B (ATOF AA)) > (setq BB (* 0.0001 B)) > (COMMAND "TEXT" PAUSE "" BB) > ) > > But is still one problem > I become such result > > 187.7116600000000 > > I need this one: > > 187.71 > > Virgis > >
Message 6 of 10
This is good one :) (defun c:TU () (SETQ SS (CAR (ENTSEL))) (SETQ A (ENTGET SS)) (SETQ AA (CDR (ASSOC 1 A))) (SETQ B (ATOF AA)) (setq BB (* 0.0001 B)) (setq C (RTOS BB 2 2)) (SETQ CC (vl-string-right-trim "0" C)) (COMMAND "TEXT" "J" "BR" PAUSE "0" CC) ) "Jim Claypool" wrote in message news:410fb9be_3@newsprd01... > (COMMAND "TEXT" PAUSE "" (rtos BB 2 2)) > > "Virgis" wrote in message news:410fad69_3@newsprd01... > > Thanks it works! > > > > (defun c:AOF () > > (SETQ A (ENTGET (ENTLAST))) > > (SETQ AA (CDR (ASSOC 1 A))) > > (SETQ B (ATOF AA)) > > (setq BB (* 0.0001 B)) > > (COMMAND "TEXT" PAUSE "" BB) > > ) > > > > But is still one problem > > I become such result > > > > 187.7116600000000 > > > > I need this one: > > > > 187.71 > > > > Virgis > > > > > >
Message 7 of 10
If you trim the trailing 0's and your value is 187.00 you will have "187." Is this really what you want? You might want to trim the decimal point too. (SETQ CC (vl-string-trim "." (vl-string-right-trim "0" C))) "Virgis" wrote in message news:410fc03b_2@newsprd01... > This is good one :) > > > (defun c:TU () > (SETQ SS (CAR (ENTSEL))) > (SETQ A (ENTGET SS)) > (SETQ AA (CDR (ASSOC 1 A))) > (SETQ B (ATOF AA)) > (setq BB (* 0.0001 B)) > (setq C (RTOS BB 2 2)) > (SETQ CC (vl-string-right-trim "0" C)) > (COMMAND "TEXT" "J" "BR" PAUSE "0" CC) > ) > > > > > "Jim Claypool" wrote in message > news:410fb9be_3@newsprd01... > > (COMMAND "TEXT" PAUSE "" (rtos BB 2 2)) > > > > "Virgis" wrote in message news:410fad69_3@newsprd01... > > > Thanks it works! > > > > > > (defun c:AOF () > > > (SETQ A (ENTGET (ENTLAST))) > > > (SETQ AA (CDR (ASSOC 1 A))) > > > (SETQ B (ATOF AA)) > > > (setq BB (* 0.0001 B)) > > > (COMMAND "TEXT" PAUSE "" BB) > > > ) > > > > > > But is still one problem > > > I become such result > > > > > > 187.7116600000000 > > > > > > I need this one: > > > > > > 187.71 > > > > > > Virgis > > > > > > > > > > > >
Message 8 of 10
Actually I want to have the result 187.00 and now I have 187 Maybe You know how? ----- Original Message ----- From: "Jim Claypool" Newsgroups: autodesk.autocad.customization Sent: Tuesday, August 03, 2004 8:41 PM Subject: Re: convert String to real? > If you trim the trailing 0's and your value is 187.00 you will have "187." > Is this really what you want? You might want to trim the decimal point too. > > (SETQ CC (vl-string-trim "." (vl-string-right-trim "0" C))) > > > "Virgis" wrote in message news:410fc03b_2@newsprd01... > > This is good one :) > > > > > > (defun c:TU () > > (SETQ SS (CAR (ENTSEL))) > > (SETQ A (ENTGET SS)) > > (SETQ AA (CDR (ASSOC 1 A))) > > (SETQ B (ATOF AA)) > > (setq BB (* 0.0001 B)) > > (setq C (RTOS BB 2 2)) > > (SETQ CC (vl-string-right-trim "0" C)) > > (COMMAND "TEXT" "J" "BR" PAUSE "0" CC) > > ) > > > > > > > > > > "Jim Claypool" wrote in message > > news:410fb9be_3@newsprd01... > > > (COMMAND "TEXT" PAUSE "" (rtos BB 2 2)) > > > > > > "Virgis" wrote in message news:410fad69_3@newsprd01... > > > > Thanks it works! > > > > > > > > (defun c:AOF () > > > > (SETQ A (ENTGET (ENTLAST))) > > > > (SETQ AA (CDR (ASSOC 1 A))) > > > > (SETQ B (ATOF AA)) > > > > (setq BB (* 0.0001 B)) > > > > (COMMAND "TEXT" PAUSE "" BB) > > > > ) > > > > > > > > But is still one problem > > > > I become such result > > > > > > > > 187.7116600000000 > > > > > > > > I need this one: > > > > > > > > 187.71 > > > > > > > > Virgis > > > > > > > > > > > > > > > > > > > >
Message 9 of 10
Command: (rtos (atof "187") 2 2) "187.00" "Virgis" wrote in message news:411087e8_3@newsprd01... > Actually I want to have the result 187.00 > and now I have 187 > Maybe You know how? > >
Message 10 of 10
(defun c:TU () (SETQ SS (CAR (ENTSEL))) (SETQ A (ENTGET SS)) (SETQ AA (CDR (ASSOC 1 A))) (SETQ B (ATOF AA)) (setq BB (* 0.0001 B)) (setq C (RTOS BB 2 2)) ;; (SETQ CC (vl-string-right-trim "0" C)) ;; REMOVE THIS LINE (COMMAND "TEXT" "J" "BR" PAUSE "0" C) ;; CHANGE CC to C ) "Virgis" wrote in message news:411087e8_3@newsprd01... > Actually I want to have the result 187.00 > and now I have 187 > Maybe You know how? > > > > > ----- Original Message ----- > From: "Jim Claypool" > Newsgroups: autodesk.autocad.customization > Sent: Tuesday, August 03, 2004 8:41 PM > Subject: Re: convert String to real? > > > > If you trim the trailing 0's and your value is 187.00 you will have "187." > > Is this really what you want? You might want to trim the decimal point > too. > > > > (SETQ CC (vl-string-trim "." (vl-string-right-trim "0" C))) > > > > > > "Virgis" wrote in message news:410fc03b_2@newsprd01... > > > This is good one :) > > > > > > > > > (defun c:TU () > > > (SETQ SS (CAR (ENTSEL))) > > > (SETQ A (ENTGET SS)) > > > (SETQ AA (CDR (ASSOC 1 A))) > > > (SETQ B (ATOF AA)) > > > (setq BB (* 0.0001 B)) > > > (setq C (RTOS BB 2 2)) > > > (SETQ CC (vl-string-right-trim "0" C)) > > > (COMMAND "TEXT" "J" "BR" PAUSE "0" CC) > > > ) > > > > > > > > > > > > > > > "Jim Claypool" wrote in message > > > news:410fb9be_3@newsprd01... > > > > (COMMAND "TEXT" PAUSE "" (rtos BB 2 2)) > > > > > > > > "Virgis" wrote in message news:410fad69_3@newsprd01... > > > > > Thanks it works! > > > > > > > > > > (defun c:AOF () > > > > > (SETQ A (ENTGET (ENTLAST))) > > > > > (SETQ AA (CDR (ASSOC 1 A))) > > > > > (SETQ B (ATOF AA)) > > > > > (setq BB (* 0.0001 B)) > > > > > (COMMAND "TEXT" PAUSE "" BB) > > > > > ) > > > > > > > > > > But is still one problem > > > > > I become such result > > > > > > > > > > 187.7116600000000 > > > > > > > > > > I need this one: > > > > > > > > > > 187.71 > > > > > > > > > > Virgis > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
”Boost
