I don't think that I ever published any of my matrix code in the newsgroup.
I was working on an article for the site and never finished it.
The first four support routines were posted here long ago by Vladimir,
although the original origin was questioned at the time of the posting.
The next three create some of the more common transformation matrices,
scaling, moving, and rotating about the Z axis. The next routine combines
these individual matrices into a matrix that will perform multiple
transformations, in the event that you wanted to do something crazy like
rotate and scale your grvecs at the same time.
;;; Thanks to Vladimir Nesterovsky
;;;a dot product of the two vectors, u & v
(defun dotprod (u v)
(apply '+ (mapcar '* u v))
;;;transpose a matrix
;;;code by doug Wilson
(defun transpose (m)
(apply 'mapcar (cons 'list m))
;;;Apply a transformation matrix to a vector
(defun mxv (m v)
(mapcar '(lambda (row) (dotprod row v))
m
;;;Multiply two matrices
(defun mxm (m q)
(setq q (transpose q))
(mapcar '(lambda (row) (mxv q row))
m
;;;Create Scale matrix
;;;We add error handling to this matrix to
;;;ensure that we never have a zero scale factor.
;;;It accepts a single scale factor for the
;;;X, Y, & Z or a list of factors in the order
;;;of '(X Y Z).
;;;(CreateScaleMatrix 3.5)
;;;(CreateScaleMatrix '(3 2 1))
(defun CreateScaleMatrix (scale / scaleX scaleY scaleZ)
(mapcar
'(lambda (variableName scaleFactor)
(if (zerop scaleFactor)
(set variableName 1)
(set variableName scaleFactor)
'(scaleX scaleY scaleZ)
(if (listp scale)
scale
(list scale scale scale)
(list (list scaleX 0 0 0)
(list 0 scaleY 0 0)
(list 0 0 scaleZ 0)
(list 0 0 0 1)
;;;Rotate about Z axis
;;;Rotation to be supplied in radians
;;;(CreateRotationAroundZaxisMatrix (* pi 3.33))
(defun CreateRotationAroundZaxisMatrix (Rot)
(list (list (cos Rot) (- (sin Rot)) 0 0)
(list (sin Rot) (cos Rot) 0 0)
(list 0 0 1 0)
(list 0 0 0 1)
;;;Translate Matrix, or movement
;;;Vector is a list of values
;;;in the order of '(X Y Z) to
;;;define the movement path
;;;(CreateTranslateMatrix '(3 4 0))
(defun CreateTranslateMatrix (Vector)
(list (list 1 0 0 (car Vector))
(list 0 1 0 (cadr Vector))
(list 0 0 1 (caddr Vector))
(list 0 0 0 1)
;;;Combines multiple Matrices into a single matrix
;;;(BuildTransformationMatrix (list (CreateScaleMatrix 2)
(CreateTranslateMatrix '(2 2 0))))
(defun BuildTransformationMatrix (matrices / TformMatrix)
(foreach matrix matrices
(setq TformMatrix
(if TformMatrix
(mxm TformMatrix matrix)
matrix
Bobby C. Jones
http://www.acadx.com
"Joe Burke" wrote in message
news:4945330@discussion.autodesk.com...
Bobby,
Thanks for the code.
How about a peek at the CreateScaleMatrix function. Not found, as far as I
can tell,
google searching this NG.
Joe Burke
"Bobby C. Jones" wrote in message
news:4945209@discussion.autodesk.com...
My lisp is a bit rusty, but here is one out of the archives.
;;;Draw closed shape with GRVECS
;;;(setq white 7
;;; doubleTheSize (CreateScaleMatrix 2))
;;;(GrDrawClosedShape '((1 1) (2 1) (2 2) (1 2)) white doubleTheSize)
(defun GrDrawClosedShape (pointList color matrix)
(grvecs
(append
(list color)
(cdr
(apply
'append
(mapcar
'(lambda (pt)
(list pt pt)
ptlst
(list (car pointList))
matrix
Bobby C. Jones
wrote in message news:4944937@discussion.autodesk.com...
R2005:
I know this will be easy for you Gurus, but I've searched and have not found
anything I can use in the archives.
I have a list of points from a polyline. I want to feed these points to
grvecs. As we all know, the points need to be in the form of (list p1 p2 p2
p3 p3 p4 p4 p5) etc.
What's a way to convert my point ilst into this format?
((230.915 -5.04606) (237.383 -9.125) (240.383 -10.8125) (243.383 -12.5)
(246.383 -14.0625) (249.383 -15.5) (252.383 -16.8125) (255.383 -18.0)
(258.383
-19.0937))
TIA
Bill
