Visual LISP, AutoLISP and General Customization
Convert Field to Text
27 REPLIES 27
Message 1 of 28
6545 Views, 27 Replies
What is the Command that Converts a Field to Text so that I can stop a Field
updating after the initial set-up?
I need to apply this in lisp.
TIA
Jim
27 REPLIES 27
Message 21 of 28
twlincoln2009
in reply to: Ian_Bryant
This is an old post, so I hope Ian (or someone else can help) I am looking to remove FIELD definitions from MTEXT within a TABLE... similar to the code listed above (as all the above works with DIMS, TEXT, MTEXT, ATTRIBUTES, but not TABLES. 😞
Thanks in advance. - Tracy Lincoln (yes, the one and only)
Message 22 of 28
Ian_Bryant
in reply to: twlincoln2009
not well tested,
and will not change tables on locked layers,
or change locked table cells.
Create a selection set of the table entities
and step through it applying the following function
to each ename in the set.
(defun do_table (ent / obj nr nc nc1 nr1 vv tstring)
 (setq obj (vlax-ename->vla-object ent)
       nr (vlax-get obj 'Rows)
       nc (vlax-get obj 'Columns)
 (setq nr1 0)
 (while (< nr1 nr)
   (setq nc1 0)
   (while (< nc1 nc)
     (if (and
            (= (vla-GetCellType obj nr1 nc1) 1)
            (setq tstring (vla-gettext obj nr1 nc1))
         (progn
          (vl-catch-all-apply 'vla-deletecellcontent
                 (list obj nr1 nc1)
          (setq vv (vla-getcellvalue obj nr1 nc1))
          (vl-catch-all-apply 'vla-SetTextString
                 (list obj nr1 nc1 vv tstring)
     (setq nc1 (+ 1 nc1))
   (setq nr1 (+ 1 nr1))
 (princ)
Ian
Message 23 of 28
twlincoln2009
Thank you for the code, but I cannot seem to get it to work after I load it?
Message 24 of 28
robert06
@Ian_Bryant wrote:
You also need to change
(setq ss1
(ssget "X"
(list (cons 0 "INSERT")
(cons 67 1)
(cons 66 1)
to
(setq ss1
(ssget "X"
(cons 67 0)
(cons 66 1)
Regards Ian
The code works great.
How to narrow the selection set to Fields with certain expression, %<\AcVar SaveDate \f "dd.MM.yyyy">% for instance?
Thank you
Robert
Message 25 of 28
arc.tu.nd
Thank you for code helpful.
Spoiler
Message 26 of 28
F.Camargo
@Ian_Bryant wrote:
you could try the attached lsp.
It coverts all fields in modelspace
text, mtext, mleaders and block attributes.
It does not convert text within
a block, or anything in a nested block.
Regards Ian
Very interesting code!
I was looking for a code to converts all fields in layout space into MText.
In my drawing have 2 Mtext as a Field by layout.
Some drawing have about 50 layout space.
Thanks in advance
Fabricio
Message 27 of 28
F.Camargo
in reply to: F.Camargo
I've already get the answer.
http://forums.augi.com/showthread.php?162398-Converting-All-Fields-To-text
Fabricio
Message 28 of 28
alexrichterdgr
Hi - Could you tell me how to alter this code to accommodate multiline attributes?  Thanks!
(defun C:R-FIELDS-ALL ( / del-field ss1 index item)
(vl-load-com)
(defun del-field (ent / edic elist etype obj val)
(if
(and
(setq edic (cdr (assoc 360 (setq elist (entget ent)))))
(dictsearch edic "ACAD_FIELD")
(progn
etype (cdr (assoc 0 elist))
(cond
((= etype "DIMENSION")
(setq val (vla-get-textoverride obj))
(dictremove edic "ACAD_FIELD")
(vla-put-textoverride obj val)
((= etype "MTEXT")
(setq val (vla-get-textstring obj))
(vla-put-textstring obj val)
(T (dictremove edic "ACAD_FIELD"))
(if
(setq ss1
(ssget "X" '((0 . "TEXT,MTEXT,MULTILEADER,DIMENSION")))
(progn
(setq index 0)
(repeat (sslength ss1)
(setq item (ssname ss1 index))
(if (del-field item) (entupd item))
(setq index (+ 1 index))
(if
(setq ss1
(ssget "X" '((0 . "INSERT")))
(progn
(setq index 0)
(while (= (cdr (assoc 0 (entget (setq item (entnext item))))) "ATTRIB")
(princ)
”Boost
