Good Morning Everyone,
Below I've posted a great routine by Jeff Mishler that converts all text in a file to "Standard". I've used it many times and it works great but I do have a question regarding how it might be modified to convert All text EXCEPT for Helv.
My thinking is to add a not equal to paren grouping to the Wcmatch "TEXT" line, but have yet to get it to successfully work.
Any help in the right direction would be much appreciated.
Coyote
;;Change all text, mtext, dimension text, attribute text to the
;;"STANDARD" text style. Preserves all existing text heights &
;;obliquing angles.
;; by Jeff Mishler
(defun c:txt2std (/ styl ss ent count doc blks lokt)
(vl-load-com)
(vla-startundomark (setq doc (vla-get-activedocument
(vlax-get-acad-object)
(vlax-for lay (vla-get-layers doc)
(if (= (vla-get-lock lay) :vlax-true)
(progn
(setq lokt (cons lay lokt))
(vla-put-lock lay :vlax-false)
(if (not (tblsearch "style" "STANDARD"))
(progn
(setq styl (vla-add
(vla-get-textstyles doc)
"STANDARD")
(vla-put-fontfile styl "txt.shx")
(if (setq ss (ssget "x" '((0 . "*TEXT,*DIM*,INSERT"))))
(progn
(setq count -1)
(while (< (setq count (1+ count)) (sslength ss))
(setq ent (vlax-ename->vla-object (ssname ss count)))
(cond ((wcmatch (strcase (vla-get-objectname ent)) "*TEXT*")
(vla-put-stylename ent "STANDARD"))
((wcmatch (strcase (vla-get-objectname ent)) "*BLOCK*")
(progn
(if (= (vla-get-hasattributes ent) :vlax-true)
(progn
(setq atts (vlax-safearray->list
(vlax-variant-value
(vla-getattributes ent))))
(foreach x atts
(vla-put-stylename x "STANDARD")
(t (vla-put-textstyle ent "STANDARD"))
(if (< 0 (vla-get-count (setq blks (vla-get-blocks doc))))
(progn
(vlax-for blk blks
(vlax-for ent blk
(if (vlax-property-available-p ent 'stylename)
(if lokt
(progn
(foreach lay lokt
(vla-put-lock lay :vlax-true)
(vla-endundomark doc)
(princ)
