Visual LISP, AutoLISP and General Customization
*Subotic, Jasmina
Post 1 of 14
convert 3d to 2d polylines with same coordinates
198 Views, 13 Replies
10-03-1999 01:52 PM
Could someone help me?
I use Auto CAD R14.I have a file drawing (input was dxf file), with lots of
3D polylines, with same X coordinates at each vertex. I need to put them
into 2D polylines with same coordinates. I have a process, but it´s very
slow. I EXPLODE all the 3dpoly. Then, I have to PEDIT all the lines one by
one to transform them into 2D polylines. Are there a process or a lisp that
transform 3Dpoly (with one same coordinate) into 2Dpoly?
If there are, tell me, please.
Thank you in advance.
Jasmina
P.S. Sorry for bad English
*Vehabovic, Ibro
Post 2 of 14
Re: convert 3d to 2d polylines with same coordinates
10-03-1999 07:03 PM in reply to: *Subotic, Jasmina
Jasmina,
This code +ACI-flats+ACI- selected 3DPolylines, e.g. changes
Z-coordinates of all vertices to zero. If you need X-coords
to be zero just move up 2 semicolons (+ADs-) 2 lines.
Anyway, let me know how it works.
(defun c:3DPoly-flat ( / ss i e eg)
(cond
((setq ss (ssget '((0 . +ACI-polyline+ACI-)(-4 . +ACIAJgA9ACI-)(70 . 8))))
(setq i -1)
(repeat (sslength ss)
(setq e (ssname ss (setq i (1+- i))))
(while (eq (cdr (assoc 0 (setq eg (entget (setq e (entnext
e)))))) +ACI-VERTEX+ACI-)
(entmod (append eg (list (cons 10 (list (car (cdr (assoc 10
eg))) +ADs-Z+AD0-0
(cadr (cdr (assoc 10
eg))) 0.0)))))
+ADs- (entmod (append eg (list (cons 10 (list 0.0 (cadr (cdr
(assoc 10 eg))) +ADs-X+AD0-0
+ADs- (caddr (cdr (assoc 10
eg))))))))
)+ADs-while
)+ADs-repeat
)+ADs-ss
(t (princ +ACIAXA-nNo 3DPolylines selected.+ACI-))
)+ADs-cond
(princ)
Best Regards,
Ibro Vehabovic
ibrov+AEA-flash.net
Jasmina Subotic wrote in message +ADw-7t8g00+ACQ-nac4+AEA-adesknews2.autodesk.com+AD4-...
+AD4-Could someone help me?
+AD4-I use Auto CAD R14.I have a file drawing (input was dxf file), with lots of
+AD4-3D polylines, with same X coordinates at each vertex. I need to put them
+AD4-into 2D polylines with same coordinates. I have a process, but it+ALQ-s very
+AD4-slow. I EXPLODE all the 3dpoly. Then, I have to PEDIT all the lines one by
+AD4-one to transform them into 2D polylines. Are there a process or a lisp that
+AD4-transform 3Dpoly (with one same coordinate) into 2Dpoly?
+AD4-If there are, tell me, please.
+AD4-
+AD4-Thank you in advance.
+AD4- Jasmina
+AD4-P.S. Sorry for bad English
+AD4-
+AD4-
+AD4-
+AD4-
+AD4-
+AD4-
*Nesterovsky, Vladimir
Post 3 of 14
10-03-1999 08:28 PM in reply to: *Subotic, Jasmina
You would assume big CAD system like ACAD
should have some conversion routines
of this sort built in, but it doesn't.
After all, you're having a planar POLYLINE
here, no matter it's described as 3DPOLY,
right? :-)
May be it's possible to cast a 3dpoly into a 2d
with ARX, I don't know.
But the only option AFAIK is to write
a LISP code:
(defun c:x2d() ; put locals there... :smileyhappy:)
(setq e (car (entsel))
ds (edlgetsubent e)
d1 (car ds)
vs (cdr ds)
f (cdr(assoc 70 d1))
p0 (get 10 (car vs))
n '(1 0 0)
q0 (trans p0 e n)
z (last q0)
(entmake
(append
(list
'(0 . "LWPOLYLINE") '(100 . "AcDbEntity")
(assoc 8 d1)
'(100 . "AcDbPolyline")
(cons 90 (length vs))
(cons 70 (logand 129 f))
(cons 38 z)
(if (assoc 48 d1) (list (assoc 48 d1)))
(mapcar '(lambda(d / p q)
(setq p (cdr(assoc 10 d))
q (trans p e n))
(list 10 (car q) (cadr q))) vs)
(list (cons 210 n))
(entdel e)
(princ))
I'm _assuming_ all your points here have
equal X coordinates.
If anyone would like to contribute more here,
make it automatically find the plane PLINE
is in, and use 'N accordingly. :smileyhappy:
A tip (for a few here who need it): it's
easy to find all points of the original
pline with
(setq ps (mapcar
'(lambda(d)(cdr(assoc 10 d))) vs))
Tricky part would be to find if they all belong
to some plane, and to find that plane's normal
vector, then to use it as 'N in the code above. :-)
Tested, :-)
(defun edlgetsubent(en / d dl )
"all ents data, w/out SEQEND"
(setq d (entget en) dl (list d))
(if (= 1 (cdr(assoc 66 d)))
(while (/= "SEQEND"
(cdr(assoc 0 (setq d(entget
(setq en (entnext en)))))))
(setq dl (cons d dl))))
(reverse dl)
On Sun, 3 Oct 1999 22:52:40 +0200, "Jasmina Subotic"
Vlad http://www.netvision.net.il/php/vnestr/
Splines can be converted into tangential arcs
with arbitrary precision. :-)
*Subotic, Jasmina
Post 4 of 14
Re:
10-04-1999 02:14 PM in reply to: *Subotic, Jasmina
Hello!
Yes, you was perfectly right...but I don't know how to use your code. I
don't understand: "put lockals there...". I didn't put anything. I just
tried your code. But nothing was happen. See what was in AutoCAD Text Window
(I can't select object?):
Command: x2d
Select object: error: null function
(EDLGETSUBENT E)
(SETQ E (CAR (ENTSEL)) DS (EDLGETSUBENT E) D1 (CAR DS) VS (CDR DS) F (CDR
(ASSOC 70 D1)) P0 (GET 10 (CAR VS)) N (QUOTE (1 0 0)) Q0 (TRANS P0 E N) Z
(LAST
Q0))
(C:X2D)
*Cancel*
Best Regards,
Jasmina
Vladimir Nesterovsky wrote in message
news:37fb1ce8.58689936@adesknews.autodesk.com...
> right? :-)
> a LISP code:
> ds (edlgetsubent e)
> d1 (car ds)
> vs (cdr ds)
> n '(1 0 0)
> q0 (trans p0 e n)
> z (last q0)
> (entmake
> (append
> (list
> (assoc 8 d1)
> (cons 38 z)
> q (trans p e n))
> (list (cons 210 n))
> (entdel e)
> (princ))
Post 5 of 14
Re:
10-04-1999 06:53 PM in reply to: *Subotic, Jasmina
You missed this function from
my previous post:
(while (/= "SEQEND"
(reverse dl)
You need to load it too, then use X2D command.
You can ignore the "Put locals there" remark. :-)
On Mon, 4 Oct 1999 23:14:17 +0200, "Jasmina Subotic"
wrote:
>Hello!
>Command: x2d
>(EDLGETSUBENT E)
*Vehabovic, Ibro
Post 6 of 14
Re:
10-05-1999 09:07 AM in reply to: *Subotic, Jasmina
Vladimir,
I have just refreshed my "analytical geometry" and look at
what I did. Maybe it is not perfect but it works.
;returns nil if all points do not belong to the same plane
;otherwise returns normal vector of the plane
(defun pts-in-plane ( pts / fuzz x a b c tmp)
(setq fuzz 0.00001)
(command "_.UCS" "_3" (car pts) (cadr pts) (caddr pts)) ;sets UCS through
first 3 points
;should be checked
if points are colinear
(setq x (getvar "UCSXDIR") y (getvar "UCSYDIR")
a (- (* (cadr x) (caddr y)) (* (caddr x) (cadr y))) ;calcs X value
of normal vector
b (- (* (caddr x) (car y)) (* (car x) (caddr y))) ;calcs Y value
of normal vector
c (- (* (car x) (cadr y)) (* (cadr x) (car y))) ;calcs Z value
of normal vector
);setq
(command "_.UCS" "_P")
(foreach x pts
(if (null (equal (+ (* a (- (car x) (car (car pts))))
(* b (- (cadr x) (cadr (car pts))))
(* c (- (caddr x) (caddr (car pts))))) 0.0 fuzz))
(setq tmp T)
);if
);foreach
(if tmp nil (list a b c))
);defun (pts-in-plane)
Here is your modified routine:
;by Vladimir Nesterovsky
(defun c:x2d ( / e ds d1 vs f p0 pts n q0 z p q)
ds (edlgetsubent e)
d1 (car ds)
vs (cdr ds)
; p0 (get 10 (car vs))
p0 (cdr (assoc 10 (car vs)))
pts (mapcar '(lambda (d) (cdr (assoc 10 d))) vs)
n (pts-in-plane pts)
; if n=nil 3DPoly does not lay in one plane ...
q0 (trans p0 e n)
z (last q0)
);setq
(entmake
(append
(list
(assoc 8 d1)
(cons 38 z)
q (trans p e n))
(list (cons 210 n))
(entdel e)
(princ))
(defun edlgetsubent(en / d dl ) ;"all ents data, w/out SEQEND"
(while (/= "SEQEND"
(cdr(assoc 0 (setq d (entget
(reverse dl)
Ibro Vehabovic
ibrov@flash.net
> right? :-)
> a LISP code:
> ds (edlgetsubent e)
> d1 (car ds)
> vs (cdr ds)
> n '(1 0 0)
> q0 (trans p0 e n)
> z (last q0)
> (entmake
> (append
> (list
> (assoc 8 d1)
> (cons 38 z)
> q (trans p e n))
> (list (cons 210 n))
> (entdel e)
> (princ))
> pline with
> (setq ps (mapcar
> Tested, :-)
> (while (/= "SEQEND"
> (reverse dl)
of
by
that
*Togores, Reinaldo
Post 7 of 14
10-05-1999 01:25 PM in reply to: *Subotic, Jasmina
I have something writen about this in http://start.at/autolisp/ including
the case in which the 3d polyline is coplanar, but not parallell to the WCS
XY plane.
The paper is in spanish, but the code will work in any language version.
Reinaldo Togores
AutoCAD based CAD - GIS Training & Consulting
Spanish-English Software translation & localization
Jasmina Subotic escribió en el mensaje de noticias
7t8g00$nac4@adesknews2.autodesk.com...
of
that
> Jasmina
*Subotic, Jasmina
Post 8 of 14
Re:
10-05-1999 04:43 PM in reply to: *Subotic, Jasmina
Hello Vladimir!
Thanks! In the meantime Ibro send me your code with this function.He
knows how my knowledge is little and how my English is bad :smileyhappy: We speak the
same language. Code works just how I ask. But I thought that I can change
UCS, surprise...it works everything in World UCS. I have 3D polylines, with
same Y or Z coordinates at each vertex also...and 5% of planar POLYLINE
which is no parallel with to the WAS planes.Maybe Reinaldo's code could help
:smileyhappy: I start to learn Spanish :smileysad:
news:37fa5983.39994037@adesknews.autodesk.com...
> my previous post:
I can't ignore this Ibro put your name here :smileyhappy:
Best Regards,
Jasmina
Post 9 of 14
Re:
10-05-1999 05:13 PM in reply to: *Subotic, Jasmina
Hi Ibro,
Here, you've come to the rescue once again! Thanks!
I hope the code will work now as it should. :-)
Good luck,
On Tue, 5 Oct 1999 09:07:58 -0700, "Ibro Vehabovic"
wrote:
>Vladimir,
-== Let the Corman LISP be with you. ==-
*Schaefer, Bob
Post 10 of 14
10-09-1999 04:36 AM in reply to: *Subotic, Jasmina
mpedit
All
O(pen)
C(lose)
X(exit)
news:7t8g00$nac4@adesknews2.autodesk.com...
of
that
> Jasmina
Post to the Community
New Post
