Visual LISP, AutoLISP and General Customization
Construct string in LISP for hyperlink path with spaces
5 REPLIES 5
jlane
851 Views, 5 Replies
I'm writing a macro that will generate a new email and create a hyperlink in the email body.  The hyperlink will be to a new file located on a network drive.
I've had success creating the hyperlink by constructing the string this way:
"file:M:/Network_Folder/Subfolder/NewFile.pdf"
I prefixed the path string with "file:".  Great.
My problem now is with folder names that use a space instead of an underscore.  The hyperlink stops short as soon as it reaches the first space.
Besides renaming the folder name (not an option for us), is there any way around this in LISP?
Even better would be to simplifiy the text that is displayed for the hyperlink, i.e. just the file name rather than the full path.
Thanks.
5 REPLIES 5
paullimapa
in reply to: jlane
How about sorrounding it with another set of quotes:
\""file:///M:/Network_Folder/Subfolder/NewFile.pdf"\"
Paul Li
IT Specialist
@The Office
jlane
in reply to: jlane
Thanks for your reply Paul.
I tried your suggestion out, in a variety of combinations, but still no success.  Hyperlink always stops short once it reaches the first space in the path.
Any other ideas?
Thx!
paullimapa
in reply to: jlane
What if instead of a space you use %20 as referenced here: http://www.w3schools.com/tags/ref_urlencode.asp
Paul Li
IT Specialist
@The Office
jlane
in reply to: paullimapa
Perfect, that did it!
Thanks for digging up that link Paul.  Much appreciated.
paullimapa
in reply to: jlane
No problem...just glad that worked out for you...
Paul Li
IT Specialist
@The Office
”Boost
