Dear All
Is there any complete list of VL, VLA, VLAX functions along with their explanation and properties ?
The ActiveX & VBA Reference detailing almost every ActiveX Property & Method (i.e. the vla-* functions) may be found in the acadauto.chm compiled help file, which, in later versions of AutoCAD is located under C:\Program Files\Common Files\Autodesk Shared
Alternatively, an online version of this reference is available here (though, note that this is a Russian site, not an Autodesk publication).
I have also written a brief tutorial describing how to work with the ActiveX & VBA Reference from a Visual LISP perspective, which may be found here.
Lee
VL-ACAD-DEFUN VL-ACAD-UNDEFUN VL-ARX-IMPORT VL-BB-REF VL-BB-SET VL-BT VL-BT-OFF VL-BT-ON VL-CATCH-ALL-APPLY VL-CATCH-ALL-ERROR-MESSAGE VL-CATCH-ALL-ERROR-P VL-CMDF VL-CONSP VL-DIRECTORY-FILES VL-DOC-EXPORT VL-DOC-IMPORT VL-DOC-REF VL-DOC-SET VL-EVERY VL-EXIT-WITH-ERROR VL-EXIT-WITH-VALUE VL-FILE-COPY VL-FILE-DELETE VL-FILE-DIRECTORY-P VL-FILE-RENAME VL-FILE-SIZE VL-FILE-SYSTIME VL-FILENAME-BASE VL-FILENAME-DIRECTORY VL-FILENAME-EXTENSION VL-FILENAME-MKTEMP VL-GET-RESOURCE VL-INFP VL-INIT VL-LIST->STRING VL-LIST-EXPORTED-FUNCTIONS VL-LIST-LENGTH VL-LIST-LOADED-VLX VL-LIST* VL-LOAD-ALL VL-LOAD-COM VL-LOAD-REACTORS VL-MEMBER-IF VL-MEMBER-IF-NOT VL-MKDIR VL-NANP VL-POSITION VL-PRIN1-TO-STRING VL-PRINC-TO-STRING VL-PROPAGATE VL-REGISTRY-DELETE VL-REGISTRY-DESCENDENTS VL-REGISTRY-READ VL-REGISTRY-WRITE VL-REMOVE VL-REMOVE-IF VL-REMOVE-IF-NOT VL-SOME VL-SORT VL-SORT-I VL-STRING->LIST VL-STRING-ELT VL-STRING-LEFT-TRIM VL-STRING-MISMATCH VL-STRING-POSITION VL-STRING-RIGHT-TRIM VL-STRING-SEARCH VL-STRING-SUBST VL-STRING-TRANSLATE VL-STRING-TRIM VL-SYMBOL-NAME VL-SYMBOL-VALUE VL-SYMBOLP VL-UNLOAD-VLX VL-VBALOAD VL-VBARUN VL-VLX-LOADED-P VLA-ACTIVATE VLA-ADD VLA-ADD3DFACE VLA-ADD3DMESH VLA-ADD3DPOLY VLA-ADDARC VLA-ADDATTRIBUTE VLA-ADDBOX VLA-ADDCIRCLE VLA-ADDCONE VLA-ADDCUSTOMINFO VLA-ADDCUSTOMOBJECT VLA-ADDCYLINDER VLA-ADDDIM3POINTANGULAR VLA-ADDDIMALIGNED VLA-ADDDIMANGULAR VLA-ADDDIMARC VLA-ADDDIMDIAMETRIC VLA-ADDDIMORDINATE VLA-ADDDIMRADIAL VLA-ADDDIMRADIALLARGE VLA-ADDDIMROTATED VLA-ADDELLIPSE VLA-ADDELLIPTICALCONE VLA-ADDELLIPTICALCYLINDER VLA-ADDEXTRUDEDSOLID VLA-ADDEXTRUDEDSOLIDALONGPATH VLA-ADDFITPOINT VLA-ADDHATCH VLA-ADDITEMS VLA-ADDLEADER VLA-ADDLEADERLINE VLA-ADDLEADERLINEEX VLA-ADDLIGHTWEIGHTPOLYLINE VLA-ADDLINE VLA-ADDMENUITEM VLA-ADDMINSERTBLOCK VLA-ADDMLEADER VLA-ADDMLINE VLA-ADDMTEXT VLA-ADDOBJECT VLA-ADDPOINT VLA-ADDPOLYFACEMESH VLA-ADDPOLYLINE VLA-ADDPVIEWPORT VLA-ADDRASTER VLA-ADDRAY VLA-ADDREGION VLA-ADDREVOLVEDSOLID VLA-ADDSECTION VLA-ADDSEPARATOR VLA-ADDSHAPE VLA-ADDSOLID VLA-ADDSPHERE VLA-ADDSPLINE VLA-ADDSUBMENU VLA-ADDTABLE VLA-ADDTEXT VLA-ADDTOLERANCE VLA-ADDTOOLBARBUTTON VLA-ADDTORUS VLA-ADDTRACE VLA-ADDVERTEX VLA-ADDWEDGE VLA-ADDXLINE VLA-ADDXRECORD VLA-ANGLEFROMXAXIS VLA-ANGLETOREAL VLA-ANGLETOSTRING VLA-APPENDINNERLOOP VLA-APPENDITEMS VLA-APPENDOUTERLOOP VLA-APPENDVERTEX VLA-ARRAYPOLAR VLA-ARRAYRECTANGULAR VLA-ATTACHEXTERNALREFERENCE VLA-ATTACHTOOLBARTOFLYOUT VLA-AUDITINFO VLA-BIND VLA-BLOCK VLA-BOOLEAN VLA-CHECKINTERFERENCE VLA-CLEAR VLA-CLEARSUBSELECTION VLA-CLEARTABLESTYLEOVERRIDES VLA-CLIPBOUNDARY VLA-CLOSE VLA-CONVERTTOANONYMOUSBLOCK VLA-CONVERTTOSTATICBLOCK VLA-COPY VLA-COPYFROM VLA-COPYOBJECTS VLA-COPYPROFILE VLA-CREATECELLSTYLE VLA-CREATECELLSTYLEFROMSTYLE VLA-CREATECONTENT VLA-CREATEENTRY VLA-CREATEJOG VLA-CREATETYPEDARRAY VLA-DELETE VLA-DELETECELLCONTENT VLA-DELETECELLSTYLE VLA-DELETECOLUMNS VLA-DELETECONFIGURATION VLA-DELETECONTENT VLA-DELETEFITPOINT VLA-DELETEPROFILE VLA-DELETEROWS VLA-DETACH VLA-DISPLAY VLA-DISPLAYPLOTPREVIEW VLA-DISTANCETOREAL VLA-DOCK VLA-ELEVATEORDER VLA-ENABLEMERGEALL VLA-ENDUNDOMARK VLA-ERASE VLA-EVAL VLA-EVALUATE VLA-EXPLODE VLA-EXPORT VLA-EXPORTPROFILE VLA-FIELDCODE VLA-FLOAT VLA-FORMATVALUE VLA-GENERATELAYOUT VLA-GENERATESECTIONGEOMETRY VLA-GENERATEUSAGEDATA VLA-GET-ACTION VLA-GET-ACTIVE VLA-GET-ACTIVEDIMSTYLE VLA-GET-ACTIVEDOCUMENT VLA-GET-ACTIVEINVPROJECT VLA-GET-ACTIVELAYER VLA-GET-ACTIVELAYOUT VLA-GET-ACTIVELINETYPE VLA-GET-ACTIVEMATERIAL VLA-GET-ACTIVEPROFILE VLA-GET-ACTIVEPVIEWPORT VLA-GET-ACTIVESELECTIONSET VLA-GET-ACTIVESPACE VLA-GET-ACTIVETEXTSTYLE VLA-GET-ACTIVEUCS VLA-GET-ACTIVEVIEWPORT VLA-GET-ADCINSERTUNITSDEFAULTSOURCE VLA-GET-ADCINSERTUNITSDEFAULTTARGET VLA-GET-ADJUSTFORBACKGROUND VLA-GET-AFFECTSGRAPHICS VLA-GET-ALGORITHM VLA-GET-ALIGNMENT VLA-GET-ALIGNMENTPOINTACQUISITION VLA-GET-ALIGNSPACE VLA-GET-ALLOWEDVALUES VLA-GET-ALLOWLONGSYMBOLNAMES VLA-GET-ALLOWMANUALHEIGHTS VLA-GET-ALLOWMANUALPOSITIONS VLA-GET-ALTFONTFILE VLA-GET-ALTROUNDDISTANCE VLA-GET-ALTSUBUNITSFACTOR VLA-GET-ALTSUBUNITSSUFFIX VLA-GET-ALTSUPPRESSLEADINGZEROS VLA-GET-ALTSUPPRESSTRAILINGZEROS VLA-GET-ALTSUPPRESSZEROFEET VLA-GET-ALTSUPPRESSZEROINCHES VLA-GET-ALTTABLETMENUFILE VLA-GET-ALTTEXTPREFIX VLA-GET-ALTTEXTSUFFIX VLA-GET-ALTTOLERANCEPRECISION VLA-GET-ALTTOLERANCESUPPRESSLEADINGZEROS VLA-GET-ALTTOLERANCESUPPRESSTRAILINGZEROS VLA-GET-ALTTOLERANCESUPPRESSZEROFEET VLA-GET-ALTTOLERANCESUPPRESSZEROINCHES VLA-GET-ALTUNITS VLA-GET-ALTUNITSFORMAT VLA-GET-ALTUNITSPRECISION VLA-GET-ALTUNITSSCALE VLA-GET-ANGLE VLA-GET-ANGLEFORMAT VLA-GET-ANGLEVERTEX VLA-GET-ANNOTATION VLA-GET-ANNOTATIVE VLA-GET-APPLICATION VLA-GET-ARCENDPARAM VLA-GET-ARCLENGTH VLA-GET-ARCPOINT VLA-GET-ARCSMOOTHNESS VLA-GET-ARCSTARTPARAM VLA-GET-AREA VLA-GET-ARROWHEAD1BLOCK VLA-GET-ARROWHEAD1TYPE VLA-GET-ARROWHEAD2BLOCK VLA-GET-ARROWHEAD2TYPE VLA-GET-ARROWHEADBLOCK VLA-GET-ARROWHEADSIZE VLA-GET-ARROWHEADTYPE VLA-GET-ARROWSIZE VLA-GET-ARROWSYMBOL VLA-GET-ASSOCIATIVEHATCH VLA-GET-ATTACHMENTPOINT VLA-GET-AUTHOR VLA-GET-AUTOAUDIT VLA-GET-AUTOMATICPLOTLOG VLA-GET-AUTOSAVEINTERVAL VLA-GET-AUTOSAVEPATH VLA-GET-AUTOSNAPAPERTURE VLA-GET-AUTOSNAPAPERTURESIZE VLA-GET-AUTOSNAPMAGNET VLA-GET-AUTOSNAPMARKER VLA-GET-AUTOSNAPMARKERCOLOR VLA-GET-AUTOSNAPMARKERSIZE VLA-GET-AUTOSNAPTOOLTIP VLA-GET-AUTOTRACKINGVECCOLOR VLA-GET-AUTOTRACKTOOLTIP VLA-GET-AXISDIRECTION VLA-GET-AXISPOSITION VLA-GET-BACKGROUNDCOLOR VLA-GET-BACKGROUNDFILL VLA-GET-BACKGROUNDLINESCOLOR VLA-GET-BACKGROUNDLINESHIDDENLINE VLA-GET-BACKGROUNDLINESLAYER VLA-GET-BACKGROUNDLINESLINETYPE VLA-GET-BACKGROUNDLINESLINETYPESCALE VLA-GET-BACKGROUNDLINESLINEWEIGHT VLA-GET-BACKGROUNDLINESPLOTSTYLENAME VLA-GET-BACKGROUNDLINESVISIBLE VLA-GET-BACKWARD VLA-GET-BANK VLA-GET-BASEPOINT VLA-GET-BASERADIUS VLA-GET-BATCHPLOTPROGRESS VLA-GET-BEEPONERROR VLA-GET-BIGFONTFILE VLA-GET-BITFLAGS VLA-GET-BLOCK VLA-GET-BLOCKCOLOR VLA-GET-BLOCKCONNECTIONTYPE VLA-GET-BLOCKROTATION VLA-GET-BLOCKS VLA-GET-BLOCKSCALE VLA-GET-BLOCKSCALING VLA-GET-BLUE VLA-GET-BOOKNAME VLA-GET-BOTTOMHEIGHT VLA-GET-BREAKSENABLED VLA-GET-BREAKSIZE VLA-GET-BREAKSPACING VLA-GET-BRIGHTNESS VLA-GET-CANONICALMEDIANAME VLA-GET-CAPTION VLA-GET-CATEGORYNAME VLA-GET-CENTER VLA-GET-CENTERMARKSIZE VLA-GET-CENTERPLOT VLA-GET-CENTERPOINT VLA-GET-CENTERTYPE VLA-GET-CENTROID VLA-GET-CHECK VLA-GET-CHORDPOINT VLA-GET-CIRCUMFERENCE VLA-GET-CLIPPED VLA-GET-CLIPPINGENABLED VLA-GET-CLOSED VLA-GET-CLOSED2 VLA-GET-COLOR VLA-GET-COLORBOOKPATH VLA-GET-COLORINDEX VLA-GET-COLORMETHOD VLA-GET-COLORNAME VLA-GET-COLUMNS VLA-GET-COLUMNSPACING VLA-GET-COMMANDDISPLAYNAME VLA-GET-COMMENT VLA-GET-COMMENTS VLA-GET-CONFIGFILE VLA-GET-CONFIGNAME VLA-GET-CONSTANT VLA-GET-CONSTANTWIDTH VLA-GET-CONSTRAIN VLA-GET-CONTENTBLOCKNAME VLA-GET-CONTENTBLOCKTYPE VLA-GET-CONTENTTYPE VLA-GET-CONTINUOUSPLOTLOG VLA-GET-CONTOURLINESPERSURFACE VLA-GET-CONTRAST VLA-GET-CONTROLPOINTS VLA-GET-COORDINATE VLA-GET-COORDINATES VLA-GET-COUNT VLA-GET-CREASELEVEL VLA-GET-CREASETYPE VLA-GET-CREATEBACKUP VLA-GET-CURRENTSECTIONTYPE VLA-GET-CURSORSIZE VLA-GET-CURVETANGENCYLINESCOLOR VLA-GET-CURVETANGENCYLINESLAYER VLA-GET-CURVETANGENCYLINESLINETYPE VLA-GET-CURVETANGENCYLINESLINETYPESCALE VLA-GET-CURVETANGENCYLINESLINEWEIGHT VLA-GET-CURVETANGENCYLINESPLOTSTYLENAME VLA-GET-CURVETANGENCYLINESVISIBLE VLA-GET-CUSTOMDICTIONARY VLA-GET-CUSTOMICONPATH VLA-GET-CUSTOMSCALE VLA-GET-CVHULLDISPLAY VLA-GET-DATABASE VLA-GET-DECIMALSEPARATOR VLA-GET-DEFAULTINTERNETURL VLA-GET-DEFAULTOUTPUTDEVICE VLA-GET-DEFAULTPLOTSTYLEFORLAYER VLA-GET-DEFAULTPLOTSTYLEFOROBJECTS VLA-GET-DEFAULTPLOTSTYLETABLE VLA-GET-DEFAULTPLOTTOFILEPATH VLA-GET-DEGREE VLA-GET-DEGREE2 VLA-GET-DELTA VLA-GET-DEMANDLOADARXAPP VLA-GET-DESCRIPTION VLA-GET-DESTINATIONBLOCK VLA-GET-DESTINATIONFILE VLA-GET-DIAMETER VLA-GET-DICTIONARIES VLA-GET-DIMCONSTRDESC VLA-GET-DIMCONSTREXPRESSION VLA-GET-DIMCONSTRFORM VLA-GET-DIMCONSTRNAME VLA-GET-DIMCONSTRREFERENCE VLA-GET-DIMCONSTRVALUE VLA-GET-DIMENSIONLINECOLOR VLA-GET-DIMENSIONLINEEXTEND VLA-GET-DIMENSIONLINETYPE VLA-GET-DIMENSIONLINEWEIGHT VLA-GET-DIMLINE1SUPPRESS VLA-GET-DIMLINE2SUPPRESS VLA-GET-DIMLINEINSIDE VLA-GET-DIMLINESUPPRESS VLA-GET-DIMSTYLES VLA-GET-DIMTXTDIRECTION VLA-GET-DIRECTION VLA-GET-DIRECTIONVECTOR VLA-GET-DISPLAY VLA-GET-DISPLAYGRIPS VLA-GET-DISPLAYGRIPSWITHINBLOCKS VLA-GET-DISPLAYLAYOUTTABS VLA-GET-DISPLAYLOCKED VLA-GET-DISPLAYOLESCALE VLA-GET-DISPLAYSCREENMENU VLA-GET-DISPLAYSCROLLBARS VLA-GET-DISPLAYSILHOUETTE VLA-GET-DOCKEDVISIBLELINES VLA-GET-DOCKSTATUS VLA-GET-DOCUMENT VLA-GET-DOCUMENTS VLA-GET-DOGLEGGED VLA-GET-DOGLEGLENGTH VLA-GET-DRAFTING VLA-GET-DRAWINGDIRECTION VLA-GET-DRAWLEADERORDERTYPE VLA-GET-DRAWMLEADERORDERTYPE VLA-GET-DRIVERSPATH VLA-GET-DWFFORMAT VLA-GET-EDGEEXTENSIONDISTANCES VLA-GET-EFFECTIVENAME VLA-GET-ELEVATION VLA-GET-ELEVATIONMODELSPACE VLA-GET-ELEVATIONPAPERSPACE VLA-GET-ENABLE VLA-GET-ENABLEBLOCKROTATION VLA-GET-ENABLEBLOCKSCALE VLA-GET-ENABLEDOGLEG VLA-GET-ENABLEFRAMETEXT VLA-GET-ENABLELANDING VLA-GET-ENABLESTARTUPDIALOG VLA-GET-ENDANGLE VLA-GET-ENDDRAFTANGLE VLA-GET-ENDDRAFTMAGNITUDE VLA-GET-ENDPARAMETER VLA-GET-ENDPOINT VLA-GET-ENDSMOOTHCONTINUITY VLA-GET-ENDSMOOTHMAGNITUDE VLA-GET-ENDSUBMENULEVEL VLA-GET-ENDTANGENT VLA-GET-ENTERPRISEMENUFILE VLA-GET-ENTITYCOLOR VLA-GET-ENTITYTRANSPARENCY VLA-GET-EXPLODABLE VLA-GET-EXTENSIONLINECOLOR VLA-GET-EXTENSIONLINEEXTEND VLA-GET-EXTENSIONLINEOFFSET VLA-GET-EXTENSIONLINEWEIGHT VLA-GET-EXTLINE1ENDPOINT VLA-GET-EXTLINE1LINETYPE VLA-GET-EXTLINE1POINT VLA-GET-EXTLINE1STARTPOINT VLA-GET-EXTLINE1SUPPRESS VLA-GET-EXTLINE2ENDPOINT VLA-GET-EXTLINE2LINETYPE VLA-GET-EXTLINE2POINT VLA-GET-EXTLINE2STARTPOINT VLA-GET-EXTLINE2SUPPRESS VLA-GET-EXTLINEFIXEDLEN VLA-GET-EXTLINEFIXEDLENSUPPRESS VLA-GET-FACECOUNT VLA-GET-FADE VLA-GET-FEATURE VLA-GET-FIELDLENGTH VLA-GET-FILE VLA-GET-FILEDEPENDENCIES VLA-GET-FILENAME VLA-GET-FILES VLA-GET-FILESIZE VLA-GET-FINGERPRINTGUID VLA-GET-FIRSTSEGMENTANGLECONSTRAINT VLA-GET-FIT VLA-GET-FITPOINTS VLA-GET-FITTOLERANCE VLA-GET-FLOATINGROWS VLA-GET-FLOWDIRECTION VLA-GET-FLYOUT VLA-GET-FONTFILE VLA-GET-FONTFILEMAP VLA-GET-FORCELINEINSIDE VLA-GET-FOREGROUNDLINESCOLOR VLA-GET-FOREGROUNDLINESEDGETRANSPARENCY VLA-GET-FOREGROUNDLINESFACETRANSPARENCY VLA-GET-FOREGROUNDLINESHIDDENLINE VLA-GET-FOREGROUNDLINESLAYER VLA-GET-FOREGROUNDLINESLINETYPE VLA-GET-FOREGROUNDLINESLINETYPESCALE VLA-GET-FOREGROUNDLINESLINEWEIGHT VLA-GET-FOREGROUNDLINESPLOTSTYLENAME VLA-GET-FOREGROUNDLINESVISIBLE VLA-GET-FOUNDPATH VLA-GET-FRACTIONFORMAT VLA-GET-FREEZE VLA-GET-FULLCRCVALIDATION VLA-GET-FULLFILENAME VLA-GET-FULLNAME VLA-GET-FULLSCREENTRACKINGVECTOR VLA-GET-GENERATIONOPTIONS VLA-GET-GRADIENTANGLE VLA-GET-GRADIENTCENTERED VLA-GET-GRADIENTCOLOR1 VLA-GET-GRADIENTCOLOR2 VLA-GET-GRADIENTNAME VLA-GET-GRAPHICSWINLAYOUTBACKGRNDCOLOR VLA-GET-GRAPHICSWINMODELBACKGRNDCOLOR VLA-GET-GREEN VLA-GET-GRIDON VLA-GET-GRIPCOLORSELECTED VLA-GET-GRIPCOLORUNSELECTED VLA-GET-GRIPSIZE VLA-GET-GROUPS VLA-GET-HANDLE VLA-GET-HASATTRIBUTES VLA-GET-HASEXTENSIONDICTIONARY VLA-GET-HASLEADER VLA-GET-HASSHEETVIEW VLA-GET-HASSUBSELECTION VLA-GET-HASVPASSOCIATION VLA-GET-HATCHOBJECTTYPE VLA-GET-HATCHSTYLE VLA-GET-HEADERSUPPRESSED VLA-GET-HEIGHT VLA-GET-HELPFILEPATH VLA-GET-HELPSTRING VLA-GET-HISTORY VLA-GET-HISTORYLINES VLA-GET-HORIZONTALTEXTPOSITION VLA-GET-HORZCELLMARGIN VLA-GET-HWND VLA-GET-HWND32 VLA-GET-HYPERLINKBASE VLA-GET-HYPERLINKDISPLAYCURSOR VLA-GET-HYPERLINKS VLA-GET-IMAGEFILE VLA-GET-IMAGEFRAMEHIGHLIGHT VLA-GET-IMAGEHEIGHT VLA-GET-IMAGEVISIBILITY VLA-GET-IMAGEWIDTH VLA-GET-INCREMENTALSAVEPERCENT VLA-GET-INDEX VLA-GET-INDICATORFILLCOLOR VLA-GET-INDICATORTRANSPARENCY VLA-GET-INSERTIONPOINT VLA-GET-INSUNITS VLA-GET-INSUNITSFACTOR VLA-GET-INTENSITYCOLORSCHEME VLA-GET-INTERSECTIONBOUNDARYCOLOR VLA-GET-INTERSECTIONBOUNDARYDIVISIONLINES VLA-GET-INTERSECTIONBOUNDARYLAYER VLA-GET-INTERSECTIONBOUNDARYLINETYPE VLA-GET-INTERSECTIONBOUNDARYLINETYPESCALE VLA-GET-INTERSECTIONBOUNDARYLINEWEIGHT VLA-GET-INTERSECTIONBOUNDARYPLOTSTYLENAME VLA-GET-INTERSECTIONBOUNDARYVISIBLE VLA-GET-INTERSECTIONFILLCOLOR VLA-GET-INTERSECTIONFILLFACETRANSPARENCY VLA-GET-INTERSECTIONFILLHATCHANGLE VLA-GET-INTERSECTIONFILLHATCHPATTERNNAME VLA-GET-INTERSECTIONFILLHATCHPATTERNTYPE VLA-GET-INTERSECTIONFILLHATCHSCALE VLA-GET-INTERSECTIONFILLHATCHSPACING VLA-GET-INTERSECTIONFILLLAYER VLA-GET-INTERSECTIONFILLLINETYPE VLA-GET-INTERSECTIONFILLLINETYPESCALE VLA-GET-INTERSECTIONFILLLINEWEIGHT VLA-GET-INTERSECTIONFILLPLOTSTYLENAME VLA-GET-INTERSECTIONFILLVISIBLE VLA-GET-INVISIBLE VLA-GET-ISCLONED VLA-GET-ISDYNAMICBLOCK VLA-GET-ISLAYOUT VLA-GET-ISMODIFIED VLA-GET-ISOPENWIDTH VLA-GET-ISOWNERXLATED VLA-GET-ISPARTIAL VLA-GET-ISPERIODIC VLA-GET-ISPLANAR VLA-GET-ISPRIMARY VLA-GET-ISQUIESCENT VLA-GET-ISRATIONAL VLA-GET-ISSUER VLA-GET-ISXREF VLA-GET-ITEMNAME VLA-GET-JOGANGLE VLA-GET-JOGLOCATION VLA-GET-JUSTIFICATION VLA-GET-KEY VLA-GET-KEY32 VLA-GET-KEYBOARDACCELERATOR VLA-GET-KEYBOARDPRIORITY VLA-GET-KEYLENGTH VLA-GET-KEYWORDS VLA-GET-KNOTPARAMETERIZATION VLA-GET-KNOTS VLA-GET-LABEL VLA-GET-LABELBLOCKID VLA-GET-LABELBLOCKID32 VLA-GET-LANDINGGAP VLA-GET-LARGEBUTTONS VLA-GET-LASTHEIGHT VLA-GET-LASTSAVEDBY VLA-GET-LAYER VLA-GET-LAYERON VLA-GET-LAYERPROPERTYOVERRIDES VLA-GET-LAYERS VLA-GET-LAYERSTATE VLA-GET-LAYOUT VLA-GET-LAYOUTCREATEVIEWPORT VLA-GET-LAYOUTCROSSHAIRCOLOR VLA-GET-LAYOUTDISPLAYMARGINS VLA-GET-LAYOUTDISPLAYPAPER VLA-GET-LAYOUTDISPLAYPAPERSHADOW VLA-GET-LAYOUTID VLA-GET-LAYOUTID32 VLA-GET-LAYOUTS VLA-GET-LAYOUTSHOWPLOTSETUP VLA-GET-LEADER1POINT VLA-GET-LEADER2POINT VLA-GET-LEADERCOUNT VLA-GET-LEADERLINECOLOR VLA-GET-LEADERLINETYPE VLA-GET-LEADERLINETYPEID VLA-GET-LEADERLINEWEIGHT VLA-GET-LEADERTYPE VLA-GET-LEFT VLA-GET-LENGTH VLA-GET-LENSLENGTH VLA-GET-LIMITS VLA-GET-LINEARSCALEFACTOR VLA-GET-LINESPACINGDISTANCE VLA-GET-LINESPACINGFACTOR VLA-GET-LINESPACINGSTYLE VLA-GET-LINETYPE VLA-GET-LINETYPEGENERATION VLA-GET-LINETYPES VLA-GET-LINETYPESCALE VLA-GET-LINEWEIGHT VLA-GET-LINEWEIGHTDISPLAY VLA-GET-LIVESECTIONENABLED VLA-GET-LOADACADLSPINALLDOCUMENTS VLA-GET-LOCALEID VLA-GET-LOCK VLA-GET-LOCKASPECTRATIO VLA-GET-LOCKED VLA-GET-LOCKPOSITION VLA-GET-LOGFILEON VLA-GET-LOGFILEPATH VLA-GET-LOWERLEFTCORNER VLA-GET-MACRO VLA-GET-MAINDICTIONARY VLA-GET-MAINTAINASSOCIATIVITY VLA-GET-MAJORAXIS VLA-GET-MAJORRADIUS VLA-GET-MASK VLA-GET-MATERIAL VLA-GET-MATERIALS VLA-GET-MAXACTIVEVIEWPORTS VLA-GET-MAXAUTOCADWINDOW VLA-GET-MAXLEADERSEGMENTSPOINTS VLA-GET-MCLOSE VLA-GET-MDENSITY VLA-GET-MEASUREMENT VLA-GET-MENUBAR VLA-GET-MENUFILE VLA-GET-MENUFILENAME VLA-GET-MENUGROUPS VLA-GET-MENUS VLA-GET-MINIMUMTABLEHEIGHT VLA-GET-MINIMUMTABLEWIDTH VLA-GET-MINORAXIS VLA-GET-MINORRADIUS VLA-GET-MLINESCALE VLA-GET-MODE VLA-GET-MODELCROSSHAIRCOLOR VLA-GET-MODELSPACE VLA-GET-MODELTYPE VLA-GET-MODELVIEW VLA-GET-MOMENTOFINERTIA VLA-GET-MONOCHROME VLA-GET-MRUNUMBER VLA-GET-MSPACE VLA-GET-MTEXTATTRIBUTE VLA-GET-MTEXTATTRIBUTECONTENT VLA-GET-MTEXTBOUNDARYWIDTH VLA-GET-MTEXTDRAWINGDIRECTION VLA-GET-MVERTEXCOUNT VLA-GET-NAME VLA-GET-NAMENOMNEMONIC VLA-GET-NCLOSE VLA-GET-NDENSITY VLA-GET-NORMAL VLA-GET-NUMBEROFCONTROLPOINTS VLA-GET-NUMBEROFCOPIES VLA-GET-NUMBEROFFACES VLA-GET-NUMBEROFFITPOINTS VLA-GET-NUMBEROFLOOPS VLA-GET-NUMBEROFVERTICES VLA-GET-NUMCELLSTYLES VLA-GET-NUMCROSSSECTIONS VLA-GET-NUMGUIDEPATHS VLA-GET-NUMVERTICES VLA-GET-NVERTEXCOUNT VLA-GET-OBJECTID VLA-GET-OBJECTID32 VLA-GET-OBJECTNAME VLA-GET-OBJECTSNAPMODE VLA-GET-OBJECTSORTBYPLOTTING VLA-GET-OBJECTSORTBYPSOUTPUT VLA-GET-OBJECTSORTBYREDRAWS VLA-GET-OBJECTSORTBYREGENS VLA-GET-OBJECTSORTBYSELECTION VLA-GET-OBJECTSORTBYSNAP VLA-GET-OBLIQUEANGLE VLA-GET-OLEITEMTYPE VLA-GET-OLELAUNCH VLA-GET-OLEPLOTQUALITY VLA-GET-OLEQUALITY VLA-GET-OLESOURCEAPP VLA-GET-ONMENUBAR VLA-GET-OPENSAVE VLA-GET-ORIGIN VLA-GET-ORTHOON VLA-GET-OUTPUT VLA-GET-OVERRIDECENTER VLA-GET-OVERWRITEPROPCHANGED VLA-GET-OWNERID VLA-GET-OWNERID32 VLA-GET-PAGESETUPOVERRIDESTEMPLATEFILE VLA-GET-PAPERSPACE VLA-GET-PAPERUNITS VLA-GET-PARENT VLA-GET-PASSWORD VLA-GET-PATH VLA-GET-PATTERNANGLE VLA-GET-PATTERNDOUBLE VLA-GET-PATTERNNAME VLA-GET-PATTERNSCALE VLA-GET-PATTERNSPACE VLA-GET-PATTERNTYPE VLA-GET-PERIMETER VLA-GET-PERIODIC VLA-GET-PICKADD VLA-GET-PICKAUTO VLA-GET-PICKBOXSIZE VLA-GET-PICKDRAG VLA-GET-PICKFIRST VLA-GET-PICKFIRSTSELECTIONSET VLA-GET-PICKGROUP VLA-GET-PLOT VLA-GET-PLOTCONFIGURATIONS VLA-GET-PLOTHIDDEN VLA-GET-PLOTLEGACY VLA-GET-PLOTLOGFILEPATH VLA-GET-PLOTORIGIN VLA-GET-PLOTPOLICY VLA-GET-PLOTROTATION VLA-GET-PLOTSTYLENAME VLA-GET-PLOTTABLE VLA-GET-PLOTTYPE VLA-GET-PLOTVIEWPORTBORDERS VLA-GET-PLOTVIEWPORTSFIRST VLA-GET-PLOTWITHLINEWEIGHTS VLA-GET-PLOTWITHPLOTSTYLES VLA-GET-POLARTRACKINGVECTOR VLA-GET-POSITION VLA-GET-POSTSCRIPTPROLOGFILE VLA-GET-PREFERENCES VLA-GET-PRESET VLA-GET-PRIMARYUNITSPRECISION VLA-GET-PRINCIPALDIRECTIONS VLA-GET-PRINCIPALMOMENTS VLA-GET-PRINTERCONFIGPATH VLA-GET-PRINTERDESCPATH VLA-GET-PRINTERPAPERSIZEALERT VLA-GET-PRINTERSPOOLALERT VLA-GET-PRINTERSTYLESHEETPATH VLA-GET-PRINTFILE VLA-GET-PRINTSPOOLERPATH VLA-GET-PRINTSPOOLEXECUTABLE VLA-GET-PRODUCTOFINERTIA VLA-GET-PROFILEROTATION VLA-GET-PROFILES VLA-GET-PROMPTSTRING VLA-GET-PROPERTYNAME VLA-GET-PROVIDERNAME VLA-GET-PROVIDERTYPE VLA-GET-PROXYIMAGE VLA-GET-QNEWTEMPLATEFILE VLA-GET-QUIETERRORMODE VLA-GET-RADIIOFGYRATION VLA-GET-RADIUS VLA-GET-RADIUSRATIO VLA-GET-READONLY VLA-GET-RED VLA-GET-REFERENCECOUNT VLA-GET-REGENERATETABLESUPPRESSED VLA-GET-REGISTEREDAPPLICATIONS VLA-GET-RENDERSMOOTHNESS VLA-GET-REPEATBOTTOMLABELS VLA-GET-REPEATTOPLABELS VLA-GET-REVISIONNUMBER VLA-GET-REVOLUTIONANGLE VLA-GET-ROTATION VLA-GET-ROUNDDISTANCE VLA-GET-ROWS VLA-GET-ROWSPACING VLA-GET-SAVEASTYPE VLA-GET-SAVED VLA-GET-SAVEPREVIEWTHUMBNAIL VLA-GET-SCALE VLA-GET-SCALEFACTOR VLA-GET-SCALEHEIGHT VLA-GET-SCALELINEWEIGHTS VLA-GET-SCALEWIDTH VLA-GET-SCMCOMMANDMODE VLA-GET-SCMDEFAULTMODE VLA-GET-SCMEDITMODE VLA-GET-SCMTIMEMODE VLA-GET-SCMTIMEVALUE VLA-GET-SECONDPOINT VLA-GET-SECONDSEGMENTANGLECONSTRAINT VLA-GET-SECTIONMANAGER VLA-GET-SEGMENTPERPOLYLINE VLA-GET-SELECTION VLA-GET-SELECTIONSETS VLA-GET-SERIALNUMBER VLA-GET-SETTINGS VLA-GET-SHADEPLOT VLA-GET-SHEETVIEW VLA-GET-SHORTCUTMENU VLA-GET-SHORTCUTMENUDISPLAY VLA-GET-SHOW VLA-GET-SHOWASSOCIATIVITY VLA-GET-SHOWCLIPPED VLA-GET-SHOWHISTORY VLA-GET-SHOWINTENSITY VLA-GET-SHOWPLOTSTYLES VLA-GET-SHOWPROXYDIALOGBOX VLA-GET-SHOWRASTERIMAGE VLA-GET-SHOWROTATION VLA-GET-SHOWWARNINGMESSAGES VLA-GET-SINGLEDOCUMENTMODE VLA-GET-SMOOTHNESS VLA-GET-SNAPBASEPOINT VLA-GET-SNAPON VLA-GET-SNAPROTATIONANGLE VLA-GET-SOLIDFILL VLA-GET-SOLIDTYPE VLA-GET-SOURCEOBJECTS VLA-GET-SPLINEFRAME VLA-GET-SPLINEMETHOD VLA-GET-STANDARDSCALE VLA-GET-STANDARDSCALE2 VLA-GET-STARTANGLE VLA-GET-STARTDRAFTANGLE VLA-GET-STARTDRAFTMAGNITUDE VLA-GET-STARTPARAMETER VLA-GET-STARTPOINT VLA-GET-STARTSMOOTHCONTINUITY VLA-GET-STARTSMOOTHMAGNITUDE VLA-GET-STARTTANGENT VLA-GET-STATE VLA-GET-STATUSID VLA-GET-STORESQLINDEX VLA-GET-STYLENAME VLA-GET-STYLESHEET VLA-GET-SUBJECT VLA-GET-SUBMENU VLA-GET-SUBUNITSFACTOR VLA-GET-SUBUNITSSUFFIX VLA-GET-SUMMARYINFO VLA-GET-SUPPORTPATH VLA-GET-SUPPRESSLEADINGZEROS VLA-GET-SUPPRESSTRAILINGZEROS VLA-GET-SUPPRESSZEROFEET VLA-GET-SUPPRESSZEROINCHES VLA-GET-SURFACENORMALS VLA-GET-SURFACETYPE VLA-GET-SURFTRIMASSOCIATIVITY VLA-GET-SYMBOLPOSITION VLA-GET-SYSTEM VLA-GET-TABLEBREAKFLOWDIRECTION VLA-GET-TABLEBREAKHEIGHT VLA-GET-TABLESREADONLY VLA-GET-TABLESTYLEOVERRIDES VLA-GET-TABORDER VLA-GET-TAGSTRING VLA-GET-TAPERANGLE VLA-GET-TARGET VLA-GET-TEMPFILEEXTENSION VLA-GET-TEMPFILEPATH VLA-GET-TEMPLATEDWGPATH VLA-GET-TEMPLATEID VLA-GET-TEMPLATEID32 VLA-GET-TEMPXREFPATH VLA-GET-TEXTALIGNMENTPOINT VLA-GET-TEXTALIGNMENTTYPE VLA-GET-TEXTANGLETYPE VLA-GET-TEXTATTACHMENTDIRECTION VLA-GET-TEXTBACKGROUNDFILL VLA-GET-TEXTBOTTOMATTACHMENTTYPE VLA-GET-TEXTCOLOR VLA-GET-TEXTDIRECTION VLA-GET-TEXTEDITOR VLA-GET-TEXTFILL VLA-GET-TEXTFILLCOLOR VLA-GET-TEXTFONT VLA-GET-TEXTFONTSIZE VLA-GET-TEXTFONTSTYLE VLA-GET-TEXTFRAMEDISPLAY VLA-GET-TEXTGAP VLA-GET-TEXTGENERATIONFLAG VLA-GET-TEXTHEIGHT VLA-GET-TEXTINSIDE VLA-GET-TEXTINSIDEALIGN VLA-GET-TEXTJUSTIFY VLA-GET-TEXTLEFTATTACHMENTTYPE VLA-GET-TEXTLINESPACINGDISTANCE VLA-GET-TEXTLINESPACINGFACTOR VLA-GET-TEXTLINESPACINGSTYLE VLA-GET-TEXTMOVEMENT VLA-GET-TEXTOUTSIDEALIGN VLA-GET-TEXTOVERRIDE VLA-GET-TEXTPOSITION VLA-GET-TEXTPRECISION VLA-GET-TEXTPREFIX VLA-GET-TEXTRIGHTATTACHMENTTYPE VLA-GET-TEXTROTATION VLA-GET-TEXTSTRING VLA-GET-TEXTSTYLE VLA-GET-TEXTSTYLENAME VLA-GET-TEXTSTYLES VLA-GET-TEXTSUFFIX VLA-GET-TEXTTOPATTACHMENTTYPE VLA-GET-TEXTUREMAPPATH VLA-GET-TEXTWIDTH VLA-GET-TEXTWINBACKGRNDCOLOR VLA-GET-TEXTWINTEXTCOLOR VLA-GET-THICKNESS VLA-GET-TIMESERVER VLA-GET-TIMESTAMP VLA-GET-TITLE VLA-GET-TITLESUPPRESSED VLA-GET-TOLERANCEDISPLAY VLA-GET-TOLERANCEHEIGHTSCALE VLA-GET-TOLERANCEJUSTIFICATION VLA-GET-TOLERANCELOWERLIMIT VLA-GET-TOLERANCEPRECISION VLA-GET-TOLERANCESUPPRESSLEADINGZEROS VLA-GET-TOLERANCESUPPRESSTRAILINGZEROS VLA-GET-TOLERANCESUPPRESSZEROFEET VLA-GET-TOLERANCESUPPRESSZEROINCHES VLA-GET-TOLERANCEUPPERLIMIT VLA-GET-TOOLBARS VLA-GET-TOOLPALETTEPATH VLA-GET-TOP VLA-GET-TOPHEIGHT VLA-GET-TOPRADIUS VLA-GET-TOTALANGLE VLA-GET-TOTALLENGTH VLA-GET-TRANSLATEIDS VLA-GET-TRANSPARENCY VLA-GET-TRUECOLOR VLA-GET-TRUECOLORIMAGES VLA-GET-TURNHEIGHT VLA-GET-TURNS VLA-GET-TURNSLOPE VLA-GET-TWIST VLA-GET-TWISTANGLE VLA-GET-TYPE VLA-GET-UCSICONATORIGIN VLA-GET-UCSICONON VLA-GET-UCSPERVIEWPORT VLA-GET-UISOLINEDENSITY VLA-GET-UNDERLAYLAYEROVERRIDEAPPLIED VLA-GET-UNDERLAYNAME VLA-GET-UNDERLAYVISIBILITY VLA-GET-UNITS VLA-GET-UNITSFORMAT VLA-GET-UNITSTYPE VLA-GET-UPPERRIGHTCORNER VLA-GET-UPSIDEDOWN VLA-GET-URL VLA-GET-URLDESCRIPTION VLA-GET-URLNAMEDLOCATION VLA-GET-USED VLA-GET-USEENTITYCOLOR VLA-GET-USELASTPLOTSETTINGS VLA-GET-USER VLA-GET-USERCOORDINATESYSTEMS VLA-GET-USESTANDARDSCALE VLA-GET-UTILITY VLA-GET-VALUE VLA-GET-VALUE32 VLA-GET-VBE VLA-GET-VERIFY VLA-GET-VERSION VLA-GET-VERSIONGUID VLA-GET-VERTCELLMARGIN VLA-GET-VERTEXCOUNT VLA-GET-VERTICALDIRECTION VLA-GET-VERTICALTEXTPOSITION VLA-GET-VERTICES VLA-GET-VIEWINGDIRECTION VLA-GET-VIEWPORTDEFAULT VLA-GET-VIEWPORTON VLA-GET-VIEWPORTS VLA-GET-VIEWS VLA-GET-VIEWTOPLOT VLA-GET-VISIBILITYEDGE1 VLA-GET-VISIBILITYEDGE2 VLA-GET-VISIBILITYEDGE3 VLA-GET-VISIBILITYEDGE4 VLA-GET-VISIBLE VLA-GET-VISOLINEDENSITY VLA-GET-VISUALSTYLE VLA-GET-VOLUME VLA-GET-WEIGHTS VLA-GET-WIDTH VLA-GET-WINDOWLEFT VLA-GET-WINDOWSTATE VLA-GET-WINDOWTITLE VLA-GET-WINDOWTOP VLA-GET-WIREFRAMETYPE VLA-GET-WORKSPACEPATH VLA-GET-XEFFECTIVESCALEFACTOR VLA-GET-XREFDATABASE VLA-GET-XREFDEMANDLOAD VLA-GET-XREFEDIT VLA-GET-XREFFADEINTENSITY VLA-GET-XREFLAYERVISIBILITY VLA-GET-XSCALEFACTOR VLA-GET-XVECTOR VLA-GET-YEFFECTIVESCALEFACTOR VLA-GET-YSCALEFACTOR VLA-GET-YVECTOR VLA-GET-ZEFFECTIVESCALEFACTOR VLA-GET-ZSCALEFACTOR VLA-GETACADSTATE VLA-GETALIGNMENT VLA-GETALIGNMENT2 VLA-GETALLPROFILENAMES VLA-GETANGLE VLA-GETATTACHMENTPOINT VLA-GETATTRIBUTES VLA-GETAUTOSCALE VLA-GETAUTOSCALE2 VLA-GETBACKGROUNDCOLOR VLA-GETBACKGROUNDCOLOR2 VLA-GETBACKGROUNDCOLORNONE VLA-GETBITMAPS VLA-GETBLOCKATTRIBUTEVALUE VLA-GETBLOCKATTRIBUTEVALUE2 VLA-GETBLOCKATTRIBUTEVALUE232 VLA-GETBLOCKATTRIBUTEVALUE32 VLA-GETBLOCKROTATION VLA-GETBLOCKSCALE VLA-GETBLOCKTABLERECORDID VLA-GETBLOCKTABLERECORDID2 VLA-GETBLOCKTABLERECORDID232 VLA-GETBLOCKTABLERECORDID32 VLA-GETBOUNDINGBOX VLA-GETBREAKHEIGHT VLA-GETBULGE VLA-GETCANONICALMEDIANAMES VLA-GETCELLALIGNMENT VLA-GETCELLBACKGROUNDCOLOR VLA-GETCELLBACKGROUNDCOLORNONE VLA-GETCELLCLASS VLA-GETCELLCONTENTCOLOR VLA-GETCELLDATATYPE VLA-GETCELLEXTENTS VLA-GETCELLFORMAT VLA-GETCELLGRIDCOLOR VLA-GETCELLGRIDLINEWEIGHT VLA-GETCELLGRIDVISIBILITY VLA-GETCELLSTATE VLA-GETCELLSTYLE VLA-GETCELLSTYLEOVERRIDES VLA-GETCELLSTYLES VLA-GETCELLTEXTHEIGHT VLA-GETCELLTEXTSTYLE VLA-GETCELLTYPE VLA-GETCELLVALUE VLA-GETCOLOR VLA-GETCOLOR2 VLA-GETCOLUMNNAME VLA-GETCOLUMNWIDTH VLA-GETCONSTANTATTRIBUTES VLA-GETCONTENTCOLOR VLA-GETCONTENTCOLOR2 VLA-GETCONTENTLAYOUT VLA-GETCONTENTTYPE VLA-GETCONTROLPOINT VLA-GETCORNER VLA-GETCUSTOMBYINDEX VLA-GETCUSTOMBYKEY VLA-GETCUSTOMDATA VLA-GETCUSTOMSCALE VLA-GETDATAFORMAT VLA-GETDATATYPE VLA-GETDATATYPE2 VLA-GETDISTANCE VLA-GETDOGLEGDIRECTION VLA-GETDYNAMICBLOCKPROPERTIES VLA-GETENTITY VLA-GETEXTENSIONDICTIONARY VLA-GETFIELDID VLA-GETFIELDID2 VLA-GETFIELDID232 VLA-GETFIELDID32 VLA-GETFITPOINT VLA-GETFONT VLA-GETFORMAT VLA-GETFORMAT2 VLA-GETFORMULA VLA-GETFULLDRAWORDER VLA-GETGRIDCOLOR VLA-GETGRIDCOLOR2 VLA-GETGRIDDOUBLELINESPACING VLA-GETGRIDLINESTYLE VLA-GETGRIDLINETYPE VLA-GETGRIDLINETYPE32 VLA-GETGRIDLINEWEIGHT VLA-GETGRIDLINEWEIGHT2 VLA-GETGRIDSPACING VLA-GETGRIDVISIBILITY VLA-GETGRIDVISIBILITY2 VLA-GETHASFORMULA VLA-GETINPUT VLA-GETINTEGER VLA-GETINTERFACEOBJECT VLA-GETINVISIBLEEDGE VLA-GETISCELLSTYLEINUSE VLA-GETISMERGEALLENABLED VLA-GETKEYWORD VLA-GETLEADERINDEX VLA-GETLEADERLINEINDEXES VLA-GETLEADERLINEVERTICES VLA-GETLIVESECTION VLA-GETLOCALEMEDIANAME VLA-GETLOOPAT VLA-GETMARGIN VLA-GETMINIMUMCOLUMNWIDTH VLA-GETMINIMUMROWHEIGHT VLA-GETNAME VLA-GETOBJECT VLA-GETOBJECTIDSTRING VLA-GETORIENTATION VLA-GETOVERRIDE VLA-GETPAPERMARGINS VLA-GETPAPERSIZE VLA-GETPLOTDEVICENAMES VLA-GETPLOTSTYLETABLENAMES VLA-GETPOINT VLA-GETPROJECTFILEPATH VLA-GETREAL VLA-GETRELATIVEDRAWORDER VLA-GETREMOTEFILE VLA-GETROTATION VLA-GETROWHEIGHT VLA-GETROWTYPE VLA-GETSCALE VLA-GETSECTIONTYPESETTINGS VLA-GETSNAPSPACING VLA-GETSTRING VLA-GETSUBENTITY VLA-GETSUBENTITY32 VLA-GETSUBSELECTION VLA-GETTEXT VLA-GETTEXTHEIGHT VLA-GETTEXTHEIGHT2 VLA-GETTEXTROTATION VLA-GETTEXTSTRING VLA-GETTEXTSTYLE VLA-GETTEXTSTYLE2 VLA-GETTEXTSTYLEID VLA-GETTEXTSTYLEID32 VLA-GETUCSMATRIX VLA-GETUNIQUECELLSTYLENAME VLA-GETUNIQUESECTIONNAME VLA-GETVALUE VLA-GETVARIABLE VLA-GETVERTEXCOUNT VLA-GETWEIGHT VLA-GETWIDTH VLA-GETWINDOWTOPLOT VLA-GETXDATA VLA-GETXRECORDDATA VLA-HANDLETOOBJECT VLA-HIGHLIGHT VLA-HITTEST VLA-IMPORT VLA-IMPORTPROFILE VLA-INDEXOF VLA-INITIALIZEUSERINPUT VLA-INSERTBLOCK VLA-INSERTCOLUMNS VLA-INSERTCOLUMNSANDINHERIT VLA-INSERTINMENUBAR VLA-INSERTLOOPAT VLA-INSERTMENUINMENUBAR VLA-INSERTROWS VLA-INSERTROWSANDINHERIT VLA-INTERSECTWITH VLA-ISCONTENTEDITABLE VLA-ISEMPTY VLA-ISFORMATEDITABLE VLA-ISMERGEALLENABLED VLA-ISMERGEDCELL VLA-ISREMOTEFILE VLA-ISURL VLA-ITEM VLA-LAUNCHBROWSERDIALOG VLA-LISTARX VLA-LOAD VLA-LOADARX VLA-LOADDVB VLA-LOADSHAPEFILE VLA-MERGECELLS VLA-MIRROR VLA-MIRROR3D VLA-MODIFIED VLA-MOVE VLA-MOVEABOVE VLA-MOVEBELOW VLA-MOVECONTENT VLA-MOVETOBOTTOM VLA-MOVETOTOP VLA-NEW VLA-NUMCUSTOMINFO VLA-OBJECTID32TOOBJECTIDSTRING VLA-OBJECTIDTOOBJECT VLA-OBJECTIDTOOBJECT32 VLA-OFFSET VLA-ONMODIFIED VLA-OPEN VLA-PLOTTODEVICE VLA-PLOTTOFILE VLA-POLARPOINT VLA-PROMPT VLA-PURGEALL VLA-PURGEFITDATA VLA-PUT-ACTION VLA-PUT-ACTIVEDIMSTYLE VLA-PUT-ACTIVEDOCUMENT VLA-PUT-ACTIVEINVPROJECT VLA-PUT-ACTIVELAYER VLA-PUT-ACTIVELAYOUT VLA-PUT-ACTIVELINETYPE VLA-PUT-ACTIVEMATERIAL VLA-PUT-ACTIVEPROFILE VLA-PUT-ACTIVEPVIEWPORT VLA-PUT-ACTIVESPACE VLA-PUT-ACTIVETEXTSTYLE VLA-PUT-ACTIVEUCS VLA-PUT-ACTIVEVIEWPORT VLA-PUT-ADCINSERTUNITSDEFAULTSOURCE VLA-PUT-ADCINSERTUNITSDEFAULTTARGET VLA-PUT-ADJUSTFORBACKGROUND VLA-PUT-ALGORITHM VLA-PUT-ALIGNMENT VLA-PUT-ALIGNMENTPOINTACQUISITION VLA-PUT-ALIGNSPACE VLA-PUT-ALLOWLONGSYMBOLNAMES VLA-PUT-ALLOWMANUALHEIGHTS VLA-PUT-ALLOWMANUALPOSITIONS VLA-PUT-ALTFONTFILE VLA-PUT-ALTROUNDDISTANCE VLA-PUT-ALTSUBUNITSFACTOR VLA-PUT-ALTSUBUNITSSUFFIX VLA-PUT-ALTSUPPRESSLEADINGZEROS VLA-PUT-ALTSUPPRESSTRAILINGZEROS VLA-PUT-ALTSUPPRESSZEROFEET VLA-PUT-ALTSUPPRESSZEROINCHES VLA-PUT-ALTTABLETMENUFILE VLA-PUT-ALTTEXTPREFIX VLA-PUT-ALTTEXTSUFFIX VLA-PUT-ALTTOLERANCEPRECISION VLA-PUT-ALTTOLERANCESUPPRESSLEADINGZEROS VLA-PUT-ALTTOLERANCESUPPRESSTRAILINGZEROS VLA-PUT-ALTTOLERANCESUPPRESSZEROFEET VLA-PUT-ALTTOLERANCESUPPRESSZEROINCHES VLA-PUT-ALTUNITS VLA-PUT-ALTUNITSFORMAT VLA-PUT-ALTUNITSPRECISION VLA-PUT-ALTUNITSSCALE VLA-PUT-ANGLEFORMAT VLA-PUT-ANGLEVERTEX VLA-PUT-ANNOTATION VLA-PUT-ANNOTATIVE VLA-PUT-ARCENDPARAM VLA-PUT-ARCPOINT VLA-PUT-ARCSMOOTHNESS VLA-PUT-ARCSTARTPARAM VLA-PUT-AREA VLA-PUT-ARROWHEAD1BLOCK VLA-PUT-ARROWHEAD1TYPE VLA-PUT-ARROWHEAD2BLOCK VLA-PUT-ARROWHEAD2TYPE VLA-PUT-ARROWHEADBLOCK VLA-PUT-ARROWHEADSIZE VLA-PUT-ARROWHEADTYPE VLA-PUT-ARROWSIZE VLA-PUT-ARROWSYMBOL VLA-PUT-ASSOCIATIVEHATCH VLA-PUT-ATTACHMENTPOINT VLA-PUT-AUTHOR VLA-PUT-AUTOAUDIT VLA-PUT-AUTOMATICPLOTLOG VLA-PUT-AUTOSAVEINTERVAL VLA-PUT-AUTOSAVEPATH VLA-PUT-AUTOSNAPAPERTURE VLA-PUT-AUTOSNAPAPERTURESIZE VLA-PUT-AUTOSNAPMAGNET VLA-PUT-AUTOSNAPMARKER VLA-PUT-AUTOSNAPMARKERCOLOR VLA-PUT-AUTOSNAPMARKERSIZE VLA-PUT-AUTOSNAPTOOLTIP VLA-PUT-AUTOTRACKINGVECCOLOR VLA-PUT-AUTOTRACKTOOLTIP VLA-PUT-AXISPOSITION VLA-PUT-BACKGROUNDCOLOR VLA-PUT-BACKGROUNDFILL VLA-PUT-BACKGROUNDLINESCOLOR VLA-PUT-BACKGROUNDLINESHIDDENLINE VLA-PUT-BACKGROUNDLINESLAYER VLA-PUT-BACKGROUNDLINESLINETYPE VLA-PUT-BACKGROUNDLINESLINETYPESCALE VLA-PUT-BACKGROUNDLINESLINEWEIGHT VLA-PUT-BACKGROUNDLINESPLOTSTYLENAME VLA-PUT-BACKGROUNDLINESVISIBLE VLA-PUT-BACKWARD VLA-PUT-BANK VLA-PUT-BASEPOINT VLA-PUT-BASERADIUS VLA-PUT-BATCHPLOTPROGRESS VLA-PUT-BEEPONERROR VLA-PUT-BIGFONTFILE VLA-PUT-BITFLAGS VLA-PUT-BLOCK VLA-PUT-BLOCKCOLOR VLA-PUT-BLOCKCONNECTIONTYPE VLA-PUT-BLOCKROTATION VLA-PUT-BLOCKSCALE VLA-PUT-BLOCKSCALING VLA-PUT-BOTTOMHEIGHT VLA-PUT-BREAKSENABLED VLA-PUT-BREAKSIZE VLA-PUT-BREAKSPACING VLA-PUT-BRIGHTNESS VLA-PUT-CANONICALMEDIANAME VLA-PUT-CATEGORYNAME VLA-PUT-CENTER VLA-PUT-CENTERMARKSIZE VLA-PUT-CENTERPLOT VLA-PUT-CENTERPOINT VLA-PUT-CENTERTYPE VLA-PUT-CHECK VLA-PUT-CHORDPOINT VLA-PUT-CIRCUMFERENCE VLA-PUT-CLIPPINGENABLED VLA-PUT-CLOSED VLA-PUT-CLOSED2 VLA-PUT-COLOR VLA-PUT-COLORBOOKPATH VLA-PUT-COLORINDEX VLA-PUT-COLORMETHOD VLA-PUT-COLUMNS VLA-PUT-COLUMNSPACING VLA-PUT-COLUMNWIDTH VLA-PUT-COMMANDDISPLAYNAME VLA-PUT-COMMENT VLA-PUT-COMMENTS VLA-PUT-CONFIGNAME VLA-PUT-CONSTANT VLA-PUT-CONSTANTWIDTH VLA-PUT-CONSTRAIN VLA-PUT-CONTENTBLOCKNAME VLA-PUT-CONTENTBLOCKTYPE VLA-PUT-CONTENTTYPE VLA-PUT-CONTINUOUSPLOTLOG VLA-PUT-CONTOURLINESPERSURFACE VLA-PUT-CONTRAST VLA-PUT-CONTROLPOINTS VLA-PUT-COORDINATE VLA-PUT-COORDINATES VLA-PUT-CREASELEVEL VLA-PUT-CREASETYPE VLA-PUT-CREATEBACKUP VLA-PUT-CURRENTSECTIONTYPE VLA-PUT-CURSORSIZE VLA-PUT-CURVETANGENCYLINESCOLOR VLA-PUT-CURVETANGENCYLINESLAYER VLA-PUT-CURVETANGENCYLINESLINETYPE VLA-PUT-CURVETANGENCYLINESLINETYPESCALE VLA-PUT-CURVETANGENCYLINESLINEWEIGHT VLA-PUT-CURVETANGENCYLINESPLOTSTYLENAME VLA-PUT-CURVETANGENCYLINESVISIBLE VLA-PUT-CUSTOMDICTIONARY VLA-PUT-CUSTOMICONPATH VLA-PUT-CUSTOMSCALE VLA-PUT-CVHULLDISPLAY VLA-PUT-DECIMALSEPARATOR VLA-PUT-DEFAULTINTERNETURL VLA-PUT-DEFAULTOUTPUTDEVICE VLA-PUT-DEFAULTPLOTSTYLEFORLAYER VLA-PUT-DEFAULTPLOTSTYLEFOROBJECTS VLA-PUT-DEFAULTPLOTSTYLETABLE VLA-PUT-DEFAULTPLOTTOFILEPATH VLA-PUT-DEGREE2 VLA-PUT-DEMANDLOADARXAPP VLA-PUT-DESCRIPTION VLA-PUT-DESTINATIONBLOCK VLA-PUT-DESTINATIONFILE VLA-PUT-DIAMETER VLA-PUT-DIMCONSTRDESC VLA-PUT-DIMCONSTREXPRESSION VLA-PUT-DIMCONSTRFORM VLA-PUT-DIMCONSTRNAME VLA-PUT-DIMCONSTRREFERENCE VLA-PUT-DIMCONSTRVALUE VLA-PUT-DIMENSIONLINECOLOR VLA-PUT-DIMENSIONLINEEXTEND VLA-PUT-DIMENSIONLINETYPE VLA-PUT-DIMENSIONLINEWEIGHT VLA-PUT-DIMLINE1SUPPRESS VLA-PUT-DIMLINE2SUPPRESS VLA-PUT-DIMLINEINSIDE VLA-PUT-DIMLINESUPPRESS VLA-PUT-DIMTXTDIRECTION VLA-PUT-DIRECTION VLA-PUT-DIRECTIONVECTOR VLA-PUT-DISPLAYGRIPS VLA-PUT-DISPLAYGRIPSWITHINBLOCKS VLA-PUT-DISPLAYLAYOUTTABS VLA-PUT-DISPLAYLOCKED VLA-PUT-DISPLAYOLESCALE VLA-PUT-DISPLAYSCREENMENU VLA-PUT-DISPLAYSCROLLBARS VLA-PUT-DISPLAYSILHOUETTE VLA-PUT-DOCKEDVISIBLELINES VLA-PUT-DOGLEGGED VLA-PUT-DOGLEGLENGTH VLA-PUT-DRAWINGDIRECTION VLA-PUT-DRAWLEADERORDERTYPE VLA-PUT-DRAWMLEADERORDERTYPE VLA-PUT-DRIVERSPATH VLA-PUT-DWFFORMAT VLA-PUT-EDGEEXTENSIONDISTANCES VLA-PUT-ELEVATION VLA-PUT-ELEVATIONMODELSPACE VLA-PUT-ELEVATIONPAPERSPACE VLA-PUT-ENABLE VLA-PUT-ENABLEBLOCKROTATION VLA-PUT-ENABLEBLOCKSCALE VLA-PUT-ENABLEBREAK VLA-PUT-ENABLEDOGLEG VLA-PUT-ENABLEFRAMETEXT VLA-PUT-ENABLELANDING VLA-PUT-ENABLESTARTUPDIALOG VLA-PUT-ENDANGLE VLA-PUT-ENDDRAFTANGLE VLA-PUT-ENDDRAFTMAGNITUDE VLA-PUT-ENDPARAMETER VLA-PUT-ENDPOINT VLA-PUT-ENDSMOOTHCONTINUITY VLA-PUT-ENDSMOOTHMAGNITUDE VLA-PUT-ENDSUBMENULEVEL VLA-PUT-ENDTANGENT VLA-PUT-ENTERPRISEMENUFILE VLA-PUT-ENTITYCOLOR VLA-PUT-ENTITYTRANSPARENCY VLA-PUT-EXPLODABLE VLA-PUT-EXTENSIONLINECOLOR VLA-PUT-EXTENSIONLINEEXTEND VLA-PUT-EXTENSIONLINEOFFSET VLA-PUT-EXTENSIONLINEWEIGHT VLA-PUT-EXTLINE1ENDPOINT VLA-PUT-EXTLINE1LINETYPE VLA-PUT-EXTLINE1POINT VLA-PUT-EXTLINE1STARTPOINT VLA-PUT-EXTLINE1SUPPRESS VLA-PUT-EXTLINE2ENDPOINT VLA-PUT-EXTLINE2LINETYPE VLA-PUT-EXTLINE2POINT VLA-PUT-EXTLINE2STARTPOINT VLA-PUT-EXTLINE2SUPPRESS VLA-PUT-EXTLINEFIXEDLEN VLA-PUT-EXTLINEFIXEDLENSUPPRESS VLA-PUT-FADE VLA-PUT-FIELDLENGTH VLA-PUT-FILE VLA-PUT-FIRSTSEGMENTANGLECONSTRAINT VLA-PUT-FIT VLA-PUT-FITPOINTS VLA-PUT-FITTOLERANCE VLA-PUT-FLOATINGROWS VLA-PUT-FLOWDIRECTION VLA-PUT-FONTFILE VLA-PUT-FONTFILEMAP VLA-PUT-FORCELINEINSIDE VLA-PUT-FOREGROUNDLINESCOLOR VLA-PUT-FOREGROUNDLINESEDGETRANSPARENCY VLA-PUT-FOREGROUNDLINESFACETRANSPARENCY VLA-PUT-FOREGROUNDLINESHIDDENLINE VLA-PUT-FOREGROUNDLINESLAYER VLA-PUT-FOREGROUNDLINESLINETYPE VLA-PUT-FOREGROUNDLINESLINETYPESCALE VLA-PUT-FOREGROUNDLINESLINEWEIGHT VLA-PUT-FOREGROUNDLINESPLOTSTYLENAME VLA-PUT-FOREGROUNDLINESVISIBLE VLA-PUT-FRACTIONFORMAT VLA-PUT-FREEZE VLA-PUT-FULLCRCVALIDATION VLA-PUT-FULLSCREENTRACKINGVECTOR VLA-PUT-GENERATIONOPTIONS VLA-PUT-GRADIENTANGLE VLA-PUT-GRADIENTCENTERED VLA-PUT-GRADIENTCOLOR1 VLA-PUT-GRADIENTCOLOR2 VLA-PUT-GRADIENTNAME VLA-PUT-GRAPHICSWINLAYOUTBACKGRNDCOLOR VLA-PUT-GRAPHICSWINMODELBACKGRNDCOLOR VLA-PUT-GRIDON VLA-PUT-GRIPCOLORSELECTED VLA-PUT-GRIPCOLORUNSELECTED VLA-PUT-GRIPSIZE VLA-PUT-HASLEADER VLA-PUT-HASVPASSOCIATION VLA-PUT-HATCHOBJECTTYPE VLA-PUT-HATCHSTYLE VLA-PUT-HEADERSUPPRESSED VLA-PUT-HEIGHT VLA-PUT-HELPFILEPATH VLA-PUT-HELPSTRING VLA-PUT-HISTORY VLA-PUT-HISTORYLINES VLA-PUT-HORIZONTALTEXTPOSITION VLA-PUT-HORZCELLMARGIN VLA-PUT-HYPERLINKBASE VLA-PUT-HYPERLINKDISPLAYCURSOR VLA-PUT-IMAGEFILE VLA-PUT-IMAGEFRAMEHIGHLIGHT VLA-PUT-IMAGEHEIGHT VLA-PUT-IMAGEVISIBILITY VLA-PUT-IMAGEWIDTH VLA-PUT-INCREMENTALSAVEPERCENT VLA-PUT-INDICATORFILLCOLOR VLA-PUT-INDICATORTRANSPARENCY VLA-PUT-INSERTIONPOINT VLA-PUT-INTENSITYCOLORSCHEME VLA-PUT-INTERSECTIONBOUNDARYCOLOR VLA-PUT-INTERSECTIONBOUNDARYDIVISIONLINES VLA-PUT-INTERSECTIONBOUNDARYLAYER VLA-PUT-INTERSECTIONBOUNDARYLINETYPE VLA-PUT-INTERSECTIONBOUNDARYLINETYPESCALE VLA-PUT-INTERSECTIONBOUNDARYLINEWEIGHT VLA-PUT-INTERSECTIONBOUNDARYPLOTSTYLENAME VLA-PUT-INTERSECTIONBOUNDARYVISIBLE VLA-PUT-INTERSECTIONFILLCOLOR VLA-PUT-INTERSECTIONFILLFACETRANSPARENCY VLA-PUT-INTERSECTIONFILLHATCHANGLE VLA-PUT-INTERSECTIONFILLHATCHPATTERNNAME VLA-PUT-INTERSECTIONFILLHATCHPATTERNTYPE VLA-PUT-INTERSECTIONFILLHATCHSCALE VLA-PUT-INTERSECTIONFILLHATCHSPACING VLA-PUT-INTERSECTIONFILLLAYER VLA-PUT-INTERSECTIONFILLLINETYPE VLA-PUT-INTERSECTIONFILLLINETYPESCALE VLA-PUT-INTERSECTIONFILLLINEWEIGHT VLA-PUT-INTERSECTIONFILLPLOTSTYLENAME VLA-PUT-INTERSECTIONFILLVISIBLE VLA-PUT-INVISIBLE VLA-PUT-ISOPENWIDTH VLA-PUT-ISPARTIAL VLA-PUT-ISSUER VLA-PUT-ITEMNAME VLA-PUT-JOGANGLE VLA-PUT-JOGLOCATION VLA-PUT-JUSTIFICATION VLA-PUT-KEYBOARDACCELERATOR VLA-PUT-KEYBOARDPRIORITY VLA-PUT-KEYLENGTH VLA-PUT-KEYWORDS VLA-PUT-KNOTPARAMETERIZATION VLA-PUT-KNOTS VLA-PUT-LABEL VLA-PUT-LABELBLOCKID VLA-PUT-LABELBLOCKID32 VLA-PUT-LANDINGGAP VLA-PUT-LARGEBUTTONS VLA-PUT-LASTHEIGHT VLA-PUT-LASTSAVEDBY VLA-PUT-LAYER VLA-PUT-LAYERON VLA-PUT-LAYERSTATE VLA-PUT-LAYOUTCREATEVIEWPORT VLA-PUT-LAYOUTCROSSHAIRCOLOR VLA-PUT-LAYOUTDISPLAYMARGINS VLA-PUT-LAYOUTDISPLAYPAPER VLA-PUT-LAYOUTDISPLAYPAPERSHADOW VLA-PUT-LAYOUTID VLA-PUT-LAYOUTID32 VLA-PUT-LAYOUTSHOWPLOTSETUP VLA-PUT-LEADER1POINT VLA-PUT-LEADER2POINT VLA-PUT-LEADERLENGTH VLA-PUT-LEADERLINECOLOR VLA-PUT-LEADERLINETYPE VLA-PUT-LEADERLINETYPEID VLA-PUT-LEADERLINEWEIGHT VLA-PUT-LEADERTYPE VLA-PUT-LEFT VLA-PUT-LENGTH VLA-PUT-LENSLENGTH VLA-PUT-LIMITS VLA-PUT-LINEARSCALEFACTOR VLA-PUT-LINESPACINGDISTANCE VLA-PUT-LINESPACINGFACTOR VLA-PUT-LINESPACINGSTYLE VLA-PUT-LINETYPE VLA-PUT-LINETYPEGENERATION VLA-PUT-LINETYPESCALE VLA-PUT-LINEWEIGHT VLA-PUT-LINEWEIGHTDISPLAY VLA-PUT-LIVESECTIONENABLED VLA-PUT-LOADACADLSPINALLDOCUMENTS VLA-PUT-LOCK VLA-PUT-LOCKASPECTRATIO VLA-PUT-LOCKED VLA-PUT-LOCKPOSITION VLA-PUT-LOGFILEON VLA-PUT-LOGFILEPATH VLA-PUT-MACRO VLA-PUT-MAINDICTIONARY VLA-PUT-MAINTAINASSOCIATIVITY VLA-PUT-MAJORAXIS VLA-PUT-MAJORRADIUS VLA-PUT-MASK VLA-PUT-MATERIAL VLA-PUT-MAXACTIVEVIEWPORTS VLA-PUT-MAXAUTOCADWINDOW VLA-PUT-MAXLEADERSEGMENTSPOINTS VLA-PUT-MCLOSE VLA-PUT-MDENSITY VLA-PUT-MENUFILE VLA-PUT-MINORRADIUS VLA-PUT-MLINESCALE VLA-PUT-MODE VLA-PUT-MODELCROSSHAIRCOLOR VLA-PUT-MODELVIEW VLA-PUT-MONOCHROME VLA-PUT-MSPACE VLA-PUT-MTEXTATTRIBUTE VLA-PUT-MTEXTATTRIBUTECONTENT VLA-PUT-MTEXTBOUNDARYWIDTH VLA-PUT-MTEXTDRAWINGDIRECTION VLA-PUT-NAME VLA-PUT-NCLOSE VLA-PUT-NDENSITY VLA-PUT-NORMAL VLA-PUT-NUMBEROFCOPIES VLA-PUT-OBJECTSNAPMODE VLA-PUT-OBJECTSORTBYPLOTTING VLA-PUT-OBJECTSORTBYPSOUTPUT VLA-PUT-OBJECTSORTBYREDRAWS VLA-PUT-OBJECTSORTBYREGENS VLA-PUT-OBJECTSORTBYSELECTION VLA-PUT-OBJECTSORTBYSNAP VLA-PUT-OBLIQUEANGLE VLA-PUT-OLEITEMTYPE VLA-PUT-OLELAUNCH VLA-PUT-OLEPLOTQUALITY VLA-PUT-OLEQUALITY VLA-PUT-OLESOURCEAPP VLA-PUT-ORIGIN VLA-PUT-ORTHOON VLA-PUT-OVERRIDECENTER VLA-PUT-PAGESETUPOVERRIDESTEMPLATEFILE VLA-PUT-PAPERUNITS VLA-PUT-PASSWORD VLA-PUT-PATH VLA-PUT-PATTERNANGLE VLA-PUT-PATTERNDOUBLE VLA-PUT-PATTERNSCALE VLA-PUT-PATTERNSPACE VLA-PUT-PERIODIC VLA-PUT-PICKADD VLA-PUT-PICKAUTO VLA-PUT-PICKBOXSIZE VLA-PUT-PICKDRAG VLA-PUT-PICKFIRST VLA-PUT-PICKGROUP VLA-PUT-PLOTHIDDEN VLA-PUT-PLOTLEGACY VLA-PUT-PLOTLOGFILEPATH VLA-PUT-PLOTORIGIN VLA-PUT-PLOTPOLICY VLA-PUT-PLOTROTATION VLA-PUT-PLOTSTYLENAME VLA-PUT-PLOTTABLE VLA-PUT-PLOTTYPE VLA-PUT-PLOTVIEWPORTBORDERS VLA-PUT-PLOTVIEWPORTSFIRST VLA-PUT-PLOTWITHLINEWEIGHTS VLA-PUT-PLOTWITHPLOTSTYLES VLA-PUT-POLARTRACKINGVECTOR VLA-PUT-POSITION VLA-PUT-POSTSCRIPTPROLOGFILE VLA-PUT-PRESET VLA-PUT-PRIMARYUNITSPRECISION VLA-PUT-PRINTERCONFIGPATH VLA-PUT-PRINTERDESCPATH VLA-PUT-PRINTERPAPERSIZEALERT VLA-PUT-PRINTERSPOOLALERT VLA-PUT-PRINTERSTYLESHEETPATH VLA-PUT-PRINTFILE VLA-PUT-PRINTSPOOLERPATH VLA-PUT-PRINTSPOOLEXECUTABLE VLA-PUT-PROFILEROTATION VLA-PUT-PROMPTSTRING VLA-PUT-PROVIDERNAME VLA-PUT-PROVIDERTYPE VLA-PUT-PROXYIMAGE VLA-PUT-QNEWTEMPLATEFILE VLA-PUT-QUIETERRORMODE VLA-PUT-RADIUS VLA-PUT-RADIUSRATIO VLA-PUT-REGENERATETABLESUPPRESSED VLA-PUT-RENDERSMOOTHNESS VLA-PUT-REPEATBOTTOMLABELS VLA-PUT-REPEATTOPLABELS VLA-PUT-REVISIONNUMBER VLA-PUT-REVOLUTIONANGLE VLA-PUT-ROTATION VLA-PUT-ROUNDDISTANCE VLA-PUT-ROWHEIGHT VLA-PUT-ROWS VLA-PUT-ROWSPACING VLA-PUT-SAVEASTYPE VLA-PUT-SAVEPREVIEWTHUMBNAIL VLA-PUT-SCALE VLA-PUT-SCALEFACTOR VLA-PUT-SCALEHEIGHT VLA-PUT-SCALELINEWEIGHTS VLA-PUT-SCALEWIDTH VLA-PUT-SCMCOMMANDMODE VLA-PUT-SCMDEFAULTMODE VLA-PUT-SCMEDITMODE VLA-PUT-SCMTIMEMODE VLA-PUT-SCMTIMEVALUE VLA-PUT-SECONDPOINT VLA-PUT-SECONDSEGMENTANGLECONSTRAINT VLA-PUT-SEGMENTPERPOLYLINE VLA-PUT-SERIALNUMBER VLA-PUT-SHADEPLOT VLA-PUT-SHEETVIEW VLA-PUT-SHORTCUTMENUDISPLAY VLA-PUT-SHOWASSOCIATIVITY VLA-PUT-SHOWCLIPPED VLA-PUT-SHOWHISTORY VLA-PUT-SHOWINTENSITY VLA-PUT-SHOWPLOTSTYLES VLA-PUT-SHOWPROXYDIALOGBOX VLA-PUT-SHOWRASTERIMAGE VLA-PUT-SHOWROTATION VLA-PUT-SHOWWARNINGMESSAGES VLA-PUT-SINGLEDOCUMENTMODE VLA-PUT-SMOOTHNESS VLA-PUT-SNAPBASEPOINT VLA-PUT-SNAPON VLA-PUT-SNAPROTATIONANGLE VLA-PUT-SOLIDFILL VLA-PUT-SOURCEOBJECTS VLA-PUT-SPLINEFRAME VLA-PUT-SPLINEMETHOD VLA-PUT-STANDARDSCALE VLA-PUT-STANDARDSCALE2 VLA-PUT-STARTANGLE VLA-PUT-STARTDRAFTANGLE VLA-PUT-STARTDRAFTMAGNITUDE VLA-PUT-STARTPARAMETER VLA-PUT-STARTPOINT VLA-PUT-STARTSMOOTHCONTINUITY VLA-PUT-STARTSMOOTHMAGNITUDE VLA-PUT-STARTTANGENT VLA-PUT-STATE VLA-PUT-STORESQLINDEX VLA-PUT-STYLENAME VLA-PUT-STYLESHEET VLA-PUT-SUBJECT VLA-PUT-SUBUNITSFACTOR VLA-PUT-SUBUNITSSUFFIX VLA-PUT-SUPPORTPATH VLA-PUT-SUPPRESSLEADINGZEROS VLA-PUT-SUPPRESSTRAILINGZEROS VLA-PUT-SUPPRESSZEROFEET VLA-PUT-SUPPRESSZEROINCHES VLA-PUT-SURFACENORMALS VLA-PUT-SURFTRIMASSOCIATIVITY VLA-PUT-SYMBOLPOSITION VLA-PUT-TABLEBREAKFLOWDIRECTION VLA-PUT-TABLEBREAKHEIGHT VLA-PUT-TABLESREADONLY VLA-PUT-TABORDER VLA-PUT-TAGSTRING VLA-PUT-TAPERANGLE VLA-PUT-TARGET VLA-PUT-TEMPFILEEXTENSION VLA-PUT-TEMPFILEPATH VLA-PUT-TEMPLATEDWGPATH VLA-PUT-TEMPLATEID VLA-PUT-TEMPLATEID32 VLA-PUT-TEMPXREFPATH VLA-PUT-TEXTALIGNMENTPOINT VLA-PUT-TEXTALIGNMENTTYPE VLA-PUT-TEXTANGLETYPE VLA-PUT-TEXTATTACHMENTDIRECTION VLA-PUT-TEXTBACKGROUNDFILL VLA-PUT-TEXTBOTTOMATTACHMENTTYPE VLA-PUT-TEXTCOLOR VLA-PUT-TEXTDIRECTION VLA-PUT-TEXTEDITOR VLA-PUT-TEXTFILL VLA-PUT-TEXTFILLCOLOR VLA-PUT-TEXTFONT VLA-PUT-TEXTFONTSIZE VLA-PUT-TEXTFONTSTYLE VLA-PUT-TEXTFRAMEDISPLAY VLA-PUT-TEXTGAP VLA-PUT-TEXTGENERATIONFLAG VLA-PUT-TEXTHEIGHT VLA-PUT-TEXTINSIDE VLA-PUT-TEXTINSIDEALIGN VLA-PUT-TEXTJUSTIFY VLA-PUT-TEXTLEFTATTACHMENTTYPE VLA-PUT-TEXTLINESPACINGDISTANCE VLA-PUT-TEXTLINESPACINGFACTOR VLA-PUT-TEXTLINESPACINGSTYLE VLA-PUT-TEXTMOVEMENT VLA-PUT-TEXTOUTSIDEALIGN VLA-PUT-TEXTOVERRIDE VLA-PUT-TEXTPOSITION VLA-PUT-TEXTPRECISION VLA-PUT-TEXTPREFIX VLA-PUT-TEXTRIGHTATTACHMENTTYPE VLA-PUT-TEXTROTATION VLA-PUT-TEXTSTRING VLA-PUT-TEXTSTYLE VLA-PUT-TEXTSTYLENAME VLA-PUT-TEXTSUFFIX VLA-PUT-TEXTTOPATTACHMENTTYPE VLA-PUT-TEXTUREMAPPATH VLA-PUT-TEXTWIDTH VLA-PUT-TEXTWINBACKGRNDCOLOR VLA-PUT-TEXTWINTEXTCOLOR VLA-PUT-THICKNESS VLA-PUT-TIMESERVER VLA-PUT-TITLE VLA-PUT-TITLESUPPRESSED VLA-PUT-TOLERANCEDISPLAY VLA-PUT-TOLERANCEHEIGHTSCALE VLA-PUT-TOLERANCEJUSTIFICATION VLA-PUT-TOLERANCELOWERLIMIT VLA-PUT-TOLERANCEPRECISION VLA-PUT-TOLERANCESUPPRESSLEADINGZEROS VLA-PUT-TOLERANCESUPPRESSTRAILINGZEROS VLA-PUT-TOLERANCESUPPRESSZEROFEET VLA-PUT-TOLERANCESUPPRESSZEROINCHES VLA-PUT-TOLERANCEUPPERLIMIT VLA-PUT-TOOLPALETTEPATH VLA-PUT-TOP VLA-PUT-TOPHEIGHT VLA-PUT-TOPRADIUS VLA-PUT-TRANSLATEIDS VLA-PUT-TRANSPARENCY VLA-PUT-TRUECOLOR VLA-PUT-TRUECOLORIMAGES VLA-PUT-TURNHEIGHT VLA-PUT-TURNS VLA-PUT-TWIST VLA-PUT-TWISTANGLE VLA-PUT-TYPE VLA-PUT-UCSICONATORIGIN VLA-PUT-UCSICONON VLA-PUT-UCSPERVIEWPORT VLA-PUT-UISOLINEDENSITY VLA-PUT-UNDERLAYLAYEROVERRIDEAPPLIED VLA-PUT-UNDERLAYNAME VLA-PUT-UNDERLAYVISIBILITY VLA-PUT-UNITS VLA-PUT-UNITSFORMAT VLA-PUT-UPSIDEDOWN VLA-PUT-URL VLA-PUT-URLDESCRIPTION VLA-PUT-URLNAMEDLOCATION VLA-PUT-USEENTITYCOLOR VLA-PUT-USELASTPLOTSETTINGS VLA-PUT-USESTANDARDSCALE VLA-PUT-VALUE VLA-PUT-VERIFY VLA-PUT-VERTCELLMARGIN VLA-PUT-VERTICALDIRECTION VLA-PUT-VERTICALTEXTPOSITION VLA-PUT-VERTICES VLA-PUT-VIEWINGDIRECTION VLA-PUT-VIEWPORTDEFAULT VLA-PUT-VIEWPORTON VLA-PUT-VIEWTOPLOT VLA-PUT-VISIBILITYEDGE1 VLA-PUT-VISIBILITYEDGE2 VLA-PUT-VISIBILITYEDGE3 VLA-PUT-VISIBILITYEDGE4 VLA-PUT-VISIBLE VLA-PUT-VISOLINEDENSITY VLA-PUT-VISUALSTYLE VLA-PUT-WEIGHTS VLA-PUT-WIDTH VLA-PUT-WINDOWLEFT VLA-PUT-WINDOWSTATE VLA-PUT-WINDOWTOP VLA-PUT-WIREFRAMETYPE VLA-PUT-WORKSPACEPATH VLA-PUT-XEFFECTIVESCALEFACTOR VLA-PUT-XREFDEMANDLOAD VLA-PUT-XREFEDIT VLA-PUT-XREFFADEINTENSITY VLA-PUT-XREFLAYERVISIBILITY VLA-PUT-XSCALEFACTOR VLA-PUT-XVECTOR VLA-PUT-YEFFECTIVESCALEFACTOR VLA-PUT-YSCALEFACTOR VLA-PUT-YVECTOR VLA-PUT-ZEFFECTIVESCALEFACTOR VLA-PUT-ZSCALEFACTOR VLA-PUTREMOTEFILE VLA-QUIT VLA-REALTOSTRING VLA-RECOMPUTETABLEBLOCK VLA-REFRESHPLOTDEVICEINFO VLA-REGEN VLA-RELOAD VLA-REMOVE VLA-REMOVEALLOVERRIDES VLA-REMOVECUSTOMBYINDEX VLA-REMOVECUSTOMBYKEY VLA-REMOVEENTRY VLA-REMOVEFROMMENUBAR VLA-REMOVEITEMS VLA-REMOVELEADER VLA-REMOVELEADERLINE VLA-REMOVEMENUFROMMENUBAR VLA-REMOVEVERTEX VLA-RENAME VLA-RENAMECELLSTYLE VLA-RENAMEPROFILE VLA-REPLACE VLA-RESELECTSUBREGION VLA-RESETBLOCK VLA-RESETCELLVALUE VLA-RESETPROFILE VLA-RESTORE VLA-REVERSE VLA-ROTATE VLA-ROTATE3D VLA-RUNMACRO VLA-SAVE VLA-SAVEAS VLA-SCALEENTITY VLA-SECTIONSOLID VLA-SELECT VLA-SELECTATPOINT VLA-SELECTBYPOLYGON VLA-SELECTONSCREEN VLA-SELECTSUBREGION VLA-SENDCOMMAND VLA-SENDMODELESSOPERATIONENDED VLA-SENDMODELESSOPERATIONSTART VLA-SETALIGNMENT VLA-SETALIGNMENT2 VLA-SETAUTOSCALE VLA-SETAUTOSCALE2 VLA-SETBACKGROUNDCOLOR VLA-SETBACKGROUNDCOLOR2 VLA-SETBACKGROUNDCOLORNONE VLA-SETBITMAPS VLA-SETBLOCKATTRIBUTEVALUE VLA-SETBLOCKATTRIBUTEVALUE2 VLA-SETBLOCKATTRIBUTEVALUE232 VLA-SETBLOCKATTRIBUTEVALUE32 VLA-SETBLOCKROTATION VLA-SETBLOCKSCALE VLA-SETBLOCKTABLERECORDID VLA-SETBLOCKTABLERECORDID2 VLA-SETBLOCKTABLERECORDID232 VLA-SETBLOCKTABLERECORDID32 VLA-SETBREAKHEIGHT VLA-SETBULGE VLA-SETCELLALIGNMENT VLA-SETCELLBACKGROUNDCOLOR VLA-SETCELLBACKGROUNDCOLORNONE VLA-SETCELLCLASS VLA-SETCELLCONTENTCOLOR VLA-SETCELLDATATYPE VLA-SETCELLFORMAT VLA-SETCELLGRIDCOLOR VLA-SETCELLGRIDLINEWEIGHT VLA-SETCELLGRIDVISIBILITY VLA-SETCELLSTATE VLA-SETCELLSTYLE VLA-SETCELLTEXTHEIGHT VLA-SETCELLTEXTSTYLE VLA-SETCELLTYPE VLA-SETCELLVALUE VLA-SETCELLVALUEFROMTEXT VLA-SETCOLOR VLA-SETCOLOR2 VLA-SETCOLORBOOKCOLOR VLA-SETCOLUMNNAME VLA-SETCOLUMNWIDTH VLA-SETCONTENTCOLOR VLA-SETCONTENTCOLOR2 VLA-SETCONTENTLAYOUT VLA-SETCONTROLPOINT VLA-SETCUSTOMBYINDEX VLA-SETCUSTOMBYKEY VLA-SETCUSTOMDATA VLA-SETCUSTOMSCALE VLA-SETDATABASE VLA-SETDATAFORMAT VLA-SETDATATYPE VLA-SETDATATYPE2 VLA-SETDOGLEGDIRECTION VLA-SETFIELDID VLA-SETFIELDID2 VLA-SETFIELDID232 VLA-SETFIELDID32 VLA-SETFITPOINT VLA-SETFONT VLA-SETFORMAT VLA-SETFORMAT2 VLA-SETFORMULA VLA-SETGRIDCOLOR VLA-SETGRIDCOLOR2 VLA-SETGRIDDOUBLELINESPACING VLA-SETGRIDLINESTYLE VLA-SETGRIDLINETYPE VLA-SETGRIDLINETYPE32 VLA-SETGRIDLINEWEIGHT VLA-SETGRIDLINEWEIGHT2 VLA-SETGRIDSPACING VLA-SETGRIDVISIBILITY VLA-SETGRIDVISIBILITY2 VLA-SETINVISIBLEEDGE VLA-SETLAYOUTSTOPLOT VLA-SETLEADERLINEVERTICES VLA-SETMARGIN VLA-SETNAMES VLA-SETOVERRIDE VLA-SETPATTERN VLA-SETPROJECTFILEPATH VLA-SETRELATIVEDRAWORDER VLA-SETRGB VLA-SETROTATION VLA-SETROWHEIGHT VLA-SETSCALE VLA-SETSNAPSPACING VLA-SETSUBSELECTION VLA-SETTEMPLATEID VLA-SETTEMPLATEID32 VLA-SETTEXT VLA-SETTEXTHEIGHT VLA-SETTEXTHEIGHT2 VLA-SETTEXTROTATION VLA-SETTEXTSTRING VLA-SETTEXTSTYLE VLA-SETTEXTSTYLE2 VLA-SETTEXTSTYLEID VLA-SETTEXTSTYLEID32 VLA-SETTOOLTIP VLA-SETVALUE VLA-SETVALUEFROMTEXT VLA-SETVARIABLE VLA-SETVIEW VLA-SETWEIGHT VLA-SETWIDTH VLA-SETWINDOWTOPLOT VLA-SETXDATA VLA-SETXRECORDDATA VLA-SLICESOLID VLA-SPLIT VLA-STARTBATCHMODE VLA-STARTUNDOMARK VLA-SWAPORDER VLA-SYNCMODELVIEW VLA-TRANSFORMBY VLA-TRANSLATECOORDINATES VLA-UNLOAD VLA-UNLOADARX VLA-UNLOADDVB VLA-UNMERGECELLS VLA-UPDATE VLA-UPDATEENTRY VLA-UPDATEMTEXTATTRIBUTE VLA-WBLOCK VLA-ZOOMALL VLA-ZOOMCENTER VLA-ZOOMEXTENTS VLA-ZOOMPICKWINDOW VLA-ZOOMPREVIOUS VLA-ZOOMSCALED VLA-ZOOMWINDOW VLARTS-INIT VLAX-3D-POINT VLAX-ADD-CMD VLAX-CREATE-OBJECT VLAX-CURVE-GETAREA VLAX-CURVE-GETCLOSESTPOINTTO VLAX-CURVE-GETCLOSESTPOINTTOPROJECTION VLAX-CURVE-GETDISTATPARAM VLAX-CURVE-GETDISTATPOINT VLAX-CURVE-GETENDPARAM VLAX-CURVE-GETENDPOINT VLAX-CURVE-GETFIRSTDERIV VLAX-CURVE-GETPARAMATDIST VLAX-CURVE-GETPARAMATPOINT VLAX-CURVE-GETPOINTATDIST VLAX-CURVE-GETPOINTATPARAM VLAX-CURVE-GETSECONDDERIV VLAX-CURVE-GETSTARTPARAM VLAX-CURVE-GETSTARTPOINT VLAX-CURVE-ISCLOSED VLAX-CURVE-ISPERIODIC VLAX-CURVE-ISPLANAR VLAX-DUMP-OBJECT VLAX-ENAME->VLA-OBJECT VLAX-ERASED-P VLAX-FOR VLAX-GET VLAX-GET-ACAD-OBJECT VLAX-GET-OBJECT VLAX-GET-OR-CREATE-OBJECT VLAX-GET-PROPERTY VLAX-IMPORT-TYPE-LIBRARY VLAX-INVOKE VLAX-INVOKE-METHOD VLAX-LDATA-DELETE VLAX-LDATA-GET VLAX-LDATA-LIST VLAX-LDATA-PUT VLAX-LDATA-TEST VLAX-MACHINE-PRODUCT-KEY VLAX-MAKE-SAFEARRAY VLAX-MAKE-VARIANT VLAX-MAP-COLLECTION VLAX-METHOD-APPLICABLE-P VLAX-OBJECT-RELEASED-P VLAX-PRODUCT-KEY VLAX-PROPERTY-AVAILABLE-P VLAX-PUT VLAX-PUT-PROPERTY VLAX-QUEUEEXPR VLAX-READ-ENABLED-P VLAX-REG-APP VLAX-RELEASE-OBJECT VLAX-REMOVE-CMD VLAX-SAFEARRAY->LIST VLAX-SAFEARRAY-FILL VLAX-SAFEARRAY-GET-DIM VLAX-SAFEARRAY-GET-ELEMENT VLAX-SAFEARRAY-GET-L-BOUND VLAX-SAFEARRAY-GET-U-BOUND VLAX-SAFEARRAY-PUT-ELEMENT VLAX-SAFEARRAY-TYPE VLAX-TMATRIX VLAX-TYPEINFO-AVAILABLE-P VLAX-USER-PRODUCT-KEY VLAX-VARIANT-CHANGE-TYPE VLAX-VARIANT-TYPE VLAX-VARIANT-VALUE VLAX-VLA-OBJECT->ENAME VLAX-WRITE-ENABLED-P VLISP-DCLRES-LIST VLISP-DCLRES-LOAD-DIALOG VLISP-EXPORT-SYMBOL VLISP-FASRES-LIST VLISP-FASRES-LOAD VLISP-IMPORT-EXSUBRS VLISP-IMPORT-SYMBOL VLISP-INIRES-LIST VLR-ACDB-REACTOR VLR-ADD VLR-ADDED-P VLR-BEEP-REACTION VLR-COMMAND-REACTOR VLR-CURRENT-REACTION-NAME VLR-DATA VLR-DATA-SET VLR-DEEPCLONE-REACTOR VLR-DOCMANAGER-REACTOR VLR-DOCUMENT VLR-DWG-REACTOR VLR-DXF-REACTOR VLR-EDITOR-REACTOR VLR-INSERT-REACTOR VLR-LINKER-REACTOR VLR-LISP-REACTOR VLR-MISCELLANEOUS-REACTOR VLR-MOUSE-REACTOR VLR-NOTIFICATION VLR-OBJECT-REACTOR VLR-OWNER-ADD VLR-OWNER-REMOVE VLR-OWNERS VLR-PERS VLR-PERS-ACTIVATE VLR-PERS-DICTNAME VLR-PERS-LIST VLR-PERS-P VLR-PERS-RELEASE VLR-REACTION-NAMES VLR-REACTION-SET VLR-REACTIONS VLR-REACTORS VLR-REMOVE VLR-REMOVE-ALL VLR-SET-NOTIFICATION VLR-SYSVAR-REACTOR VLR-TOOLBAR-REACTOR VLR-TRACE-REACTION VLR-TYPE VLR-TYPES VLR-UNDO-REACTOR VLR-WBLOCK-REACTOR VLR-WINDOW-REACTOR VLR-XREF-REACTOR :VLAX-FALSE :VLAX-NULL :VLAX-TRUE :VLR-ABORTATTACH :VLR-ABORTDEEPCLONE :VLR-ABORTDXFIN :VLR-ABORTDXFOUT :VLR-ABORTINSERT :VLR-ABORTRESTORE :VLR-ABORTWBLOCK :VLR-ACDB-REACTOR :VLR-BEGINATTACH :VLR-BEGINCLOSE :VLR-BEGINDEEPCLONE :VLR-BEGINDEEPCLONEXLATION :VLR-BEGINDOUBLECLICK :VLR-BEGINDWGOPEN :VLR-BEGINDXFIN :VLR-BEGINDXFOUT :VLR-BEGININSERT :VLR-BEGININSERTM :VLR-BEGINRESTORE :VLR-BEGINRIGHTCLICK :VLR-BEGINSAVE :VLR-BEGINWBLOCK :VLR-BEGINWBLOCKID :VLR-BEGINWBLOCKOBJECTS :VLR-BEGINWBLOCKPT :VLR-CANCELLED :VLR-COMANDEERED :VLR-COMMAND-REACTOR :VLR-COMMANDCANCELLED :VLR-COMMANDENDED :VLR-COMMANDFAILED :VLR-COMMANDWILLSTART :VLR-COPIED :VLR-DATABASECONSTRUCTED :VLR-DATABASETOBEDESTROYED :VLR-DEEPCLONE-REACTOR :VLR-DOCFRAMEMOVEDORRESIZED :VLR-DOCMANAGER-REACTOR :VLR-DOCUMENTBECAMECURRENT :VLR-DOCUMENTCREATED :VLR-DOCUMENTLOCKMODECHANGED :VLR-DOCUMENTLOCKMODECHANGEVETOED :VLR-DOCUMENTLOCKMODEWILLCHANGE :VLR-DOCUMENTTOBEACTIVATED :VLR-DOCUMENTTOBEDEACTIVATED :VLR-DOCUMENTTOBEDESTROYED :VLR-DWG-REACTOR :VLR-DWGFILEOPENED :VLR-DXF-REACTOR :VLR-DXFINCOMPLETE :VLR-DXFOUTCOMPLETE :VLR-EDITOR-REACTOR :VLR-ENDATTACH :VLR-ENDDEEPCLONE :VLR-ENDDWGOPEN :VLR-ENDINSERT :VLR-ENDRESTORE :VLR-ENDWBLOCK :VLR-ERASED :VLR-GOODBYE :VLR-INSERT-REACTOR :VLR-LAYOUTSWITCHED :VLR-LINKER-REACTOR :VLR-LISP-REACTOR :VLR-LISPCANCELLED :VLR-LISPENDED :VLR-LISPWILLSTART :VLR-MAINFRAMEMOVEDORRESIZED :VLR-MISCELLANEOUS-REACTOR :VLR-MODIFIED :VLR-MODIFIEDXDATA :VLR-MODIFYUNDONE :VLR-MOUSE-REACTOR :VLR-OBJECT-REACTOR :VLR-OBJECTAPPENDED :VLR-OBJECTCLOSED :VLR-OBJECTERASED :VLR-OBJECTMODIFIED :VLR-OBJECTOPENEDFORMODIFY :VLR-OBJECTREAPPENDED :VLR-OBJECTUNAPPENDED :VLR-OBJECTUNERASED :VLR-OPENEDFORMODIFY :VLR-OTHERATTACH :VLR-OTHERINSERT :VLR-OTHERWBLOCK :VLR-PICKFIRSTMODIFIED :VLR-REAPPENDED :VLR-REDIRECTED :VLR-RXAPPLOADED :VLR-RXAPPUNLOADED :VLR-SAVECOMPLETE :VLR-SUBOBJMODIFIED :VLR-SYSVAR-REACTOR :VLR-SYSVARCHANGED :VLR-SYSVARWILLCHANGE :VLR-TOOLBAR-REACTOR :VLR-TOOLBARBITMAPSIZECHANGED :VLR-TOOLBARBITMAPSIZEWILLCHANGE :VLR-UNAPPENDED :VLR-UNDO-REACTOR :VLR-UNDOSUBCOMMANDAUTO :VLR-UNDOSUBCOMMANDBACK :VLR-UNDOSUBCOMMANDBEGIN :VLR-UNDOSUBCOMMANDCONTROL :VLR-UNDOSUBCOMMANDEND :VLR-UNDOSUBCOMMANDMARK :VLR-UNDOSUBCOMMANDNUMBER :VLR-UNERASED :VLR-UNKNOWNCOMMAND :VLR-WBLOCK-REACTOR :VLR-WBLOCKNOTICE :VLR-WINDOW-REACTOR :VLR-XREF-REACTOR :VLR-XREFSUBCOMMANDATTACHITEM :VLR-XREFSUBCOMMANDBINDITEM :VLR-XREFSUBCOMMANDDETACHITEM :VLR-XREFSUBCOMMANDOVERLAYITEM :VLR-XREFSUBCOMMANDPATHITEM :VLR-XREFSUBCOMMANDRELOADITEM :VLR-XREFSUBCOMMANDUNLOADITEM
Dear All
Thanks for your replies.
Lee, you are always of such great help !!!
Thank you mailmaverick
Lee
I was wondering where this was buried these days. Thanks Lee.
