I think something like this [untested] should work on orthogonal rectangles with the same Z
extrusion direction [whether or not they're at the same Z elevation]. Otherwise [for example
non-orthogonal, especially if not rotated to the same angle], I'd have to think about what the
complications would be. I haven't really worked with the getBoundingBox or safearray things before,
so there might be a simpler way to go about it, and I hope I got the syntax right. You might need a
(vl-load-com) first, too.
(setq
rectA (vlax-ename->vla-object (car (entsel "Select Rectangle A: ")))
rectB (vlax-ename->vla-object (car (entsel "Select Rectangle B: ")))
); end setq
(vla-getBoundingBox rectA 'minA 'maxA); set corners to safearray variables
(vla-getBoundingBox rectB 'minB 'maxB)
(setq
llA (vlax-safearray->list minA); convert safearrays to regular point lists
urA (vlax-safearray->list maxA)
llB (vlax-safearray->list minB)
urB (vlax-safearray->list maxB)
); ent setq
(cond
((and ; if lower left corner of A is to upper right of lower left corner of B, etc.
(= (cdr (reverse (mapcar '> llA llB))) '(T T)); removes Z to check only X and Y
(= (cdr (reverse (mapcar '< urA urB))) '(T T))
); end and
(alert "Rectangle A is INside Rectangle B.")
); end A-inside-B test
((and
(= (cdr (reverse (mapcar '< llA llB))) '(T T))
(= (cdr (reverse (mapcar '> urA urB))) '(T T))
); end and
(alert "Rectangle A is OUTside Rectangle B.")
); end A-outside-B test
(T (alert "Rectangles A and B overlap or {at least partially} coincide."))
); end cond
If they're always *Polyline* rectangles, and always orthogonal, it might be done more briefly,
calculating lower left and upper right corners from their entity data. The above [assuming it
actually works] has the advantage that it should also work if the rectangles are Blocks or [2D]
Solids or 3DFaces or Traces or Mlines.
Kent Cooper
skin wrote...
how to compare if one rectangle is inside other one?
how to get coordinates from rectangles and compare them?
result should be: A is inside B, A is outside B and A&B are overlapping...
