Is there any way to compare 2 cells in a table? I have tried diesel
$(if,$(EQ,%<\AcObjProp Object(%<\_ObjId 2128896328>%).b2>%,%<\AcObjProp Object(%<\_ObjId 2128896328>%).d2>%),true,false)
I can't seem to pass the cells into the equation. I tried formulas also with no luck.
Thanks in advance
Steve in Alaska
Read about the following function from Acad Help Documentation .
vla-gettext
Tharwat
Thank you for your quick reply, I did look for "vla-gettext" in the help file of my AutoCAD, and I even looked in the AutoCAD Developer Help file. There isn't any reference to "vla-gettext".
I am using AutoCAD 2010.
I did a quick Google for "vla-gettext" and found a couple of program snips, but no real reference to "vla-gettext".
It would help I suppose if I had some reference to how you propose to use "vla-gettext", do you think I can enter this term into a field in a cell?
I am trying to find a way to compare the values of 2 cells, and if the cell values are not the same display an "x" . As I said in my original post, I have tried formulas and diesel and have been unsuccessful.
Steve in Alaska
Since you are using Autocad 2010 you do the following to get more information about the function that I posted earlier .
Type in commnad line Vlide to invoke the Autolisp App. and then type the function and you would realize the it turned into blue color and after that highlight the function and press on the Help button that existed in the toolbar .
The return of the function would be a string and whatever if the background of the string is field or a text , so you would check if the string is equal to another and nothings more ( up to my knowledge)
Just ask if you need any help .
Tharwat
simple example ...
(defun c:test (/ table val1 val2) (vl-load-com) (if (and (setq table (car (entsel "\n Select table :"))) (eq (cdr (assoc 0 (entget table))) "ACAD_TABLE") ) (progn (setq table (vlax-ename->vla-object table)) (setq val1 (vla-gettext table 1 0));; row number 2 and column 1 (which means that
;;; first row or column is equal to zero) (setq val2 (vla-gettext table 1 1));; row number 2 and column 2 (if (eq val1 val2) (alert "\n That's correct") (alert "\n That's wrong ") ) ) ) (princ) )
Thank you again
I have not yet given up hope to have this contained all in the table. My next choice would be to attach a reactor to the table. My last choice to accomplish what I am trying to do is to write a lisp that requires running to update the table.
Steve in Alaska
Why you are everytime changing your opinion and talking about something else ???
Did my code answer your first question or not ?
Your right, I did not present my need completely and thoroughly. You have presented a solution based on the original post. If you had been a wizard you would have seen that by presenting a diesel expression, that I was trying to create a self contained solution.
Thank you very much for your help, I do appreciate it.
Steve in Alaska
