I am try to load the common didag browse box.
(vlax-create-object "MSComDlg.CommonDialog")
comes back nil
I am running AutoCAD 2010 Windows 7 64 bit.
Any ideas would be helpful.
My guess is that MSComDlg.CommonDialog is 32 bit trying to load into AutoCAD 64 bit process space. Are you able to use the CommonDialog in VBA? AutoCAD VBA IDE is a 32-bit application running in a separate process space to AutoCAD 64-bit.
Perhaps using the AutoLISP function getfiled could provide a way to get the files instead.
Cheers,
Wayne Brill
Autodesk Developer Network
