Visual LISP, AutoLISP and General Customization
COMMAND TO CONTROL WHEN LISP LISP is CANCELLED
3 REPLIES 3
811 Views, 3 Replies
HELLO, I HAVE THE FOLLOWING LISP
DEFUN c:DLI ()
(setq MLAYER (GETVAR "CLAYER"))
(SETVAR "CLAYER" "COTAS M")
(COMMAND "DIMLINEAR" PAUSE PAUSE PAUSE)
(SETVAR "CLAYER" MLAYER)
(prompt "comandos carregados com sucesso")
(princ)
When I call this routine it works correctly, but when I call and tightening ESC canceling the routine she did not back the current layer configuration.
Is to make the routine when canceled, return the current settings?
Thank you.
3 REPLIES 3
hmsilva
Hi Marcelo,
one way:
(defun c:dli (/ *error* MLAYER)
(defun *error* (msg)
  (if MLAYER (SETVAR "CLAYER" MLAYER))
    (cond ((not msg))
          ((member msg '("Function cancelled" "quit / exit abort")))
          ((princ (strcat "\n** Error: " msg " ** ")))
    (princ)
(*error* nil)
(princ)
take a look at Lee Mac's Error Handling
Henrique
mpalan2009
in reply to: hmsilva
Another way that I have done this in the past is to put a mark in the database. If my lisp function called a bunch of commands then the error function would undo back to the mark.  You could also group the functions or commands togather so that 1 undo will undo the whole group of commands at the same time.
Hope this helps.
Matthew
Thank you, very nice home to Lee Mac's
”Boost
