Then bob.at's suggestion should do well for you:
(command "_layer" "_off" "1,2,3,4" "_on" "5" "")
[except that for me in ADT [this may not be true for you], I have to put the decimal place in front
of "_.layer" for it to work.]
Or, converted to macro language so you can do it in mid-command, and expanded up to 9 Layers:
[GuideLines1]'-LAYER Off 2,3,4,5,6,7,8,9 On 1 ;
[GuideLines2]'-LAYER Off 1,3,4,5,6,7,8,9 On 2 ;
[GuideLines3]'-LAYER Off 1,2,4,5,6,7,8,9 On 3 ;
[GuideLines4]'-LAYER Off 1,2,3,5,6,7,8,9 On 4 ;
[GuideLines5]'-LAYER Off 1,2,3,4,6,7,8,9 On 5 ;
[GuideLines6]'-LAYER Off 1,2,3,4,5,7,8,9 On 6 ;
[GuideLines7]'-LAYER Off 1,2,3,4,5,6,8,9 On 7 ;
[GuideLines8]'-LAYER Off 1,2,3,4,5,6,7,9 On 8 ;
[GuideLines9]'-LAYER Off 1,2,3,4,5,6,7,8 On 9 ;
If you're putting them into Toolbars or something with icons, you can porbably dispense with the
[bracketed] headings, but you would need them for a Screen menu or Pull-down menu. You could also
leave them there even where they're not needed, for identifying what the menu items are for when you
get back into the menu later.
Kent Cooper
neeboy74 wrote...
Hello Kent; here's exactly what I'll be using this for:
I will have 9 layers. Each of these layers will have guidelines on them. These guidelines will be
used as "snap lines" when I draw elevations. That way, I can draw an elevation, then dimension it
across the bottom and snap the dimensions to these guidelines. You can see why only 1 layer should
be on at a time, otherwise I'd have a jumble of un-needed lines on the screen at once.
The layers will be different in that the spacing between the lines will shrink as the annotation
scale changes, with the "Full-Scale Layer" having the lines closest together in Model Space.
I really like your idea of being able to invoke this command while in the middle of something else
(because I know I'll forget to set this before dimensioning)
The layers will not be frozen but I will have them locked so that the lines can't be moved. I will
also not be drawing anythng on these layers after setting up the guidelines.
If you could write code for this that'd be super. Each layer could be labeled sequentially 1-9 for
this purpose. Thanks so very much!
