Hi guys
I am trying to create a short cut button with a macor code.
I want it to set up a new orgin and set a base point in xrefs i am creating
The commands i want to combined are the follwoing
UCS enter
3P enter
BASE enter
The macro i am using is the following
^c^c_ucs 3p \\_base \
but it wont run the base command after it finishes the 3P command
This is whats show up in my commands bar
Command: _ucs
Current ucs name: *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
<World>: 3p
Specify new origin point <0,0,0>:
Specify point on positive portion of X-axis <117381.06,6796.84,0.00>:
Specify point on positive-Y portion of the UCS XY plane
<117380.06,6797.84,0.00>: _base
Invalid point.
<117380.06,6797.84,0.00>: Regenerating model.
any help would be appreciated
cheers
jthorgo
@jthorgo wrote:....
UCS enter
3P enter
BASE enter
Invalid point.
That's because it hasn't finished the UCS command and its 3P option [not the 3P command -- that's the default shortcut for 3DPoly] -- the very name of the option implies you would need three backslashes after the 3P for User input to define the UCS, and the prompts confirm it.
Here is the LISP eqivalent example.
Notice for the third point it is "" [Enter].
(command ".ucs" "3" PT1 PT2 "")
When I write macro/script, I do not use spaces.
^c^c_ucs;3p;\\;_base;\
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
@scot-65 wrote:Here is the LISP eqivalent example.
Really, the AutoLISP equivalent of their routine, with an Enter added to "complete" the UCS command [if that's really what they want -- see below] would be:
(command ".ucs" "3" pause pause "" "_base" pause)
Making the third point response an Enter will put the new UCS XY plane parallel to the current one if the first two points are in a plane parallel to it [which they might not be], but with presumably a new origin and/or a new rotation. That is certainly not the only possible desired result. One could want it "facing" downward, in which case one would pick a third point on the negative-Y side relative to the first two points, or one could want it non-parallel, in which case one would pick a third point not in the XY plane relative to the first two points.
If one would need those options, it would be necessary to answer three point prompts, and the equivalent would be:
(command ".ucs" "3" pause pause pause "_base" pause)
or in macro format, with three backslashes where the original has two, rather than two backslashes and a semicolon or space.
