Visual LISP, AutoLISP and General Customization
Combine Multiple Mtext into 1 Mtext
24 REPLIES 24
Message 1 of 25
28825 Views, 24 Replies
Does anyone have a tool to combine multiple pieces of Mtext into a single
Mtext with paragraphs?
24 REPLIES 24
Message 21 of 25
in reply to: Kent1Cooper
The routine is very handy for me when I come acorss dwgs where someone made seperate mtext paragraphs. Thank you so much for witing this routine.
Message 22 of 25
Just found this routine after a short search, does exactly what I was after.  My complements to Kent Cooper, nicely done.
Lan
Message 23 of 25
troma
Lovely tool @Kent1Cooper
I went and marked your post as the solution.
(BTW it was a Google search, not a forum search that brought me here.)
Mark Green
Working on Civil 3D in Canada
Message 24 of 25
alevenhagen
An easy way is to explode ("EXPLODE") all the mtexts, and then use the Express Tool command "TXT2MTXT." You can click "yes" or "no" to adding a return after each line.
Message 25 of 25
yjavadidoodran
I just had this question and noticed that in AutoCAD 2022 you can easily select all txt objects and convert them to MText using the command TXT2MTEXT all all txt objects will be combined to one mtxt
”Boost
