Visual LISP, AutoLISP and General Customization
Combine Assoc and Wcmatch
4 REPLIES 4
mdhutchinson
556 Views, 4 Replies
Each of these returns T as follows...
(wcmatch "ROOM#" "*`#*,*NUM*,*NO")
T
_$ (wcmatch "ROOMNO" "*`#*,*NUM*,*NO")
T
_$ (wcmatch "ROOMNUM" "*`#*,*NUM*,*NO")
T
I am looking for code that will use a combination of Wcmatch with the Assoc function...
(setq PairLstA (list (list "ROOM#" "195)(list "ROOMNAME" "REST ROOM")))
(setq PairLstB (list (list "NAME" "MEN'S ROOM")(list "ROOMNUM" "385")))
(setq PairLstC (list (list "ROOMNO" "495")(list "ROOMNM" "WOMEN'S ROOM")))
(WcAssoc "*`#*,*NUM*,*NO" PairLstA)
should return... ("ROOM#" "195")
(WcAssoc "*`#*,*NUM*,*NO" PairLstB)
should return... ("ROOMNUM" "385")
(WcAssoc "*`#*,*NUM*,*NO" PairLstC)
should return...  ("ROOMNO" "495")
Does this make sense?
4 REPLIES 4
alanjt_
in reply to: mdhutchinson
Untested...
Case sensitive:
(defun _AssocWCMatch (match lst)
  (vl-some (function (lambda (item)
                       (if (wcmatch match (car item))
                         item
           lst
not case sensitive:
  (setq match (strcase match))
                       (if (wcmatch match (strcase (car item)))
                         item
           lst
mdhutchinson
in reply to: alanjt_
A small edit got it working as I want.
changed to
(wcmatch (car item) match))
then it worked.
alanjt_
Whoops. That's what happens when you scratch something out quickly.
Glad it works anyway. You're welcome.
Here's both codes, corrected:
                       (if (wcmatch (car item) match)
                         item
           lst
                       (if (wcmatch (strcase (car item)) match)
                         item
           lst
Lee_Mac
Another, recursive variation:
(defun wcassoc ( s l / x )
    (if (setq x (car l))
        (if (wcmatch (car x) s) x (wcassoc s (cdr l)))
_$ (setq l '(("ROOM#" "195") ("ROOMNAME" "REST ROOM")))
_$ (wcassoc "*`#*,*NUM*,*NO" l)
("ROOM#" "195")
”Boost
