Visual LISP, AutoLISP and General Customization
Collect empty blocks inserted in the dwg.
9 REPLIES 9
Message 1 of 10
mdhutchinson
403 Views, 9 Replies
The code below collects empty blocks with the intent to delete them.
However, it appears that if an Xref is currently 'unloaded' it apparrently collects that too. I could probably just test to see if the block is an Xref and avoid it... but how could I modify this to check if it is loaded and still empty?
(defun NullBlocks (/ block *thisdwg* block nullblocks)
 (setq *thisdwg* (vla-get-activedocument (vlax-get-acad-object)))
 (vlax-for block (vla-get-blocks *thisdwg*) ;iterate block table
  (vla-get-Name block)
  (if (= 0 (vla-get-count block))
   (setq nullblocks (cons (vla-get-name block) nullblocks))
 nullblocks
9 REPLIES 9
Message 2 of 10
Kent1Cooper
in reply to: mdhutchinson
@mdhutchinson wrote:
The code below collects empty blocks .... if an Xref is currently 'unloaded' it apparrently collects that too. I could probably just test to see if the block is an Xref and avoid it... but how could I modify this to check if it is loaded and still empty?
I don't see any difference between the VLA Properties for Xref's that are loaded or not, but I do in the entity data returned by (entget (tblobjname "block" "YourXrefName")).  If I Attach an Xref [Attachment method], while it's loaded, there's an entry like this:
(70 . 36)
but after I unload it, there are these:
(70 . 4) (71 . 1)
The 71-code entry is not present when it's loaded.
For an Overlay Xref, when it's loaded, it's:
(70 . 44)
and when it's unloaded, they're:
(70 . 12) (71 . 1)
So the presence of the 32 bit in the (assoc 70) value, which you can check for with (logand), indicates that it's loaded.  But since the 71-code exists at all only for an unloaded one, I would think you could, a little more simply, just check for whether anything is returned by:
(assoc 71 (entget (tblobjname "block" "YourXrefName")))
If that returns nil, it should be loaded, and you can check whether it's empty.  If that returns anything, or at least if it returns (71 . 1), it should be unloaded.  But I wouldn't guarantee that other complications might not result in some other 71-code value, so you might need to experiment.  I have a listing of DXF codes for Block table entries, and it explains the bit-code values for the 70-code entry [it says 32 means it's "resolved"], but it doesn't list a 71-code entry at all, so I could't say whether that might have other possible values.  Presumably if it might, there would be other binary bits representing something or other, so you might need to use (logand) on that, checking for the 1 bit, just to be sure.
Kent Cooper, AIA
Message 3 of 10
pbejse
(if (and (= 0 (vla-get-count block))
   (eq (vla-get-IsXref block) :vlax-false))
nullblocks
HTH
Message 4 of 10
mdhutchinson
in reply to: pbejse
Thanks!
This seems close - I have added this to the routine... however, I ONLY wanted to avoid the xref if it is currently 'Unloaded'.
As a side note: I discovered the code is getting the empty blocks that are within the xref too... or blocks that are xref dependant...  This is fine.
Is there a way to tell if the xref is 'Unloaded' ?
Message 5 of 10
Kent1Cooper
Carrying on with elements from my first Reply, something like this, perhaps [untested]:
(defun NullBlocks (/ *thisdwg* block bname bdata nullblocks)
  (vlax-for block (vla-get-blocks *thisdwg*); iterate block table
    (setq
      bname (vla-get-name block)
      bdata (tblsearch "block" bname)
    ); setq
    (if
      (and
        (= 0 (vla-get-count block)); no elements in definition
        (if (assoc 1 bdata); it's an Xref
          (= (logand 32 (cdr (assoc 70 bdata))) 32); then -- T if loaded, nil if unloaded
          T ; else -- it's a regular Block
        ); if
      ); and
      (setq nullblocks (cons bname nullblocks))
    ); if
  ); vlax-for
  nullblocks
); defun
Kent Cooper, AIA
Message 6 of 10
pbejse
Thanks!
(defun NullBlocks (/ block *thisdwg* block nullblocks bn)
    (setq bn (vla-get-Name block))
	     (not (vl-some '(lambda (o)
			      (vl-string-search o bn)
			   '("Space" "|")
      (setq nullblocks (cons bn nullblocks))
  nullblocks
Unloaded <---- linky
HTH
Message 7 of 10
pbejse
in reply to: Kent1Cooper
      (and
        ); if
); defun
watch out for Xref dependent blocks.
(assoc 1 bdata) <- nil
perhaps
(and
(setq flg (cdr (assoc 70 bdata)))
(zerop (boole 1 20 flg))
Message 8 of 10
Kent1Cooper
in reply to: pbejse
I think it should be OK as is [OP confirm?] -- to quote from the OP's Message 4:  "... the code is getting ... blocks that are xref dependant...  This is fine."
So my line for what to do if that test returns nil:
could say:
          T ; else -- it's a regular Block, either defined in this drawing or Xref-dependent
and if it also passed the emptiness test, its name will be put in the nullblocks list.
Kent Cooper, AIA
Message 9 of 10
pbejse
could say:
Good point. but Message 1 "... with the intent to delete them..."
No need to filter nullblocks list if automating the intent to delete the blocks
Message 10 of 10
Kent1Cooper
in reply to: pbejse
@pbejse wrote:
..... but Message 1 "... with the intent to delete them..."
I think some kind of filtering is needed because that they don't want to eliminate unloaded Xrefs.  I assume that's because they want to preserve their locations, scales, Layers, etc., and the ability to reload them without needing to attach/overlay them all over again.
But apparently, whether or not unloaded Xrefs actually contain anything, they are always interpreted as "empty" by the (vla-get-count) test, so without some kind of further check, it would put them in the list to eliminate.  They need a way to identify those probably-not-really-empty unloaded Xrefs, to distinguish them from really-empty ordinary Blocks and really-empty loaded Xrefs.  That distinction is to keep the routine from eliminating any unloaded Xrefs, even though they are considered "empty" Blocks, at least by the test that's being used.
Kent Cooper, AIA
”Boost
