0 Kudos
Post 1 of 3
clean BOM list in text
93 Views, 2 Replies
03-25-2009 11:05 PM
I have gotten this routine to collect the objects I want to have listed. However, when I get to where I want to have the BOM list created there is an issue. When I create the list, the text will simply all be on top of each other, or there may be one or two spots where the y point actually changes. I have also noticed this routine tends to be a little 'picky'. If I am zoomed into a small group of text and create the BOM, this routine works flawlessly. If I zoom out a bit and pick the exact same group of text, the BOM comes out wrong.
{code}
(defun c:hh ( / )
(princ "\nSelect Objects:")
(setq ss1 (ssget '((0 . "TEXT"))))
(setq sslen (sslength ss1))
(setq slst nil)
(setq sn 0)
(while (< sn sslen)
(setq sent (entget (ssname ss1 sn)))
(setq sid (cdr (assoc 1 sent)))
(setq slst (cons sid slst))
(setq sn (+ sn 1))
);while
(setq flst (countitem slst))
;; here is my issue area -------------------------------------------------------
(setq x (getpoint "\nPick point for BOM text list: "))
(setq bomptx (car x))
(setq bompty (cadr x))
;(setq ent nil)
(foreach ent flst
(setq qty (cdr ent))
(setq sid (car ent))
(setq bomline (strcat (itoa qty) " " sid))
(command ".text" (list bomptx bompty) "" "" bomline) (princ (list bomptx bompty))
(setq bompty (- bompty 12))
(princ)
;; end of issue code ---------------------------------------------
;;; Count item in a list
;;; Ex: (countitem '(1 2 "a" 1 3 "a"))
;;; Return: ((1 . 2) (2 . 1) ("a" . 2) (3 . 1))
(defun countitem (dolist / item result uniquelist)
(foreach item dolist
(if (not (member item uniquelist))
(setq uniquelist (append uniquelist (list item))
result (append result (list (cons item 1)))
(setq
result (subst (cons item (1+ (cdr (assoc item result))))
(assoc item result)
result
result
{code} Edited by: jaswild69 on Mar 26, 2009 6:11 AM
Active Contributor
0 Kudos
Post 2 of 3
Re: clean BOM list in text
03-26-2009 12:52 AM in reply to: jaswild69
did you turn osnaps off?
0 Kudos
Post 3 of 3
03-26-2009 08:55 PM in reply to: jaswild69
thanks, i feel retarded now.... :smileyvery-happy:
