For the change space, I've attached one that was written way back in
'93. It was originally posted to a newsgroup, although I don't recall
which one. I have not tested this in the newer versions, but I don't see
why it shouldn't work. Command is "CTOS", for Change To Other Space.
For the LAYISO, why not just write your own? I'll get you started:
(if (setq ent (entsel "\nSelect entity on layer to Isolate: "))
(progn
(setq lay (cdr (assoc 8 (entget (car ent)))))
(command "-layer" "s" lay "off" "*" "n" "")
(princ "\nNothing selected, try again....")
Good Luck!
Jeff
"yesby"
wrote in message news:40519c2c$1_2@newsprd01...
> Hi,
> Does anyone know of a free LISP routine that will emulate the CHSPACE
and
> LAYISO routine in Express Tools?
> Also would like to know of a routine that can make pick points snap to
> objects in 3D with the default elevation always being "0.0" without
having
> to specify the elevation, something with using coordinate filters .xy
> "pick point" and .z=0.
> Thanks
Attachment not added (content type not allowed): "CTOS.LSP"
