Check original color of layer in xref
21 REPLIES 21
Message 1 of 22
BMcAnney
425 Views, 21 Replies
Hello all,
I am looking for a way to access the original color of a layer an xref
drawing. For example, you have an xref in your drawing. In the drawing you
change the xref layer color to something else. What I want is to access the
original color, as it stands in the xref drawing currently.
Once I can do this, my goal is to create a quick lisp that will let me pick
a particular layer, and restore it to it's default xref color. Kind of like
setting VISRETAIN to zero for that particular layer, temporarily.
Anyone know how I would go about this?
Thanks!
Brent McAnney
21 REPLIES 21
Message 2 of 22
t.willey
in reply to: BMcAnney
The only way I can think of is to use ObjectDBX. I have one that changes all the layers back to the original color and linetype, but it will only work with 2004. You can change it to only work with a single pick.
If it's something you think you are interested in, let me know, and I can post it.
Tim
Message 3 of 22
BMcAnney
Although I know nothing of ObjectDBX, I am interested. However, we are
currently on 2000 (LD3), and upgrading to 2006 within a week. Am I out of
luck?
Thanks Tim,
Brent
wrote in message news:4944178@discussion.autodesk.com...
post it.
Tim
Message 4 of 22
t.willey
As far as I can go, yes. You can use ObjectDBX in the later versions, but I don't have the code to do it. If someone can post code to modify my code, then it can be all good. I can post the code as a learning tool for you though.
This code works as is here. I cannot guarantee anything.
Tim
(defun c:SetOrigLayerProps (/ ActDoc LayCol BlkCol Obj Name DwgPath ErrChk dbxRtn dbxLayCol tmpLayName tmpLay tmpEnt)
; Sets color and linetype to match the original drawing.
; First trys to make the linetype match whats in the drawing, if it's not in the drawing,
; then it matches it back to the xref drawing file.
; Subs 'tmw:OpenDBX 'tmw:CloseDBX 'MakeX
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq LayCol (vla-get-Layers ActDoc))
(setq BlkCol (vla-get-Blocks ActDoc))
(setvar "errno" 0)
(while (/= (getvar "errno") 52)
(if
(and
(setq tmpEnt (entsel "\nSelect Xref to copy back original layer properties: "))
(setq Obj (MakeX (car tmpEnt)))
(= (vla-get-ObjectName Obj) "AcDbBlockReference")
(= (vla-get-IsXref (vla-Item BlkCol (vla-get-Name Obj))) :vlax-true)
(progn
(setq Name (vla-get-Name Obj))
(setq DwgPath (vla-get-Path Obj))
(if (= (strcase DwgPath) (strcase (strcat (vl-filename-base DwgPath) ".dwg")))
(setq DwgPath (strcat (getvar "dwgprefix") DwgPath))
(setq dbxRtn (tmw:OpenDBX DwgPath))
(setq dbxLayCol (vla-get-Layers (car dbxRtn)))
(vlax-for Lay dbxLayCol
(setq LayName (vla-get-Name Lay))
(if (and (not (vl-string-search "|" LayName)) (/= LayName "0") (/= (strcase LayName) "DEFPOINTS"))
(progn
(setq tmpLayName (strcat Name "|" LayName))
(setq tmpLay (vla-Item LayCol tmpLayName))
(vla-put-Color tmpLay (vla-get-Color Lay))
(setq ErrChk (vl-catch-all-apply 'vla-put-Linetype (list tmpLay (vla-get-Linetype Lay))))
(if (vl-catch-all-error-p ErrChk)
(vl-catch-all-apply 'vla-put-Linetype (list tmpLay (strcat Name "|" (vla-get-LineType Lay))))
(tmw:CloseDBX dbxRtn T)
(prompt "\n No X-ref selected.")
(princ)
(defun tmw:OpenDBX (FileName / NewFileName TestIf dbxDoc)
(if FileName
(progn
(if (setq TestIf (open FileName "a"))
(close TestIf)
(progn
(setq NewFileName (strcat (vl-filename-directory FileName) "\\" (strcat "CopyOf-" (vl-filename-base FileName) ".dwg")))
(if (not (vl-file-copy FileName NewFileName))
(progn
(setq NewFileName (strcat "c:\\" (strcat "CopyOf-" (vl-filename-base FileName) ".dwg")))
(setq FileName NewFileName)
(setq dbxDoc (vla-GetInterfaceObject (vlax-get-ACAD-Object) "ObjectDBX.AxDbDocument.16"))
(vla-Open dbxDoc FileName)
(list dbxDoc FileName)
(defun tmw:CloseDBX (Results EraseFile / FileName)
(setq FileName (cadr Results))
(vlax-Release-Object (car Results))
(if
(and
(= EraseFile T)
(vl-string-search "CopyOf-" (vl-filename-base FileName))
(vl-file-delete FileName)
(defun MakeX (entname)
(vlax-ename->vla-object entname)
Message 5 of 22
Jeff Mishler has(had?) a VBA program to do this that's called
XREF-SYNC...pretty nifty. You'll have to search the NGs or contact him to
get it.
wrote in message news:4944152@discussion.autodesk.com...
Hello all,
Thanks!
Brent McAnney
Message 6 of 22
To use ObjectDBX in 2000/2002 just remove the .16 in the GetInterfaceObject
line.
And you must make sure it is registered with Windows:
(if (not (vl-registry-read
"HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID"))
(startapp "regsvr32.exe" (strcat "/s \"" (findfile "axdb15.dll") "\""))
HTH,
Jeff
wrote in message news:4944220@discussion.autodesk.com...
though.
Tim
the drawing,
(setvar "errno" 0)
(if
(and
properties: "))
(progn
".dwg")))
(progn
(princ)
(if FileName
(progn
(close TestIf)
(progn
(progn
FileName) ".dwg")))
(if
(and
(= EraseFile T)
Message 7 of 22
t.willey
Thanks Jeff.
Tim
Message 8 of 22
Hi Josh,
Thanks for the plug. However, mine changes the colors/linetypes/whatever
globally, not on a per layer basis. Although it could be modified to do so.
Jeff
"Josh" wrote in message
news:4944263@discussion.autodesk.com...
get it.
Message 9 of 22
I would be interested in this as well. On many occasions, I've run in to
the need to do pretty much the same thing. I've sometimes needed to do it
on all layers and sometimes on a couple layers. I've just never had the
time to sit down and try.
Maybe a good revision would be to have it take an argument which would be
the layer(s) to modify. You could specify * for all layers. Then if you
wanted to have a command whose only purpose was to change ALL layers, you
could have a seperate command that called the first one. That way you
wouldn't have double the code.
"Jeff Mishler" wrote in message
news:4944283@discussion.autodesk.com...
Hi Josh,
Jeff
get it.
Message 10 of 22
BMcAnney
Jeff and Tim,
Thank you very much, this is a great start. Unfortunately, the code is a bit
above my head at the moment, so I may have to put off trying to modify it to
work for picked layers only - but if anyone could point me in the right
direction (or modify the code, if it isn't too hard), that would be
excellent. I think this tool would be very useful
Thanks again guys,
Brent McAnney
news:4944281@discussion.autodesk.com...
line.
HTH,
Jeff
though.
Tim
the drawing,
(setvar "errno" 0)
(if
(and
properties: "))
(progn
".dwg")))
(progn
(princ)
(if FileName
(progn
(close TestIf)
(progn
(progn
FileName) ".dwg")))
(if
(and
(= EraseFile T)
Message 11 of 22
t.willey
I was thinking about doing that before, but "real" work has come up, so I can't do it right now. When I get a chance I can do it, but if anyone wants to try/do it in the mean time, my feelings won't be hurt.
Tim
Message 12 of 22
t.willey
Try this one.
Tim
tmpObj Opt LayName tmpLayName CurLay dbxLay)
; Sets color and linetype to match the original drawing. Either by single pick, or all layers per Xref.
(initget "All Single")
(setq Opt (getkword "\n Single layer, or All layers : "))
(setvar "errno" 0)
(if
(and
(setq tmpEnt (nentsel "\nSelect object within Xref to copy back original layer properties: "))
(setq Obj (MakeX (last (last tmpEnt))))
(if (> (length (last tmpEnt)) 1)
(setq tmpObj (MakeX (car (last tmpEnt))))
(setq tmpObj (MakeX (car tmpEnt)))
(progn
(if (= Opt "All")
(progn
(progn
(setq LayName (vla-get-Layer tmpObj))
(setq tmpLayName (substr LayName (+ 2 (vl-string-search "|" LayName))))
(setq CurLay (vla-Item LayCol LayName))
(setq dbxLay (vla-Item dbxLayCol tmpLayName))
(vla-put-Color CurLay (vla-get-Color dbxLay))
(setq ErrChk (vl-catch-all-apply 'vla-put-Linetype (list CurLay (vla-get-Linetype dbxLay))))
(vl-catch-all-apply 'vla-put-Linetype (list CurLay (strcat Name "|" (vla-get-LineType dbxLay))))
(princ)
Message 13 of 22
t.willey
Wow. That didn't come in at all.
Tim
(setvar "errno" 0)
(if
(and
(progn
(if (= Opt "All")
(progn
(progn
(princ)
Message 14 of 22
t.willey
Sorry. Didn't meant to post the second time, wanted a preview. I will attach a lisp file now, but it will only have the newly changed part.
I have tried serval different ways, but they all come up looking somewhat distorted.
Tim
Message 15 of 22
BMcAnney
Tim,
Thank you very much - This works beautifully, and will be a real time saver!
Thanks for all the help here and in the past - I really appreciate it.
Brent McAnney
wrote in message news:4944522@discussion.autodesk.com...
distorted.
Tim
Message 16 of 22
t.willey
You're welcome. It a tool I use also, and I like it.
Tim
Message 17 of 22
Funny. A few years ago I posted something which dealt with this topic. At the time,
no one paid much attention. And as far as I could tell (google searching) it hadn't
been addressed before.
Anyway, I think Autodesk should address the issue in the core application. You don't
need code to do it in Microstation.
Joe Burke
Hello all,
Thanks!
Brent McAnney
Message 18 of 22
I'm trying to work out the kinks in my version, only if I
had more time. (the reason I was posting about nested
xrefs the other day, which I still haven't had tim to get
back to, btw.)
I do agree that this should be part of the core program.
Autodesk Discussion Group Facilitator
"Joe Burke" wrote in message
news:4945248@discussion.autodesk.com...
the time,
hadn't
You don't
Joe Burke
Message 19 of 22
t.willey
It kind of is, with "visretain" and reloading, but IMO, it does too much. All I want to reload would be the color and the linetype. Maybe if I didn't plot bycolor, then I would want the plot style to get refreshed also, but for now I don't care about that stuff.
My 2 cents.
Tim
Message 20 of 22
Visretain works good if you want global settings,
doesn't work very well if all you want is a single
layer or maybe just a couple.
wrote in message news:4945339@discussion.autodesk.com...
My 2 cents.
Tim
”Boost
