Check number of attribute tags the same
2 REPLIES 2
andrewscott99
243 Views, 2 Replies
Hi there
How do i go about checking if there are 2 attribute tags call 'rev' in a block called 'DyerA1'...? I would like to alert the user if so.
Many Thanks
A
2 REPLIES 2
Kent1Cooper
in reply to: andrewscott99
In simplest terms, for only that block name and attribute tag:
{code}
(setq item (tblobjname "block" "DyerA1"))
(while (setq item (entnext item))
(if (= (cdr (assoc 2 (entget item))) "REV")
(if found1
(progn ; then - second one
(alert "DyerA1 contains more than one REV Attribute Tag.")
(quit)
); end progn
(setq found1 T) ; else - first one
); end if
); end if
); end while
{code}
That will also answer the same if there are three or more, not just if there are two.
It wouldn't be hard to make it [for instance] identify whether a Block definition has *any* duplicate Attribute Tags. Or it could announce *how many* REV Attribute Tags it contains [only one, or perhaps more than two]. It could be made not as a command but as a function, to take arguments for Block and Attribute Tag names, for more generalized use. Etc., etc.
Kent Cooper
andrewscott99 wrote...
Kent Cooper, AIA
Perfect, Thanks again! Only need it to check that one block.
A
”Boost
