In simplest terms, for only that block name and attribute tag:
{code}
(setq item (tblobjname "block" "DyerA1"))
(while (setq item (entnext item))
(if (= (cdr (assoc 2 (entget item))) "REV")
(if found1
(progn ; then - second one
(alert "DyerA1 contains more than one REV Attribute Tag.")
(quit)
); end progn
(setq found1 T) ; else - first one
); end if
); end if
); end while
{code}
That will also answer the same if there are three or more, not just if there are two.
It wouldn't be hard to make it [for instance] identify whether a Block definition has *any* duplicate Attribute Tags. Or it could announce *how many* REV Attribute Tags it contains [only one, or perhaps more than two]. It could be made not as a command but as a function, to take arguments for Block and Attribute Tag names, for more generalized use. Etc., etc.
Kent Cooper
andrewscott99 wrote...
How do i go about checking if there are 2 attribute tags call 'rev' in a block called 'DyerA1'...? I would like to alert the user if so.
Kent Cooper, AIA
