Visual LISP, AutoLISP and General Customization
Check if a file exists to choose YES in the SAVE
2 REPLIES 2
gustavobernardi
675 Views, 2 Replies
Hello, I'm creating a system that creates additional autosave files. In the first SAVE okay, the problem is when I save the file again, the prompt checks with yes and no if I want to overwrite the file. My wish is that if the file already exists can answer yes automatically. (defun salvameubackup() (setq ringobackupname (strcat (getvar "dwgprefix") "backup_"(getvar "dwgname"))) (command "._save" ringobackupname) ) TIA
2 REPLIES 2
Try by changing the code like this.
(if (findfile ringobackupname);check if the file exists
(command "._save" ringobackupname "yes");if file exists then replace it
);if
);defun
Here's what I do in a similar situation, which avoids the need to check whether the file exists:  I just include the "Yes" answer in the Save command.  The first time a drawing is saved that way, the command doesn't ask whether it should be replaced, the "Yes" goes in as if it were a command, and an unknown-command message goes by at the Command: prompt line, but it doesn't interfere with anything.  Then for all subsequent saves under the same name, the question is asked, and the "Yes" is there to answer it.
Kent Cooper, AIA
”Boost
