Hi everybody ,
I have a big problem and i ask you help me, please!!!
I have a block with:
tag1: XX
tag2: YYYYYY
tag3: ZZZZZZZZ
I have an external file check.txt with string:
XXYYYYYYZZZZZZZZ
I would like to create a lisp program that check the attributes of block using an external database, if tag1+tag2+tag3 = XXYYYYYYZZZZZZZZ ok end program, if not make a circle on block :
Thanks-you very much
AcciaioSteel
Are it ?
tag1: XX
tag2: YYYYYY
tag3: ZZZZZZZZ
textstring that mean numbers, or letters
Please ubload a sample DWG , or send it off line , see attached file
@AcciaioSteel wrote:Hi everybody ,
tag1: XX
tag2: YYYYYY
tag3: ZZZZZZZZ
XXYYYYYYZZZZZZZZ
AcciaioSteel
Sounds easy enough. What does the text file contents look like? If it is as vague as you have posted XXYYYYYYZZZZZZZZ , how'd you know where the second and third tag value start and end? If the length of string per tag value is constant ,then its easy cheesy.
Provide more ino AcciaioSteel
@pbejse wrote:Provide more ino AcciaioSteel
info provided thru PM
...it is possible make the circle on new layer named "$01Check" with yellow color?
HYG
(defun c:CirBlk ( / file of data ss Bdata e ll ur str) (vl-load-com) (if (not (tblsearch "Layer" "$01Check")) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 "$01Check") (cons 70 0)(cons 62 5)))) (cond ((and (setq data nil file (getfiled "Select text file" (getvar 'dwgprefix) "txt" 16)) (progn (setq of (open file "r")) (while (setq a (read-line of)) (setq data (cons a data)) ) (close of) data ) (setq ss (ssget "_x" '((0 . "INSERT")(66 . 1)(2 . "sample")))) (repeat (setq i (sslength ss)) (setq str "" Bdata (last (mapcar '(lambda (j) (if (member (vla-get-tagstring j) '("TAG1" "TAG2" "TAG3")) (setq str (strcat str (strcase (vla-get-textstring j)))))) (vlax-invoke (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i))))) 'GetAttributes)))) (if (not (member Bdata Data)) (progn (vla-getboundingbox e 'll 'ur) (entmakex (list (cons 0 "CIRCLE") (cons 10 (mapcar (function (lambda (a b) (/ (+ a b) 2.))) (vlax-safearray->list ll) (vlax-safearray->list ur) ) ) (cons 8 "$01Check") (cons 40 (* (distance (vlax-safearray->list ll) (vlax-safearray->list ur)) 0.5)))) ) ) ) ) ) ) (princ) )
