Hi everybody,
I want to creat a table with all characters inside a font.
I used "%%" to change a number to it's character.
but "%%" limited to 999 and for numbers bigger than 999 it doesn't work.
also, CHR command limited to 255 and for numbers bigger than 255 it change to (number-255).
so I used "%%" to create this table:
[Please change default font in your AutoCAD to ARIAL]
(Defun c:charmap ()
(setvar "cmdecho" 0)
(setq cnt 1.0)
(setq r_cnt 0.0)
(setq ts 32)
(setq x 0.0)
(setq y 0.0)
(setq sub_y (- y 0.1))
(command "layer" "m" "textfont" "c" "2" "" "")
(repeat ts
(while (<= (fix cnt) (+ r_cnt ts))
(setq pt (list x y))
(setq sub_pt (list x sub_y))
(command "text" "m" pt "0.05" "0" (strcat "%%" (rtos cnt 2 0)))
(command "text" "m" sub_pt "0.05" "0" (rtos cnt 2 0))
(setq x (+ x 0.2))
(setq cnt (+ cnt 1.0))
(setq r_cnt (+ r_cnt ts))
(setq x 0)
(setq y (- y 0.2))
(command "zoom" "e")
(command "zoom" "0.75x")
I want to know:
1- what can I do for numbers more than 999?
2- How can I know the number of characters inside a font?
3-how can improve my LISP program to have complete characters inside the fonts?
the "%%" prefix 'function' is exist to let you 'see' a character that does not exist in KB
like %%d, %%c , %%p
if i understand you? you do not need to use "%%" instead just loop thought the ascii code
as far as i know true type fonts can have at top 2^16 charachters (= 65536)
(setq i 32)
(while (< i 65536)
(setq i (1+ i))
(princ (strcat "\n" (rtos i 2 0) "=" (chr i)))
but this does not give you what is really inside the font file. ttf file (also shx) can not be accessed by
autolisp cause they are not ascii files. i have already seen fonts file (especialy shx files) that does
not have all the ascii characters. trying to access them will create '?' or undefined shape xxxx.
Moshe
I did it. It was very complicated!
you can see all 65536 charactes in ARIAL fonts!
Because of limiting in size of uploading file in this forums(1.5MB) I uploaded in another website:
https://hotfile.com/dl/187672235/45357e3/CharMap_Arial_Font.7z.html
(size: 2.8MB)
