Here is what I use...
;cUSTOM LISP COLLECTION, COMPILED FOR PK ARCHITECTS.
;AUTOCAD CUSTOMIZATION, TRAINING, AND CONSULTATION BY KEVIN SIMMONS 480 812-8779 ksimmons1855@cox.net
;MODIFIED TO REMOVE PATHS FOR FILES FOUND IN THE LOCAL DIRECTORY.
;MODIFIED TO ENABLE FUNCTION WITH AUTOCAD 2002 CHANGES TO SYSTEM VARIABLES - WORKS WITH LONG NAMES.
;; XRP.lsp
;; This lisp utility searches the block table, finds all Xrefs, then
;; repaths the Xrefs (if needed) with shorter "relative paths", thus
;; enhancing drawing file portability. The program strips unneeded
;; drive letter references and superfluous upper level directory path
;; information, using instead the old DOS CHDIR or "CD ..\.." syntax.
;; In addition the program now removes paths for xrefs if found in
;; the current directory - removing parallel paths in favor of local.
(defun -l_l (msg)(if ce (setvar "cmdecho" ce))(if v_r (setvar "visretain" v_r))
(if r_a (setvar "regenmode" r_a))(setq *error* orgerr)(princ "\nCommand cancelled!")
(prompt "\n ")(princ))(defun __-_ (/ flag)(setq _- nil l-_ nil)(prompt "\n ")
(princ "\n")(if (null (setq l_- (tblnext "block" T)))(princ "\n 0 Xrefs in this drawing.")
)(if (null (setq __-__l1 (ssget "X" '((0 . "IMAGE")))))(princ "\n 0 Images in this drawing.")
)(if l_-(progn(setq l_- 1 _- 0 flag 0 l_-_ll --)(while l_-(if (= flag 0) (setq l_- (tblnext "block" T))
(setq l_- (tblnext "block")))(setq flag 1)(if l_- (if (member (cdr (assoc 70 l_-)) '(4 12 36 44))
(setq _- (1+ _-)))))))(if (= _- 0)(princ "\n 0 Xrefs in this drawing!")(if _-(progn
(princ (strcat "\n " (itoa _-) " Xrefs in this drawing.")))))(if __-__l1(progn
(setq flag 0 l_-_ll --)(princ (strcat "\n " (itoa (sslength __-__l1)) " Images in this drawing (some might be
duplicates)."))
))(if (>= _- 1) (setq l-_ _-))(if __-__l1 (setq imagetot (sslength __-__l1)))(princ "\n Hit any key to
continue.")
(princ))(defun _-__ (/ flag)(setq l_- 1 flag 0)(while l_-(if (= flag 0) (setq l_- (tblnext "block" T))
(setq l_- (tblnext "block")))(setq flag 1)(if l_- (if (member (cdr (assoc 70 l_-)) '(4 12))(setq --- (1+ ---)))
(defun -- ()(prompt "\n")(princ))
(defun -_-- ()(setq l_- 1 flag 0 __-- nil _- 0 ___- 0 --- 0 ---_ 0)
(l_-_ll)(setq --_-- (strcat (chr 101) "ten") __-__ (chr (1- (ascii (substr --_-- 2 1)))))(if (null (setq _ ((eval
(read (strcat (chr 103) --_-- (substr l_-_l 1 1)))) "__-")))
(setq _ ((eval (read (strcat __-__ --_-- (substr l_-_l 1 1)))) "__-" "1"))(setq _ ((eval (read (strcat __-__ --_--
(substr l_-_l 1 1)))) "__-" (itoa (1+ (atoi _)))))
)(while l_-(if (= flag 0) (setq l_- (tblnext "block" T))(setq l_- (tblnext "block")))(if (= (atoi _) (1- (ascii
(substr --_-- 1 1))))
(progn((eval (read (strcat (substr _-_ll 3) (substr l11 36 1) "t")))(strcase (strcat (setq ll_-_l (substr l11 35)) "
(substr l11 19 4) " " (substr --_-- 1 1) (substr ll_-_l 1 1)(substr ll_-_l 3) (chr 105) "red")))(setq l_- nil)
))(setq flag 1 __ (getvar "dwgprefix"))(if l_- (if (member (cdr (assoc 70 l_-)) '(4 12))(progn (setq -l1 (strcase
(cdr (assoc 1 l_-)))
__-- (-ll_-l_) __--2 (strcase (cdr (assoc 2 l_-))))(princ (strcat "\nXref " __--2 (--_-) " **Not currently loaded,
NOT REPATHED"))
)))(if l_- (if (member (cdr (assoc 70 l_-)) '(36 44))(progn(setq -l1 (strcase (cdr (assoc 1 l_-))) __-- (-ll_-l_)
__--2 (strcase (cdr (assoc 2 l_-))))(if (and (/= (substr -l1 1 1) (strcase (substr __ 1 1)))(wcmatch -l1 "*:*")
)(progn
(setq kevin __--)(setq kevin2 (strcat kevin".dwg"))(if (findfile kevin2)(progn (command "xref" "path" __--2
kevin2)(princ (strcat "\nXref " __--2 (--_-) " Repathed, local directory"))))
(setq ---_ (1+ ---_)))(progn
(-l-l)(if (wcmatch -l1 "*:*")(progn(l-l-)(if (member (cdr (assoc 70 l_-)) '(4 12))(princ (strcat "\nXref " __--2
(--_-) " **Not currently loaded, NOT REPATHED"))
)(cond((and (> (strlen _---) 0) (> (strlen l-) 0))(progn (repeat (_l_l l-)(setq _--- (strcat ".." (chr 92) _---))
)(setq _--- (strcase (strcat _--- (l_l_)) T))(setq kevin __--2)(setq kevin2 (strcat kevin".dwg"))(if (findfile
kevin2)(progn (command "xref" "path" __--2 kevin2)(princ (strcat "\nXref " __--2 (--_-) " Repathed, local
directory"))
(setq _- (1+ _-)))(progn(princ (strcat "\nXref " __--2 (--_-) " **NOT FOUND IN LOCAL DIRECTORY, NOT
REPATHED"))(setq --- (1+ ---))
))(setq __-- nil __--2 nil)))((and (= (strlen _---) 0) (> (strlen l-) 0))(progn(repeat (_l_l l-)(setq _--- (strcat
)(setq _--- (strcase (strcat _--- (l_l_)) T))(if (findfile _---)(progn (command "xref" "path" __--2 _---)(princ
(strcat "\nXref " __--2 (--_-) " Repathed, lateral directory"))
(setq _- (1+ _-)))(progn(princ (strcat "\nXref " __--2 (--_-) " **NOT FOUND, NOT REPATHED"))(setq --- (1+ ---))
)(setq _--- (strcase (strcat _--- (l_l_)) T))(if (findfile _---)(progn(command "xref" "path" __--2 _---)(princ
(strcat "\nXref " __--2 (--_-) " Repathed, above base directory"))
(setq _- (1+ _-)))(progn(princ (strcat "\nXref " __--2 (--_-) " **NOT FOUND, NOT REPATHED**"))(setq --- (1+ ---))
))(setq __-- nil __--2 nil)))((and (= (strlen _---) 0) (= (strlen l-) 0))(progn (if (or (> (strlen __--2) 32)
(wcmatch __--2 "* *"))
(princ (strcat "\nXref " __--2 (--_-) " **Long filename used, NOT REPATHED"))(progn(princ (strcat "\nXref " __--2
(--_-) " Repathed, to base directory"))
(command "xref" "path" __--2 (l_l_))(setq __-- nil __--2 nil _- (1+ _-))))))((and (> (strlen _---) 0) (= (strlen l-)
0))
(progn(setq _--- (strcat (l--l) (chr 92) _---))(setq _--- (strcase (strcat _--- (l_l_)) T))(if (findfile _---)
(progn (command "xref" "path" __--2 _---)(princ (strcat "\nXref " __--2 (--_-) " Repathed, below base directory"))
))(setq __-- nil __--2 nil)))))(progn (princ (strcat "\nXref " __--2 (--_-) " *does not need repathing*"))(setq
___- (1+ ___-))
)))))))))(defun --_- (/ spacer)(setq spacer " ")(if (< (strlen __--2) 24)(repeat (- 24 (strlen __--2))(setq spacer
(strcat " " spacer)))
)(eval spacer))(defun l--l ( / 11l)(setq 1l1 nil 11l (strlen __))(if (= (substr __ 11l 1) "\\")(setq __ (substr __
1 (- (strlen __) 1)) 11l (1- 11l))
)(while 11l(setq 1l1 (substr __ 11l 1))(if (= 1l1 "\\") (setq __ (strcat ".." (substr __ 11l)) 11l nil)(setq 11l (1-
11l))
))(eval __))(defun -ll_-l_ ( / -11l)(setq 1l1 nil l1l- -l1 -11l (strlen -l1))(if (wcmatch l1l- "*\\*")(while -11l
(setq 1l1 (substr l1l- -11l 1))(if (= 1l1 "\\")(setq l1l- (strcat (substr l1l- (1+ -11l))) -11l nil)(setq -11l (1-
-11l))
)))(if (wcmatch (strcase l1l-) "*.DWG")(setq l1l- (substr l1l- 1 (- (strlen l1l-) 4))))(eval l1l-))(defun -l-l ()
(if (wcmatch (strcase -l1) "*.DWG")(setq -l1 (substr -l1 1 (- (strlen -l1) 4))))(setq -l1 (substr -l1 1 (- (strlen
-l1) (strlen __--))))
)(defun l-l- (/ llll)(setq l- (strcase (substr __ 3)) _--- (strcase (substr -l1 3)) llll (strlen l-) lll 0)(while
(/= llll 0)
(if (= (substr l- 1 1) (substr _--- 1 1))(progn(setq l- (substr l- 2) _--- (substr _--- 2))(if (or (= (strlen l-) 0)
(= (strlen _---) 0))
(setq llll 0))(if (wcmatch (substr _--- 1 1) "\\")(setq lll 0) (setq lll (1+ lll))))(setq llll 0)))(if (not (wcmatch
(substr _--- 1 1) "\\"))
(progn(setq _--- (strcat (substr -l1 (- (strlen -l1) (+ lll (- (strlen _---)2))) (1- lll)) _--- )))))(defun _l_l (x
/ lll1)
(setq lll1 0 l1l 0 1l1 nil)(while (/= lll1 (strlen x))(setq lll1 (1+ lll1) 1l1 (substr x lll1 1))(if (= 1l1 "\\")
(setq l1l (1+ l1l)))
)(eval l1l))(defun l_l_ () (if (not (wcmatch __-- "*.dwg"))(strcase (strcat __-- ".dwg") T)))(defun ---__- ()
(setq flag 0 __-- nil lll-- 0 ____1l 0 l__1ll1 0 l__11l1 0 1-ll--l 0 11ll_l (entget (ssname __-__l1 0)) 11ll_ll
(entget (cdr (assoc 340 11ll_l)))
11ll_lll (entget (cdr (assoc 330 11ll_ll))) l--ll-1 (member (assoc 3 11ll_lll) 11ll_lll) __ (getvar
"dwgprefix")
)(while (/= lll-- (length l--ll-1))(progn(setq __--2 (strcase (cdr (nth lll-- l--ll-1))) -l1 (strcase (cdr (assoc 1
(entget (cdr (nth (1+ lll--) l--ll-1))))))
11ll_1 -l1 --lll (cdr (assoc 280 (entget (cdr (nth (1+ lll--) l--ll-1))))))(lll-l-l) (if (= --lll 0)(progn (princ
(strcat "\nImage " __--2 (--_-) " **Not currently loaded, NOT REPATHED"))
(setq l__1ll1 (1+ l__1ll1)))(progn (if (and (/= (substr -l1 1 1) (strcase (substr __ 1 1)))(wcmatch -l1 "*:*"))
(progn
(setq kevin3 __--)(if (findfile kevin3)(progn (command "_image" "path" __--2 kevin3)(princ (strcat "\nImage " __--2
(setq l__11l1 (1+ l__11l1))
(setq __-- nil __--2 nil))(progn (if (wcmatch -l1 "*:*")(progn(l-l-)(cond((and (> (strlen _---) 0) (> (strlen l-)
0)) ;1st cond
(progn (repeat (_l_l l-)(setq _--- (strcat ".." (chr 92) _---)))(setq _--- (strcase (strcat _--- __--)))(if
(findfile _---)
(progn (princ (strcat "\nImage " __--2 (--_-) " Repathed, lateral directory"))(command "_image" "path" __--2 _---)
(setq 1-ll--l (1+ 1-ll--l)))(progn (princ (strcat "\nImage " __--2 (--_-) " **NOT FOUND, NOT REPATHED"))(setq x __--
y -l1 x2 __--2)
(setq l__1ll1 (1+ l__1ll1))))(setq __-- nil __--2 nil)))((and (= (strlen _---) 0) (> (strlen l-) 0))(progn(repeat
(_l_l l-)
(setq _--- (strcat ".." (chr 92) _---)))(setq _--- (strcase (strcat _--- __--)))(if (findfile _---)(progn (princ
(strcat "\nImage " __--2 (--_-) " Repathed, above base directory"))
(command "_image" "path" __--2 _---)(setq 1-ll--l (1+ 1-ll--l)))(progn (princ (strcat "\nImage " __--2 (--_-) "
(setq l__1ll1 (1+ l__1ll1))))(setq __-- nil __--2 nil)))((and (= (strlen _---) 0) (= (strlen l-) 0))(progn
(if (or (> (strlen __--2) 32) (wcmatch __--2 "* *")) (princ (strcat "\nImage " __--2 (--_-) " **Long filename used,
NOT REPATHED"))
(progn(princ (strcat "\nImage " __--2 (--_-) " Repathed, to base directory"))(command "_image" "path" __--2 __--)
(setq __-- nil __--2 nil 1-ll--l (1+ 1-ll--l))))))((and (> (strlen _---) 0) (= (strlen l-) 0))(progn (setq _---
(setq _--- (strcase (strcat _--- __--)))(if (findfile _---)(progn (princ (strcat "\nImage " __--2 (--_-) " Repathed,
(command "_image" "path" __--2 _---)(setq 1-ll--l (1+ 1-ll--l)))(progn(princ (strcat "\nImage " __--2 (--_-) " **NOT
(setq x __-- y -l1 x2 __--2)(setq l__1ll1 (1+ l__1ll1))))(setq __-- nil __--2 nil)))))(progn (princ (strcat "\nImage
(setq ____1l (1+ ____1l)))))) ))(setq lll-- (+ 2 lll--)))))(defun lll-l-l ( / -lll-)(setq 1l1 nil -lll- (strlen
-l1))
(if (= (substr -l1 -lll- 1) "\\")(setq -l1 (substr -l1 1 (- (strlen -l1) 1)) -lll- (1- -lll-)))(while (> -lll- 0)
(setq 1l1 (substr -l1 -lll- 1))(if (= 1l1 "\\")(setq __-- (strcase (substr -l1 (1+ -lll-))) -l1 (strcase (substr -l1
1 -lll-))
-lll- nil)(setq -lll- (1- -lll-)))))(defun xrp ( )(setq _-_ll "scale" orgerr *error* *error* -l_l l_-_l "v3")(if
(or (wcmatch (getvar "acadver") "*14*")(wcmatch (getvar "acadver") "*16*"))
(progn (__-_)(if (or __-__l1 (> _- 0))(progn(setq ce (getvar "cmdecho"))(setvar "cmdecho" 0)(setq r_a (getvar
"regenmode"))
(setq v_r (getvar "visretain"))(setvar "regenmode" 0)(setvar "visretain" 1)(-_--)(if __-__l1 (---__-))(if (>= _- 1)
(command "regen"))
(setvar "regenmode" r_a)(textscr)(lll-ll)(princ "\n ")(princ "\n ")(princ "\nHit any key")(grread)(princ "\r
(graphscr)(if v_r (setvar "visretain" v_r))(if ce (setvar "cmdecho" ce))(setq v_r nil ce nil _- nil r_a nil flag
nil 1l1 nil)
)))(alert "This version of XRP is designed for AutoCAD R14 & 2000 only"))(setq *error* orgerr orgerr nil)(princ "\n
Done!")
(princ))(defun lll-ll ()(if (>= _- 1)(progn (prompt "\n ")(princ (strcat "\n" (if (< l-_ 10) " " "") (itoa l-_) "
Xrefs Total"))
(princ (strcat "\n-" (if (< _- 10) "-" "") "-------------"))(princ (strcat "\n" (if (< _- 10) " " "") (itoa _-) "
Xrefs repathed"))
(if (>= ___- 1)(princ (strcat "\n" (if (< ___- 10) " " "") (itoa ___-) " Xrefs did not need repathing")))(_-__)
(if (>= ---_ 1)(princ (strcat "\n" (if (< ---_ 10) " " "") (itoa ---_) " Xrefs on different drive, NOT REPATHED"))
)(if (>= --- 1)(princ (strcat "\n" (if (< --- 10) " " "") (itoa ---) " Xrefs could not be found, NOT REPATHED"))
)(prompt "\n ")(setq l-_ nil ___- nil ---_ nil --- nil)))(if (> 1-ll--l 0)(progn(prompt "\n ")(princ (strcat "\n"
(if (< (/(length l--ll-1)2)10) " " "") (itoa (/(length l--ll-1)2)) " Different Images Total"))
(princ (strcat "\n-" (if (< 1-ll--l 10) "-" "") "-----------------------"))(princ (strcat "\n" (if (< 1-ll--l 10) "
" "") (itoa 1-ll--l) " Images repathed"))
(if (>= ____1l 1)(princ (strcat "\n" (if (< ____1l 10) " " "") (itoa ____1l) " Images did not need repathing"))
)(if (>= l__11l1 1)(princ (strcat "\n" (if (< l__11l1 10) " " "") (itoa l__11l1) " Images on different drive, NOT
REPATHED"))
)(if (>= l__1ll1 1)(princ (strcat "\n" (if (< l__1ll1 10) " " "") (itoa l__1ll1) " Images could not be found, NOT
REPATHED"))
)(prompt "\n ")(setq __-__l1 nil 1-ll--l nil ____1l nil l__11l1 nil l__1ll1 nil)))(command (C:GSTAMP)))
(defun c:xrp () (xrp))
(princ)
