Visual LISP, AutoLISP and General Customization
Changing XREF layer colors in a tool
10 REPLIES 10
Message 1 of 11
Mr.Hella
1163 Views, 10 Replies
Does anyone in the group know how to edit the string below so that it will ignore all layer names starting with "E-". I want to change all XREFED layers in the current dwg. to 161 but ignore all XREFED layer names that start with E- such as E-lighting, E-power etc.
Thanks in advance
M.
^C^C-layer;c;161;*|*;
10 REPLIES 10
Message 2 of 11
hmsilva
in reply to: Mr.Hella
mhlr,
try
^C^C-layer;c;161;*|[~e-]*;;
Henrique
Message 3 of 11
Mr.Hella
in reply to: hmsilva
Henrique,
THANK YOU VERY MUCH!! this is perfect. Forgive me! I have very little knowledge of Lisp as you could imagine since I've posted these questions! in your opinion, what would be the best way to learn how to do this on my own??
Thanks again,
M.
Message 4 of 11
hmsilva
mhlr,
try the Acad Customization Guide
under DIESEL,
or just google "acad diesel tutorial"
for  Lisp see the Acad Customization Guide,
and see google "afralisp"
Cheers
Henrique
Message 5 of 11
pbejse
Also consider looking up wcmatch function for wild-card pattern match. ..e.g. *|[~e-]*
HTH
Message 6 of 11
erod714
Is it possible to get a pop up to select my own color instead of a color designated?
Message 7 of 11
ronjonp
in reply to: erod714
Try this: (acad_colordlg 1)
Message 8 of 11
erod714
in reply to: ronjonp
Thanks it worked!
Message 9 of 11
ronjonp
Glad to help.
Message 10 of 11
erod714
Do you have a command line series for changing a selected xref's layer color and linetype?  I'm trying to change the color and linetype of an xref layer only.  (Ex. I only want to change the xref existing water color and linetype by selecting the line) I know it can be done with through the layer properties, but I'm trying to make a customized button.
Message 11 of 11
ronjonp
HERE is a recent post that will change a layer color by pick. Perhaps you can modify it to apply a linetype too?
If these layer names have something in common like *DEMO*, you could use the -layer command and apply a color and linetype based on a wildcard match with no picking necessary.
Command: -LAYER
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: c
New color [Truecolor/COlorbook] : 1
Enter name list of layer(s) for color 1 (red) <0>: *demo*
”Boost
