I am looking for a way to change the text style used by a table style with Visual LISP. So far I have been able to get the IAcadTableStyle object from the acad_tablestyle dictionary, but there is no property for text style. Is this even possible? Code and results are below.
Mark
(defun DumpTableStyles ()
(setq dict (vla-get-dictionaries (vla-get-activedocument(vlax-get-acad-object))))
(setq TableStyles (vla-item dict "acad_tablestyle"))
(vlax-for TableStyle TableStyles
(vlax-dump-object TableStyle)
; IAcadTableStyle: AutoCAD IAcadTableStyle Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 0000000140d391d8>
; BitFlags = 0
; Description = "Standard"
; Document (RO) = #<VLA-OBJECT IAcadDocument 000000002813de30>
; FlowDirection = 0
; Handle (RO) = "1D"
; HasExtensionDictionary (RO) = -1
; HeaderSuppressed = 0
; HorzCellMargin = 0.06
; Name = "Standard"
; NumCellStyles (RO) = 3
; ObjectID (RO) = 44
; ObjectID32 (RO) = 44
; ObjectName (RO) = "AcDbTableStyle"
; OwnerID (RO) = 42
; OwnerID32 (RO) = 42
; TemplateId = 0
; TemplateId32 = 0
; TitleSuppressed = 0
; VertCellMargin = 0.06
T
Solved by kefer_kb. Go to Solution.
it's easy with pure lisp:
(entget (cdr (assoc 350 (dictsearch (namedobjdict) "ACAD_TABLESTYLE"))))
(-1 . <Objektname: 7ffff75ad60>)
(0 . "TABLESTYLE")
(5 . "11FE")
(102 . "{ACAD_REACTORS")
(330 . <Objektname: 7ffff75ab20>)
(330 . <Objektname: 7ffff75adb0>)
(102 . "}")
(100 . "AcDbTableStyle")
(280 . 0)
(3 . "Standard")
(70 . 0)
(71 . 0)
(40 . 1.5)
(41 . 1.5)
(280 . 0)
(281 . 0)
(7 . "neutextstil")
(140 . 4.5)
(170 . 2)
(62 . 0)
(63 . 7)
(283 . 0)
(90 . 512)
(91 . 0)
(1 . "")
(274 . -2)
(284 . 1)
(64 . 0)
(275 . -2)
(285 . 1)
(65 . 0)
(276 . -2)
(286 . 1)
(66 . 0)
(277 . -2)
(287 . 1)
(67 . 0)
(278 . -2)
(288 . 1)
(68 . 0)
(279 . -2)
(289 . 1)
(69 . 0)
(7 . "STANDARD")
(140 . 6.0)
(170 . 5)
(62 . 0)
(63 . 7)
(283 . 0)
(90 . 512)
(91 . 0)
(1 . "")
(274 . -2)
(284 . 1)
(64 . 0)
(275 . -2)
(285 . 1)
(65 . 0)
(276 . -2)
(286 . 1)
(66 . 0)
(277 . -2)
(287 . 1)
(67 . 0)
(278 . -2)
(288 . 1)
(68 . 0)
(279 . -2)
(289 . 1)
(69 . 0)
(7 . "STANDARD")
(140 . 4.5)
(170 . 5)
(62 . 0)
(63 . 7)
(283 . 0)
(90 . 512)
(91 . 0)
(1 . "")
(274 . -2)
(284 . 1)
(64 . 0)
(275 . -2)
(285 . 1)
(65 . 0)
(276 . -2)
(286 . 1)
(66 . 0)
(277 . -2)
(287 . 1)
(67 . 0)
(278 . -2)
(288 . 1)
(68 . 0)
(279 . -2)
(289 . 1)
(69 . 0)
DXF-Code no. 7 is the name for textstyle to title, header and data.
e.g.: 'neutextstil' is textstyle for data entries.
kind regards,
Franz
