Hi everyone!
Does anyone know where i can get a lisp routine on how to change xref files base point to WCS (0,0,0) all at once? Your help is highly appreciated.
I don't need to move it to 0,0 only to change base point (xref's must to remain in old places)
Solved by igal1971. Go to Solution.
Solved by marko_ribar. Go to Solution.
Smething like this link :
http://www.lee-mac.com/changeblockinsertion.html
Try it with xrefs, should work the same as with blocks...
thank you Marko it's work great but lisp work only in one xref per session and i have a least 46 xref's and want to change it all at once How to do it?
Try this mod... Untested though...
;; Retains Xref Reference Position (defun c:cxpr ( / ss entlst ) (prompt "\nSelect Xref entities to process changing insertion points to WCS origin while retaining their position...") (setq ss (ssget '((0 . "INSERT")))) (setq entlst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach ent entlst (if (eq (vla-get-isxref (vla-item (vla-get-blocks (LM:acdoc)) (LM:blockname (vlax-ename->vla-object ent)))) :vlax-true) (LM:changeblockbasepoint t ent) ) ) (princ) ) ;;----------------------------------------------------------------------;; (defun LM:changeblockbasepoint ( flg ent / *error* bln cmd lck mat nbp vec ) (defun *error* ( msg ) (foreach lay lck (vla-put-lock lay :vlax-true)) (if (= 'int (type cmd)) (setvar 'cmdecho cmd)) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (and (= 'ename (type ent)) (setq nbp '(0.0 0.0 0.0))) (progn (setq mat (car (revrefgeom ent)) vec (mxv mat (mapcar '- (trans nbp 1 0) (trans (cdr (assoc 10 (entget ent))) ent 0))) bln (LM:blockname (vlax-ename->vla-object ent)) ) (LM:startundo (LM:acdoc)) (vlax-for lay (vla-get-layers (LM:acdoc)) (if (= :vlax-true (vla-get-lock lay)) (progn (vla-put-lock lay :vlax-false) (setq lck (cons lay lck)) ) ) ) (vlax-for obj (vla-item (vla-get-blocks (LM:acdoc)) bln) (vlax-invoke obj 'move vec '(0.0 0.0 0.0)) ) (if flg (vlax-for blk (vla-get-blocks (LM:acdoc)) (if (= :vlax-false (vla-get-isxref blk)) (vlax-for obj blk (if (and (= "AcDbBlockReference" (vla-get-objectname obj)) (= bln (LM:blockname obj)) (vlax-write-enabled-p obj) ) (vlax-invoke obj 'move '(0.0 0.0 0.0) (mxv (car (refgeom (vlax-vla-object->ename obj))) vec)) ) ) ) ) ) (if (= 1 (cdr (assoc 66 (entget ent)))) (progn (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (vl-cmdf "_.attsync" "_N" bln) (setvar 'cmdecho cmd) ) ) (foreach lay lck (vla-put-lock lay :vlax-true)) (vla-regen (LM:acdoc) acallviewports) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; RefGeom (gile) ;; Returns a list whose first item is a 3x3 transformation matrix and ;; second item the object insertion point in its parent (xref, block or space) (defun refgeom ( ent / ang enx mat ocs ) (setq enx (entget ent) ang (cdr (assoc 050 enx)) ocs (cdr (assoc 210 enx)) ) (list (setq mat (mxm (mapcar '(lambda ( v ) (trans v 0 ocs t)) '( (1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0) ) ) (mxm (list (list (cos ang) (- (sin ang)) 0.0) (list (sin ang) (cos ang) 0.0) '(0.0 0.0 1.0) ) (list (list (cdr (assoc 41 enx)) 0.0 0.0) (list 0.0 (cdr (assoc 42 enx)) 0.0) (list 0.0 0.0 (cdr (assoc 43 enx))) ) ) ) ) (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0) (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx)))))) ) ) ) ;; RevRefGeom (gile) ;; The inverse of RefGeom (defun revrefgeom ( ent / ang enx mat ocs ) (setq enx (entget ent) ang (cdr (assoc 050 enx)) ocs (cdr (assoc 210 enx)) ) (list (setq mat (mxm (list (list (/ 1.0 (cdr (assoc 41 enx))) 0.0 0.0) (list 0.0 (/ 1.0 (cdr (assoc 42 enx))) 0.0) (list 0.0 0.0 (/ 1.0 (cdr (assoc 43 enx)))) ) (mxm (list (list (cos ang) (sin ang) 0.0) (list (- (sin ang)) (cos ang) 0.0) '(0.0 0.0 1.0) ) (mapcar '(lambda ( v ) (trans v ocs 0 t)) '( (1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0) ) ) ) ) ) (mapcar '- (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))) (mxv mat (trans (cdr (assoc 10 enx)) ocs 0)) ) ) ) ;; Matrix x Vector - Vladimir Nesterovsky ;; Args: m - nxn matrix, v - vector in R^n (defun mxv ( m v ) (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m) ) ;; Matrix x Matrix - Vladimir Nesterovsky ;; Args: m,n - nxn matrices (defun mxm ( m n ) ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n)) ) ;; Matrix Transpose - Doug Wilson ;; Args: m - nxn matrix (defun trp ( m ) (apply 'mapcar (cons 'list m)) ) ;; Block Name - Lee Mac ;; Returns the true (effective) name of a supplied block reference (defun LM:blockname ( obj ) (if (vlax-property-available-p obj 'effectivename) (defun LM:blockname ( obj ) (vla-get-effectivename obj)) (defun LM:blockname ( obj ) (vla-get-name obj)) ) (LM:blockname obj) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ)
Marko
Hi Marco!
I tested your lisp solution and found a little problem: When you reload xref after invoking this routine it moved insted of fact that it must to Retain Xref Reference Position What the problem?
@igal1971 wrote:Hi Marco!
Try to change this line :
To this line :
(LM:changeblockbasepoint nil ent)
HTH, M.R.
I think that the problem is, because Lee Mac's command will change the xref insert position, but xref drawing is still the same.
So when you restart drawing, only insertion point of xref will be changed.
I think the only way is to change the insertion point, and then to change xref it self.
Igal, will that be the problem for you, if xref drawings are changed?
Hi dicra!
It's seems to be a Real problem because position of all xref's changed, but you don't see it until you reopen the drawing and then you see the catch...
Igal,
I can see the solution for your problem. But I'm not sure that it is going to bee ok for you.
There are two ways.
1. That, all original drawings of xref be changed. When you reopen drawing, it is going to load changed xref. (same as REFEDIT command!!!)
2. That you convert xref to block, and then to change insertion point.
If one of this solutions is good for, you, I could find the way to help you.
Other things, are beyond my knowledge and experience.
Hi Dicra!
Where is very simple way to do it manualy
1. bind xref as block
2. wblock this block with new insertion point and new name
3. open this file explode internal block and make purge command
4. open main file with xrefs and make purge, after that insert modifyed xref
an so on for all xrefs with "problem" insertion poit....
Can you make a lisp in order to automate this algorithm?
If you don't have nested xrefs into xrefs, make backup of all files (master DWG + xrefs), and try this on master DWG just once...
;; Retains Xref Reference Position (defun c:cxpr ( / ss entlst p pentlst f ) (command "_.UCS" "_W") (prompt "\nSelect Xref entities to process changing insertion points to WCS origin while retaining their position...") (setq ss (ssget '((0 . "INSERT")))) (setq entlst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach ent entlst (if (eq (vla-get-isxref (vla-item (vla-get-blocks (LM:acdoc)) (LM:blockname (vlax-ename->vla-object ent)))) :vlax-true) (progn (setq p (cdr (assoc 10 (entget ent)))) (LM:changeblockbasepoint t ent) (setq pentlst (cons (cons p ent) pentlst)) ) ) ) (setq f (open "c:/scr.scr" "w")) (write-line "_.QSAVE" f) (foreach pent pentlst (write-line "_.OPEN" f) (write-line (strcat "\"" (findfile (vla-get-path (vlax-ename->vla-object (cdr pent)))) "\"") f) (write-line "_.-LAYER" f) (write-line "T" f) (write-line "*" f) (write-line "U" f) (write-line "*" f) (write-line "ON" f) (write-line "*" f) (write-line "" f) (write-line "_.MOVE" f) (write-line "ALL" f) (write-line "" f) (write-line "0,0,0" f) (write-line (strcat (rtos (caar pent)) "," (rtos (cadar pent)) "," (rtos (caddar pent))) f) (write-line "_.LAYERP" f) (write-line "_.QSAVE" f) ) (write-line "_.CLOSEALL" f) (close f) (alert "After reopening master DWG, type (vl-file-delete \"c:/scr.scr\")") (command "_.SCRIPT" "c:/scr.scr") (princ) ) ;;----------------------------------------------------------------------;; (defun LM:changeblockbasepoint ( flg ent / *error* bln cmd lck mat nbp vec ) (defun *error* ( msg ) (foreach lay lck (vla-put-lock lay :vlax-true)) (if (= 'int (type cmd)) (setvar 'cmdecho cmd)) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (and (= 'ename (type ent)) (setq nbp '(0.0 0.0 0.0))) (progn (setq mat (car (revrefgeom ent)) vec (mxv mat (mapcar '- (trans nbp 1 0) (trans (cdr (assoc 10 (entget ent))) ent 0))) bln (LM:blockname (vlax-ename->vla-object ent)) ) (LM:startundo (LM:acdoc)) (vlax-for lay (vla-get-layers (LM:acdoc)) (if (= :vlax-true (vla-get-lock lay)) (progn (vla-put-lock lay :vlax-false) (setq lck (cons lay lck)) ) ) ) (vlax-for obj (vla-item (vla-get-blocks (LM:acdoc)) bln) (vlax-invoke obj 'move vec '(0.0 0.0 0.0)) ) (if flg (vlax-for blk (vla-get-blocks (LM:acdoc)) (if (= :vlax-false (vla-get-isxref blk)) (vlax-for obj blk (if (and (= "AcDbBlockReference" (vla-get-objectname obj)) (= bln (LM:blockname obj)) (vlax-write-enabled-p obj) ) (vlax-invoke obj 'move '(0.0 0.0 0.0) (mxv (car (refgeom (vlax-vla-object->ename obj))) vec)) ) ) ) ) ) (if (= 1 (cdr (assoc 66 (entget ent)))) (progn (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (vl-cmdf "_.attsync" "_N" bln) (setvar 'cmdecho cmd) ) ) (foreach lay lck (vla-put-lock lay :vlax-true)) (vla-regen (LM:acdoc) acallviewports) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; RefGeom (gile) ;; Returns a list whose first item is a 3x3 transformation matrix and ;; second item the object insertion point in its parent (xref, block or space) (defun refgeom ( ent / ang enx mat ocs ) (setq enx (entget ent) ang (cdr (assoc 050 enx)) ocs (cdr (assoc 210 enx)) ) (list (setq mat (mxm (mapcar '(lambda ( v ) (trans v 0 ocs t)) '( (1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0) ) ) (mxm (list (list (cos ang) (- (sin ang)) 0.0) (list (sin ang) (cos ang) 0.0) '(0.0 0.0 1.0) ) (list (list (cdr (assoc 41 enx)) 0.0 0.0) (list 0.0 (cdr (assoc 42 enx)) 0.0) (list 0.0 0.0 (cdr (assoc 43 enx))) ) ) ) ) (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0) (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx)))))) ) ) ) ;; RevRefGeom (gile) ;; The inverse of RefGeom (defun revrefgeom ( ent / ang enx mat ocs ) (setq enx (entget ent) ang (cdr (assoc 050 enx)) ocs (cdr (assoc 210 enx)) ) (list (setq mat (mxm (list (list (/ 1.0 (cdr (assoc 41 enx))) 0.0 0.0) (list 0.0 (/ 1.0 (cdr (assoc 42 enx))) 0.0) (list 0.0 0.0 (/ 1.0 (cdr (assoc 43 enx)))) ) (mxm (list (list (cos ang) (sin ang) 0.0) (list (- (sin ang)) (cos ang) 0.0) '(0.0 0.0 1.0) ) (mapcar '(lambda ( v ) (trans v ocs 0 t)) '( (1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0) ) ) ) ) ) (mapcar '- (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))) (mxv mat (trans (cdr (assoc 10 enx)) ocs 0)) ) ) ) ;; Matrix x Vector - Vladimir Nesterovsky ;; Args: m - nxn matrix, v - vector in R^n (defun mxv ( m v ) (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m) ) ;; Matrix x Matrix - Vladimir Nesterovsky ;; Args: m,n - nxn matrices (defun mxm ( m n ) ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n)) ) ;; Matrix Transpose - Doug Wilson ;; Args: m - nxn matrix (defun trp ( m ) (apply 'mapcar (cons 'list m)) ) ;; Block Name - Lee Mac ;; Returns the true (effective) name of a supplied block reference (defun LM:blockname ( obj ) (if (vlax-property-available-p obj 'effectivename) (defun LM:blockname ( obj ) (vla-get-effectivename obj)) (defun LM:blockname ( obj ) (vla-get-name obj)) ) (LM:blockname obj) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ)
Basically the same code I already posted...
HTH, M.R.
Small mod of main function :
;; Retains Xref Reference Position (defun c:cxpr ( / ss entlst p pentlst f ) (command "_.UCS" "_W") (prompt "\nSelect Xref entities to process changing insertion points to WCS origin while retaining their position...") (setq ss (ssget '((0 . "INSERT")))) (setq entlst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach ent entlst (if (eq (vla-get-isxref (vla-item (vla-get-blocks (LM:acdoc)) (LM:blockname (vlax-ename->vla-object ent)))) :vlax-true) (progn (setq p (cdr (assoc 10 (entget ent)))) (LM:changeblockbasepoint t ent) (setq pentlst (cons (cons p ent) pentlst)) ) ) ) (setq f (open "c:/scr.scr" "w")) (write-line "_.QSAVE" f) (foreach pent pentlst (write-line "_.OPEN" f) (if (vl-file-directory-p (vla-get-path (vlax-ename->vla-object (cdr pent)))) (write-line (strcat "\"" (vla-get-path (vlax-ename->vla-object (cdr pent))) "\"") f) (write-line (strcat "\"" (findfile (strcat (getvar 'dwgprefix) (vla-get-path (vlax-ename->vla-object (cdr pent))))) "\"") f) ) (write-line "_.-LAYER" f) (write-line "T" f) (write-line "*" f) (write-line "U" f) (write-line "*" f) (write-line "ON" f) (write-line "*" f) (write-line "" f) (write-line "_.MOVE" f) (write-line "ALL" f) (write-line "" f) (write-line "0,0,0" f) (write-line (strcat (rtos (caar pent) 2 50) "," (rtos (cadar pent) 2 50) "," (rtos (caddar pent) 2 50)) f) (write-line "_.LAYERP" f) (write-line "_.QSAVE" f) ) (write-line "_.CLOSEALL" f) (close f) (alert "After reopening master DWG, type (vl-file-delete \"c:/scr.scr\")") (command "_.SCRIPT" "c:/scr.scr") (princ) )
Marko,
I was having some errors with your code, hope you don't mind, I made some changes.
Think I made the same thing, but whit out using script, and with vla functions.
igal,
Sorry I didn't answer immediately.
Please before using this function, please backup all external references and current drawing, because this lisp is modifying external references.
It moves objects in xref form point 0,0,0 to point which one is same as xref insertpoint in active drawing. On that way insertpoint in xref is 0,0,0 in active drawing, and objects of xref are on the same location as in active drawing.
Because xref drawings are changed, please test this routine on example drawing, so that we be sure that this is what you wanted.
Only thing which I'm not sure about it, is because I made selection set of all objects in xref (vla-select newss acselectionsetall).
In that selection set are some vla-objects which are not entitys in drawing, I applied vla-move on all of them.
I don' know if this is wrong, hope that some one more experience will answer.
Anyway, I didn't find any problems while I was using this routine, on my example drawing.
;; Retains Xref Reference Position (defun c:cxpr (/ ss entlst newss ssets v-ent pt1 pat docs) (prompt "\nSelect Xref entities to process changing insertion points to WCS origin while retaining their position..." ) (setq ss (ssget '((0 . "INSERT")))) (setq entlst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach ent entlst (if (eq (vla-get-isxref (vla-item (vla-get-blocks (LM:acdoc)) (LM:blockname (vlax-ename->vla-object ent)) ) ) :vlax-true ) (progn (setq pt1 (cdr (assoc 10 (entget ent)))) (LM:changeblockbasepoint t ent) (setq v-ent (vlax-ename->vla-object ent)) (setq pat (vla-get-path v-ent)) (setq docs (vla-get-Documents (vlax-get-Acad-Object))) (setq x-open (vla-Open docs pat :vlax-false)) (setq ssets (vla-get-selectionsets x-open)) (setq newss (vla-add ssets "SS1")) (vla-select newss acselectionsetall) (vlax-for item newss (vla-move item (vlax-3d-point '(0 0 0)) (vlax-3d-point pt1))) (vla-delete (vla-item ssets "SS1")) (vla-close x-open) ) ;end progn ) ) (princ) ) ;;----------------------------------------------------------------------;; (defun LM:changeblockbasepoint (flg ent / *error* bln cmd lck mat nbp vec) (defun *error* (msg) (foreach lay lck (vla-put-lock lay :vlax-true)) (if (= 'int (type cmd)) (setvar 'cmdecho cmd) ) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (and (= 'ename (type ent)) (setq nbp '(0.0 0.0 0.0))) (progn (setq mat (car (revrefgeom ent)) vec (mxv mat (mapcar '- (trans nbp 1 0) (trans (cdr (assoc 10 (entget ent))) ent 0) ) ) bln (LM:blockname (vlax-ename->vla-object ent)) ) (LM:startundo (LM:acdoc)) (vlax-for lay (vla-get-layers (LM:acdoc)) (if (= :vlax-true (vla-get-lock lay)) (progn (vla-put-lock lay :vlax-false) (setq lck (cons lay lck)) ) ) ) (vlax-for obj (vla-item (vla-get-blocks (LM:acdoc)) bln) (vlax-invoke obj 'move vec '(0.0 0.0 0.0)) ) (if flg (vlax-for blk (vla-get-blocks (LM:acdoc)) (if (= :vlax-false (vla-get-isxref blk)) (vlax-for obj blk (if (and (= "AcDbBlockReference" (vla-get-objectname obj)) (= bln (LM:blockname obj)) (vlax-write-enabled-p obj) ) (vlax-invoke obj 'move '(0.0 0.0 0.0) (mxv (car (refgeom (vlax-vla-object->ename obj))) vec) ) ) ) ) ) ) (if (= 1 (cdr (assoc 66 (entget ent)))) (progn (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (vl-cmdf "_.attsync" "_N" bln) (setvar 'cmdecho cmd) ) ) (foreach lay lck (vla-put-lock lay :vlax-true)) (vla-regen (LM:acdoc) acallviewports) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; RefGeom (gile) ;; Returns a list whose first item is a 3x3 transformation matrix and ;; second item the object insertion point in its parent (xref, block or space) (defun refgeom (ent / ang enx mat ocs) (setq enx (entget ent) ang (cdr (assoc 050 enx)) ocs (cdr (assoc 210 enx)) ) (list (setq mat (mxm (mapcar '(lambda (v) (trans v 0 ocs t)) '( (1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0) ) ) (mxm (list (list (cos ang) (- (sin ang)) 0.0) (list (sin ang) (cos ang) 0.0) '(0.0 0.0 1.0) ) (list (list (cdr (assoc 41 enx)) 0.0 0.0) (list 0.0 (cdr (assoc 42 enx)) 0.0) (list 0.0 0.0 (cdr (assoc 43 enx))) ) ) ) ) (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0) (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))) ) ) ) ) ;; RevRefGeom (gile) ;; The inverse of RefGeom (defun revrefgeom (ent / ang enx mat ocs) (setq enx (entget ent) ang (cdr (assoc 050 enx)) ocs (cdr (assoc 210 enx)) ) (list (setq mat (mxm (list (list (/ 1.0 (cdr (assoc 41 enx))) 0.0 0.0) (list 0.0 (/ 1.0 (cdr (assoc 42 enx))) 0.0) (list 0.0 0.0 (/ 1.0 (cdr (assoc 43 enx)))) ) (mxm (list (list (cos ang) (sin ang) 0.0) (list (- (sin ang)) (cos ang) 0.0) '(0.0 0.0 1.0) ) (mapcar '(lambda (v) (trans v ocs 0 t)) '( (1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0) ) ) ) ) ) (mapcar '- (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))) (mxv mat (trans (cdr (assoc 10 enx)) ocs 0)) ) ) ) ;; Matrix x Vector - Vladimir Nesterovsky ;; Args: m - nxn matrix, v - vector in R^n (defun mxv (m v) (mapcar '(lambda (r) (apply '+ (mapcar '* r v))) m) ) ;; Matrix x Matrix - Vladimir Nesterovsky ;; Args: m,n - nxn matrices (defun mxm (m n) ((lambda (a) (mapcar '(lambda (r) (mxv a r)) m)) (trp n)) ) ;; Matrix Transpose - Doug Wilson ;; Args: m - nxn matrix (defun trp (m) (apply 'mapcar (cons 'list m)) ) ;; Block Name - Lee Mac ;; Returns the true (effective) name of a supplied block reference (defun LM:blockname (obj) (if (vlax-property-available-p obj 'effectivename) (defun LM:blockname (obj) (vla-get-effectivename obj)) (defun LM:blockname (obj) (vla-get-name obj)) ) (LM:blockname obj) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo (doc) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo (doc) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)) ) ) (LM:acdoc) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ)
Hope this is what you are looking for.
cheers,
dicra
Hi Marco Hi Dicra!
I tested all of your routines and have some comments
1. Marco's routine works properly but a little "dirty". I mean why we must to close all drawings? and if we close drawings why not to open it in the end of script session? Why not to wtite a temporaly script in temporaly acad directory in order not to "dirty" a root disk?
2. Dicra. your lisp is very slow just becouce of (vla-select newss acselectionsetall) I don't see any reason to add it to routine.. but the BIG problem is when you reopen master drawing in acad 2013 (i tested it on this "war-horse") xref moved..
Now we can use only Marco's version with some reservations:)
Marko! I "on the way" found another problem. When you have initialy rotated xref in a main drawing programm works not proprerly (xref moved after invoking lisp function and reopening main drawing) Can you fix it?
Ok, try this mod...
;; Retains Xref Reference Position (defun c:cxpr ( / ss entlst pp p r ppentlst f ) (command "_.UCS" "_W") (prompt "\nSelect Xref entities to process changing insertion points to WCS origin while retaining their position...") (setq ss (ssget '((0 . "INSERT")))) (setq entlst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach ent entlst (if (eq (vla-get-isxref (vla-item (vla-get-blocks (LM:acdoc)) (LM:blockname (vlax-ename->vla-object ent)))) :vlax-true) (progn (setq p (cdr (assoc 10 (entget ent)))) (setq r (cdr (assoc 50 (entget ent)))) (LM:changeblockbasepoint t ent) (setq pp (polar '(0.0 0.0 0.0) (- (angle '(0.0 0.0 0.0) p) r) (distance '(0.0 0.0 0.0) p))) (setq ppentlst (cons (cons pp ent) ppentlst)) ) ) ) (setq f (open "c:/scr.scr" "w")) (write-line "_.QSAVE" f) (foreach ppent ppentlst (write-line "_.OPEN" f) (if (vl-file-directory-p (vla-get-path (vlax-ename->vla-object (cdr ppent)))) (write-line (strcat "\"" (vla-get-path (vlax-ename->vla-object (cdr ppent))) "\"") f) (write-line (strcat "\"" (findfile (strcat (getvar 'dwgprefix) (vla-get-path (vlax-ename->vla-object (cdr ppent))))) "\"") f) ) (write-line "_.-LAYER" f) (write-line "T" f) (write-line "*" f) (write-line "U" f) (write-line "*" f) (write-line "ON" f) (write-line "*" f) (write-line "" f) (write-line "_.MOVE" f) (write-line "ALL" f) (write-line "" f) (write-line "0,0,0" f) (write-line (strcat (rtos (caar ppent) 2 50) "," (rtos (cadar ppent) 2 50) "," (rtos (caddar ppent) 2 50)) f) (write-line "_.LAYERP" f) (write-line "_.QSAVE" f) ) (write-line "_.CLOSEALL" f) (close f) (alert "After reopening master DWG, type (vl-file-delete \"c:/scr.scr\")") (command "_.SCRIPT" "c:/scr.scr") (princ) )
Cheers...
Yes, you're wrong, look for "r" variable - it stored rotation angle in radians which is then used to calculate position of new displacement point according to rotation and insertion point of xref... This new point is then used inside script... Master DWG should have then insertion point of xref in WCS origin and should keep rotation parameter of xref and no bad movement of xref should appear - it should be at original position... Sorry, I've checked my code again also on simple example and I can't replicate your error... Try to trace bug in VLIDE, and check all variables before starting script... Your error points to bug that some I suppose (write-line "string" f) string is nil... Its very simple code, you should be able to trace error... All strings should be "some value", or empty string ""...
