Visual LISP, AutoLISP and General Customization
Change to today date
5 REPLIES 5
1339 Views, 5 Replies
Hi guys hav a GooD dAy...!!
i want to paste the today date over the selected text after that zoom extent the screen automatically by lisp ...
i attached files for ur reference.
Plz help me this bcz the same change i hav to do 40 files per day...
5 REPLIES 5
hmsilva
in reply to: 377-83869076
Something like this perhaps.
(vl-load-com)
(defun c:demo (/ cd day dte mth obj ss txt yer)
  (prompt "\nSelect Text text to place current date: ")
  (if (setq ss (ssget "_+.:E:S:L" '((0 . "TEXT,MTEXT"))))
    (progn
      (or *acad*
	  (setq *acad* (vlax-get-acad-object))
      (setq obj	(vlax-ename->vla-object (ssname ss 0))
	    cd	(getvar "CDATE")
	    dte	(rtos cd 2 4)
	    yer	(substr dte 1 4)
	    mth	(substr dte 5 2)
	    day	(substr dte 7 2)
	    txt	(strcat day "." mth "." yer)
      (vlax-put obj 'TextString txt)
      (vla-zoomextents *acad*)
  (princ)
HTH
Henrique
Lee_Mac
Here are two options, the first uses a Field (i.e. the text will automatically update to display the current date), the second uses plain text:
(defun c:test1 ( / ent )
    (while
        (progn (setvar 'errno 0) (setq ent (car (nentsel "\nSelect text, mtext or attribute: ")))
            (cond
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (null ent) nil)
                (   (not (wcmatch (cdr (assoc 0 (entget ent))) "TEXT,MTEXT,ATTRIB"))
                    (princ "\nInvalid object selected.")
                (   (vla-put-textstring (vlax-ename->vla-object ent) "%<\\AcVar Date \\f \"dd.MM.yyyy\">%"))
    (princ)
(vl-load-com) (princ)
(defun c:test2 ( / ent )
    (while
            (cond
                (   (null ent) nil)
                (   (vla-put-textstring (vlax-ename->vla-object ent) (menucmd "m=$(edtime,0,dd.mo.yyyy)")))
    (princ)
Thanks its work .... Man Very Happy ( hmsilva )
hmsilva
You're welcome!
Glad I could help
Henrique
rshortacad
I modified hmsilva's lisp lines and made them bold.
-Changed .'s to /'s
-Changed Month/Day/Year
-Added string to omit the zero in front of the months with 01-09 number months.
(vl-load-com)
(defun c:cd (/ cd day dte mth obj ss txt yer)
    (progn
      (or *acad*
     cd (getvar "cdate")
     dte (rtos cd 2 4)
     yer (substr dte 3 2)
     mth (itoa(atoi(substr dte 5 2)))
       txt (strcat mth "/" day "/" yer)
  (princ)
”Boost
