Visual LISP, AutoLISP and General Customization
Change this .lsp text back to ascII
10 REPLIES 10
Message 1 of 11
oliverwarzecha5440
1890 Views, 10 Replies
I have this old lisp routine that I have been using for quite a while and it works and loads just fine, however I would like to open it to see/edit the code... when I open in Notepad however it opens with wierd symbols... anyone know how to get this back into normal text?
10 REPLIES 10
Message 2 of 11
dbroad
in reply to: oliverwarzecha5440
Oliver,
This is just a guess but I suspect that you may have just renamed a vlx file as a lsp file.  You can't do that.  Find the original .LSP file.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 11
That is a "AutoCAD PROTECTED LISP file"
This is a format to distribute your programs and codes without any concerning about your time/coding/algorithms/.....
Nobody knows the encoding algorithm except AutoDesk!
So, don't waste your time, write it yourself or buy it!
Abbas
Message 4 of 11
Patchy
Is this it?
Message 5 of 11
mid-awe
in reply to: aqdam1978
It's funny how many times over the years this topic comes up. At one point attempts were being made to decompile vlx which made many folks angry. But, let us not scorn those that ask once. It has crossed the minds of several through the years.
Message 6 of 11
aqdam1978
in reply to: Patchy
Hi Patchy,
did you have source code of ADDLEN.LSP?
Message 7 of 11
Patchy
I decoded it with autodc.exe (DOS base)
http://cd.textfiles.com/unprotect/AUTODC/
Message 8 of 11
aqdam1978
in reply to: Patchy
Hi Patchy,
Does it works for .FAS files too?
AutoDC Version 1.0  -- ACAD Protected LISP file Decriptor
Written by: Memphis Software Company
            P. O. Box 172328
            Memphis, TN 38187-2328
            (901)458-4153
AutoDC will decode an encripted AutoLISP(tm) file, this allows
a user to modify the AutoLISP(tm) modules for their own needs
and correct any encountered problems.
AutoLISP(tm) files are encripted for two reasons; the first is
You are encouraged to freely distribute this software program
and this documentation file to other users by any method available.
This program is copyrighted, you the user are allowed to use it only
for evaluation purposes, if you decide to use it commerically or
for any other purposes other than evaluation, you must become a
licensed user. You may become a licensed user by sending $25 to
Memphis Software at the address above, you will receive a current
version of the program by return mail and be placed on our update
list.
For command line parameters, just execute the program by typing AUTODC
Message 9 of 11
Patchy
Unfortunately it doesn't.
Message 10 of 11
dgorsman
In the current context, the copyright blurb is rather amusing.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 11 of 11
mid-awe
in reply to: dgorsman
absurd, is maybe more appropriate.
”Boost
