Change the colour of the drafting tool tip using lisp
2 REPLIES 2
The_Caddie
468 Views, 2 Replies
I use the following lisp to control my window background colour,
;Setting window colour to crimson (uses OLE colour code system)...
(vla-put-TextWinBackgrndColor(vla-get-display(vla-get-preferences(vlax-get-acad-object)))3937500)
However I would like to change the drafting tool tip background also using lisp, but I don’t know which vla-put-….. I need?
Could somebody elaborate on this?
2 REPLIES 2
diagodose2009
in reply to: The_Caddie
HI... i  need  more detalis.,....
Woman Surprised
stepa) You capture  JPG  or BMP image  from your desktop-windows..(CTRL+PrintScreen)
stepb) You  edit this image with mspaint.exe and you write detalis , where  you want swapping the colors
stepc) You  upload the picture here on autodesk.com
Robot Frustrated
Best Regards...
The_Caddie
in reply to: diagodose2009
Couldn't imagine why you'd want more details or what MS-paint has anything to do with it. Like all AutoCAD users I have a tooltip I would simply like to change the tooltip background color using lisp, apposed to manually changing it in the options dialogue box
”Boost
