I use the following lisp to control my window background colour,
;Setting window colour to crimson (uses OLE colour code system)... (vla-put-TextWinBackgrndColor(vla-get-display(vla-get-preferences(vlax-get-acad-object)))3937500)
However I would like to change the drafting tool tip background also using lisp, but I don’t know which vla-put-….. I need?
Could somebody elaborate on this?
HI... i need more detalis.,....
stepa) You capture JPG or BMP image from your desktop-windows..(CTRL+PrintScreen)
stepb) You edit this image with mspaint.exe and you write detalis , where you want swapping the colors
stepc) You upload the picture here on autodesk.com
Best Regards...
Couldn't imagine why you'd want more details or what MS-paint has anything to do with it. Like all AutoCAD users I have a tooltip I would simply like to change the tooltip background color using lisp, apposed to manually changing it in the options dialogue box
