Visual LISP, AutoLISP and General Customization
change length to match length
14 REPLIES 14
Message 1 of 15
1571 Views, 14 Replies
Anybody have a command to make a line change length to match length of a
line, arc, polyline or circle? Could use this when making flat patterns
layouts. Thanks for any help Steve
14 REPLIES 14
Message 2 of 15
Could be done with a little LISP ... but it would take a bit more
information about the line: would you want it to remain at the same angle,
or would that change as well? Which end would you want to extend/shorten? Or
would you like to add the same amount on both ends?
___
"Steve Bose" wrote in message
news:7D3B66E5FBBFCE25D310D9FB971810D8@in.WebX.maYIadrTaRb...
Message 3 of 15
Paul,
Thanks for the reply. Would like it to work like the lengthen total
command, where the end you pick changes with line staying at same angle.
Steve
Paul Turvill wrote in message
news:7A8D40B59353F6DBCED9BC553D058B96@in.WebX.maYIadrTaRb...
Or
> ___
Message 4 of 15
Quick & dirty -- easiest way seemed to be to just use the LENGTHEN command:
(defun C:ASLONGAS (/ cmde obj len)
(setq cmde (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq obj (car (entsel "\nSelect object to measure: ")))
(command "_.lengthen" obj "")
(setq len (getvar "perimeter"))
(prompt "\nPick end of line to change: ")
(command "_.lengthen" "_t" len pause "")
(setvar "cmdecho" cmde)
(princ)
No error checking, but it works as you describe on most objects. Feel free
to modify & refine as you see fit.
___
news:13B398086E8D2508C05493B48C486A81@in.WebX.maYIadrTaRb...
> Paul,
> Thanks,
> Steve
angle,
extend/shorten?
> Or
> > ___
a
patterns
Message 5 of 15
Paul,
Thank you very much, it works great.
Steve
news:31D10002CD4E467755A79D766552F9BB@in.WebX.maYIadrTaRb...
command:
> (princ)
> ___
> > Paul,
> > Thanks,
> > Steve
> angle,
> extend/shorten?
> > Or
> > > ___
of
> a
> patterns
Message 6 of 15
JoseVicario
Message 7 of 15
steven.bose
any know why this works great in 2006, but hangs up in 2018?
thanks for any help,
Steve
Message 8 of 15
pbejse
in reply to: steven.bose
  (setq len (vlax-curve-getDistAtParam obj
                      (vlax-curve-getEndParam obj)
   (command "_.lengthen" "_t" len)
  		(while (> (getvar 'cmdactive) 0) (command pause))
  	(command)
  (princ)
Message 9 of 15
steven.bose
in reply to: pbejse
Works great! thank you very much!
Would be cool if it could change a circle circumference to match a line length also if possible.
thanks again,
Steve
Message 10 of 15
steven.bose
;;changed one line to work on 2018, thank you Kent Cooper
;;(command "_.lengthen" obj "")
(command "_.lengthen" obj nil);;changed per Kent Cooper for 2018
(princ)
Message 11 of 15
Kent1Cooper
That needs a different approach, since LENGTHEN can't be applied to a Circle.  One way to do it, in simplest terms:
(setpropertyvalue
  (car (entsel "\nSelect Circle to change circumference: "))
  "Circumference"
  (getpropertyvalue (car (entsel "\nSelect Line for length: ")) "Length")
Kent Cooper, AIA
Message 12 of 15
pbejse
Yeah, that would be nice isnt it?
Message 13 of 15
steven.bose
in reply to: Kent1Cooper
Works good Kent, was able to pick circle and change
circumference to match a picked line length.
Thank you!
Steve
Message 14 of 15
Kent1Cooper
Thank you!
You're welcome.  For the source object for the length to impose on the Circle, you can also pick a Polyline or an Arc, because they also have the same "Length" property under the (get/setpropertyvalue) system.  [But not an Ellipse or Spline.]
Kent Cooper, AIA
Message 15 of 15
Sea-Haven
Why not use a cond for the length is it Line,arc,lwpolyline then length or Circle then circumference ?
Ps no getproperty in Bricscad.
; (GETPROPERTYVALUE (CAR (ENTSEL "Select Line for length: ")) "Length")
; error : no function definition <GETPROPERTYVALUE> ; expected FUNCTION at [eval]
”Boost
