*Bose, Steve
Message 1 of 6 (245 Views)
change length to match length
245 Views, 5 Replies
05-24-2002 10:37 PM
Anybody have a command to make a line change length to match length of a
line, arc, polyline or circle? Could use this when making flat patterns
layouts. Thanks for any help Steve
*Turvill, Paul
Message 2 of 6 (245 Views)
Re: change length to match length
05-25-2002 12:52 AM in reply to: *Bose, Steve
Could be done with a little LISP ... but it would take a bit more
information about the line: would you want it to remain at the same angle,
or would that change as well? Which end would you want to extend/shorten? Or
would you like to add the same amount on both ends?
___
"Steve Bose" wrote in message
news:7D3B66E5FBBFCE25D310D9FB971810D8@in.WebX.maYIadrTaRb...
*Bose, Steve
Message 3 of 6 (245 Views)
Re:
05-28-2002 01:54 AM in reply to: *Bose, Steve
Paul,
Thanks for the reply. Would like it to work like the lengthen total
command, where the end you pick changes with line staying at same angle.
Steve
Paul Turvill wrote in message
news:7A8D40B59353F6DBCED9BC553D058B96@in.WebX.maYIadrTaRb...
Or
> ___
*Turvill, Paul
Message 4 of 6 (245 Views)
Re:
05-28-2002 05:41 AM in reply to: *Bose, Steve
Quick & dirty -- easiest way seemed to be to just use the LENGTHEN command:
(defun C:ASLONGAS (/ cmde obj len)
(setq cmde (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq obj (car (entsel "\nSelect object to measure: ")))
(command "_.lengthen" obj "")
(setq len (getvar "perimeter"))
(prompt "\nPick end of line to change: ")
(command "_.lengthen" "_t" len pause "")
(setvar "cmdecho" cmde)
(princ)
No error checking, but it works as you describe on most objects. Feel free
to modify & refine as you see fit.
___
news:13B398086E8D2508C05493B48C486A81@in.WebX.maYIadrTaRb...
> Paul,
> Thanks,
> Steve
angle,
extend/shorten?
> Or
> > ___
a
patterns
*Bose, Steve
Message 5 of 6 (245 Views)
Re:
05-29-2002 02:01 AM in reply to: *Bose, Steve
Paul,
Thank you very much, it works great.
Steve
news:31D10002CD4E467755A79D766552F9BB@in.WebX.maYIadrTaRb...
command:
> (princ)
> ___
> > Paul,
> > Thanks,
> > Steve
> angle,
> extend/shorten?
> > Or
> > > ___
of
> a
> patterns
Active Member
JoseVicario
Message 6 of 6 (184 Views)
08-20-2012 03:42 AM in reply to: *Bose, Steve
